Old 01-18-2007, 02:01 PM   #1456
I measured the springs, and found about .010" difference between them. I have another set of springs, I will put those on, and check. Have there been problems with the stock shock orings leaking?
jonny257 is offline   Reply With Quote
Old 01-18-2007, 02:22 PM   #1457
SupermaxxRich's Avatar
you don't have any binding anywhere do you? Like maybe overly tightened outer rear hingepin nuts causing the rear hubs to bind in the arm?
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 01-18-2007, 02:50 PM   #1458
The supension drops under its own weight without shocks or tires on.
Old 01-18-2007, 03:35 PM   #1459
OK, good. Don't know what to tell ya bud without seeing the car in person.....
Old 01-18-2007, 04:53 PM   #1460
dirtracer1's Avatar
yup.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 01-18-2007, 06:26 PM   #1461
tex1's Avatar
Send a message via Yahoo to tex1
Red face Come on guys......
The car is much heavier on the radio side. I run aluminum screws in the top and bottom of the radio tray. I have a 1000 mah Lipo in the box. Now it will sit on balancing pins. It is still heavy to the radio side though.
Before I did this stuff, I ran 2.5 oz of weight on the flap under the pipe. The car woulds still rock to the radio side when on the pins.
I would guess between 2.5 and 2.75 ozs.
I could not figure out why the car would always want to come off of a jump on it's right front nose. I measured her underside and had to do some sedan type figuring. Sure enough. Real heavy to the radio side.
Now it flies straight as an arrow. All of my weight is removed.
The Aluminum screws are Associated 4-40 and 8-32s.
Hope this helps,
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 01-18-2007, 06:39 PM   #1462
Hope this helps,
TEX
when you did this check did you have fuel in the car? biggest gain you'll get for reducing weight on the radio side is the Lipo batteries. Aluminum screws are kinda a waste of time as the heads on them strip pretty easily.... but if you don't mind replacing them more often...then I guess thats something one could try.
Old 01-18-2007, 08:09 PM   #1463
Default Team Losi 8ight-T!!
Get them while he's got them! Tod at RC Compound ordered quite a few of these from the first batch but they are pre selling FAST at these prices
$535 US Shipped to your door! B)
http://www.rccompound.com/p2068/Team...duct_info.html
Old 01-19-2007, 09:24 AM   #1464
What are the different sway bar sizes that come with the kit?
Dale.0 is offline   Reply With Quote
Old 01-19-2007, 09:27 AM   #1465
If your car isent sitting level first try swapping the shocks from one side to the other. It also might be the shocks are assembled wrong. I would be concerned that your shocks are leaking before you have even ran it. If that doesent do it it must be weight on one side more than the other.
Old 01-19-2007, 10:01 AM   #1466
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
So they had some of the 8T's in stock? It shows out of stock right now.
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE houstonsengineservice@live.com (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 01-19-2007, 10:05 AM   #1467
also disconnect the roll bars after an impact i found the rear bar was screwing the ride height to the point there was 8mm difference between the spring collars
chuckyegg is offline   Reply With Quote
Old 01-19-2007, 10:17 AM   #1468
Bigedmond's Avatar
no, it was for pre-order. Shows that the price you might be able to find them for is coming down every month.
Bigedmond is offline   Reply With Quote
Old 01-19-2007, 10:19 AM   #1469
Ah ok I see what you are saying. Damn I got my hopes up and was just waiting for the hobby shop to open so I could see if mine was on its way.
Old 01-19-2007, 11:22 AM   #1470
Ronny.A's Avatar
Hope this helps,
TEX
Tex is very correct in the statment that a car with a heavier side WILL lean towards that side after a level take-off. I also agree with his effort to balance it as much as possible, as this could also give a "tweeking" feeling, i.e the car would accelerate / brake more to one side then the other. I would however not use alum. screws on the car, I actually rather make it a bit heavier on the light side then using Aluminium screws, just by the fact that they have taken me out before, and that they should merly be used for 1/10 electric IMO. Lipo-pack, titanium-screws on the radio-side is cool..
Nice tread btw
Ronny.A is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
