Old 01-01-2007, 07:04 AM   #1216
Great job with full details.
I have a question about setup. Has anyone found a good basic all around setup posted on the websites? The few people that has ran the Losi in my area talk about the rearend breaking loose coming out of the corner. I think they may ran the setup the instructions called for.
kyracer is offline   Reply With Quote
Old 01-01-2007, 08:23 AM   #1217
Trader Rating: 28 (100%+)
run the stock setup with the following:
54 pistons/40wt oil in the froint shocks.
3/3 rear plate
inner hole on the rear hub.
FlyByWire is offline   Reply With Quote
Old 01-01-2007, 12:56 PM   #1218
thanks I will give it a try
Old 01-01-2007, 02:54 PM   #1219
are these the rubber things everyone is using to save there servos and if so post a pic of your install please
JATOMAN is offline   Reply With Quote
Old 01-01-2007, 03:09 PM   #1220
Yes they are. They come with the servo you buy.
Old 01-01-2007, 03:27 PM   #1221
ok but what if i get the RTR will it come with the spacers?
Old 01-01-2007, 06:56 PM   #1222
Default Clutch Bearing pole..
How much run time are you getting out of your bearings?
Or how often are you changing them?
MonkeyWrench is offline   Reply With Quote
Old 01-01-2007, 09:09 PM   #1223
SupermaxxRich's Avatar
I only got about 2 hours track time out of my stock bearings before I changed them. I had a couple bearings that were getting notchy already. I have installed TKO Ceramics since then and they are well worth the extra money!! If you clean them and preform routine maintenance on them they will last you a VERY LONG time.
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 01-02-2007, 06:46 AM   #1224
sport10's Avatar
The RTR comes with them also. Look in your radio box. The grommets are locked onto the servo using a brass sleeve. You slide the brass sleeve in the hole of the grommet(from the bottom) after the grommet is in the ears of the servo. This locks the grommet in place. Do not over tighten the screws that hold the servo in place just tighten down till the screw is flush with the top of the rubber grommet. This way the servo can flex back and forth if get too much load.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 01-02-2007, 07:17 AM   #1225
sport10's Avatar
A little question about the clutch. I was running my 8ight RTR this past weekend and noticed the clutch was not engaging as well as before. So I opened it up and found one of the shoes was stuck from the mushrooming of the aluminum shoes. I tried to loosening the clutch pins and they both stripped. I was using a good 1/16 screwdriver too. I noticed they had locktite on them when I managed to get one out by slotting it for a screwdriver the other broke in half and so I have to replace the flywheel now . How many of you are using locktite on these? Is it nessessary? It is going to get old having to replace the flywheel each time I have to rebuild the clutch because the clutch pins are soft.
Associated B44
Associated B6
Old 01-02-2007, 07:25 AM   #1226
R40Victim's Avatar
I used locktite on my flywheel, but not very much force in tightening them. That way I know I can get them back off. So far, they haven't come apart on me since the first small front bearing let go, and I was able to swap shoes/springs pretty easily.
R40Victim is offline   Reply With Quote
Old 01-02-2007, 07:49 AM   #1227
yes, use one drop of blue locktite but don't "torque" the screw down. Just wind the screw down until it touches the flywheel and then your done. If you tighten the screw down too much not only will you strip out the flywheel but you will put pressure onto the clutch shoe as well making it hang up or stall late.....
Old 01-02-2007, 10:51 AM   #1228
sport10's Avatar
Thanks, I am new to these kind of clutchs and is info is invaluable.
Associated B44
Associated B6
Old 01-02-2007, 11:42 AM   #1229
weezer23's Avatar
Whatsup guys well Im new to the 8ight family, just ordered my kit today. Ive been racing a Kanai 3 and defenently look forward to racing the 8ight. Glad to see a forum with this much information and help on the buggy.
weezer23 is offline   Reply With Quote
Old 01-02-2007, 05:36 PM   #1230
rod_b's Avatar
Send a message via AIM to rod_b
Is there somewhere that shows the differences between the RTR and the Pro kit...in terms of performance parts on the buggy itself?! Thanks
rod_b is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
