Like Tree1Likes
CEN Matrix TR
Old 07-06-2008, 08:38 AM
  #1576
lockmouth's Avatar
Trader Rating: 33 (100%+)
switch the wires on the motors
lockmouth is offline
Old 07-06-2008, 06:35 PM
  #1577
Trader Rating: 19 (100%+)
Thanks Lockmouth got it... Now I have been trying a few different wings and some of them dont fit on the stock TR wingmount like the J-concepts and proline High downforce dont fit. My question is does the Himoto wing fit? I want a High downforce wing to try. But I will say that I do like the RC8 wing. It is huge and keeps its form well in scuffles.
malik is offline
Old 07-07-2008, 09:21 AM
  #1578
chrobar's Avatar
The Himoto wing fits fine.
chrobar is offline
Old 07-07-2008, 09:24 AM
  #1579
Trader Rating: 21 (100%+)
I use the Proline High Downforce wing. I just use my dremel to remove the ribs on the bottom that interfere with the wing mount.
Colin
C Branch is offline
Old 07-07-2008, 09:50 AM
  #1580
just cut a strip off of both wing mounts where the holes are to make it thin enough that way most any wing will fit with no interference of the wing mount
Robert.Hull is offline
Old 07-07-2008, 10:06 AM
  #1581
Chrobar the Himoto fits with no mods? Thanks guys..
malik is offline
Old 07-07-2008, 05:34 PM
  #1582
chrobar's Avatar
Yup, well just about. I did a little shaving on the bottom, but it took all of 2 minutes.
chrobar is offline
Old 07-07-2008, 05:37 PM
  #1583
Nice, thanks.
malik is offline
Old 07-07-2008, 06:21 PM
  #1584
CEN_RACING's Avatar
Default question
Originally Posted by Tree
A few updated pictures of my CEN Matrix TR Arena
hi sir!
i notice you are using the original matrix arena chassis. How were you able to use the traditional chassis brace?
thanks!
CEN philippines
CEN_RACING is offline
Old 07-07-2008, 06:26 PM
  #1585
lockmouth's Avatar
Guys here ya go... This wing setup here allows any wing to mount directly without any mods I have yet to break a wing mount or even bend it with this set-up ( I not on my lid much )
You can use the stock radio post, but I had some Ofna wing mount post so i used them instead. They are a little longer an they look nice to boot
Old 07-07-2008, 08:16 PM
  #1586
Tree's Avatar
Originally Posted by CEN_RACING
hi sir!
thanks!
CEN philippines
I drilled out the chassis for the buggy braces. I mounted the front brace to the front end assembly then drilled the chassis right through the mounting hole of the brace. I also did the same to the rear. I mounted the brace to the rear end assembly the drilled through the hole of the rear chassis brace. Use a smaller drill bit so that you don't strip the threads of of the chassis braces. Then you can drill the holes larger if needed to accomdate the screws.
Tree is offline
Old 07-07-2008, 08:39 PM
  #1587
Where do ou guys mount your transponders? I am finally getting a personal and am trying to figure it out?
malik is offline
Old 07-08-2008, 08:02 AM
  #1588
TripleX-JT's Avatar
If you are still running the guards on the TR. I just had some velcro and stuck it to the guard. I never had it fall off and it was removable.
TripleX-JT is offline
Old 07-08-2008, 08:04 AM
  #1589
I put mine inside the radiobox. There is plenty of room for it in there.
Colin
C Branch is offline
Old 07-08-2008, 08:08 AM
  #1590
TripleX-JT's Avatar
Great minds think alike. That is what I did early this season and I have never bent or twisted the wing mount yet. It also allows you to mnt any wing perfect. I used the radio post from the buggy and a couple washers. This is a great mod
