Old 09-27-2006, 11:51 AM   #106
Super Moderator
Brandon Rohde's Avatar
Originally Posted by csdonnie
hey Brandon. should i pull the tubing so that its flush or a couple of mm in the tank? now i have about an in of tubing in the tank. i sure its like that for packaging.
No, keep the fuel tube long so it goes all the ways to the back of the tank. The 'clunker' on the end is weighted, so if you flip over it drops to the lowest part of the tank so it still gets fuel and doesn't flame out.
Brandon Rohde
LiveRC.com
Brandon Rohde is offline   Reply With Quote
Old 09-27-2006, 11:51 AM   #107
Super Moderator
oops, sorry jimball, didnt mean to repeat what you said... I hit reply and then got a phone call, so when I finally posted you had already beat me to it.
Brandon Rohde
LiveRC.com
Old 09-27-2006, 11:53 AM   #108
jimbal's Avatar
No problem Brandon. Nice to see someone on the same page.
jimbal is offline   Reply With Quote
Old 09-27-2006, 12:24 PM   #109
thanks guys!! hey what type of battery pack are or will you run?
csdonnie is offline   Reply With Quote
Old 09-27-2006, 12:44 PM   #110
jimbal's Avatar
I went with a Orion 1600 hump pack. The Li-Po's are kinda pricy.
Old 09-27-2006, 12:49 PM   #111
what other starter boxes will work besides the mugen?
xxxtracer is offline   Reply With Quote
Old 09-27-2006, 12:54 PM   #112
rdeppen's Avatar
Orion 1600 same as Jimbal
R40 if you let it setup overnight your going to be golden as far as the shock pistons go.
I posted this over on the S-grid this morning after I downloaded the latest RC Car
This is Travis Amezcua's 4 rnd TQ setup of the Buggy Nats at the Farm.
Front:
Toe out 2 degrees
Ride Height 27mm
Camber Neg 1 degrees
Caster 20 degrees
Sway Bar 2.3mm
Piston/oil 54/40wt
Spring 4.4
Droop N/A
Shock Length 97mm (I'm guessing as it wasn't printed Travis does it the
same way Drake does by using the droop screw to set overall length)
Steering Ackerman Long
Bump Steer Down
Camber Link 2
Shock Location 2 on tower Inside on Arm
Diff 5000wt
Rear:
Toe 3 degrees
Anti-Squat 3 degrees
Ride height 29mm
Camber Neg 2 degrees
Rear Hub spacing Back
Sway bar 2.5mm
Piston/oil 55/32.5wt
Spring 3.1
Droop N/A
Shock length 106mm
Camber link 4-A
Shock location 2 inside on arm
Diff 2000wt
Center:
Diff 7000wt
Gearing 13/48
rdeppen is offline   Reply With Quote
Old 09-27-2006, 12:57 PM   #113
rdeppen's Avatar
xxxtracer the small grey top OFNA box will work with the 8ight. You may have to trim the wheel a little. I would suggest dremeling the chassis opening ever so slightly also to aide in starting. I dremeled the opening on mine, took my time with it and it came out really clean and starts MUCH easir.
Old 09-27-2006, 01:13 PM   #114
GeneralG's Avatar
Send a message via AIM to GeneralG
Read on rcuniverse that the ofna wheels will not work on the Losi 8ight... can anyone comfirm this? What about Proline wheels, or other brands of wheels??
www.gsairwerx.com
GeneralG is offline   Reply With Quote
Old 09-27-2006, 01:18 PM   #115
sepirts's Avatar
I've got an RD Logics box that works fine. I did trim the wheel. The flywheel opening in the 8ight chassis is slim.
sepirts is offline   Reply With Quote
Old 09-27-2006, 01:21 PM   #116
sepirts's Avatar
I've got Proline dish rims on my 8ight - no probs. I've also had some Jammin premounts (rippers & shredders) that I used during breakin. Again, no problems.
Old 09-27-2006, 01:24 PM   #117
sepirts's Avatar
Same as jimbal - Orion 1600 hump pack. Someday I'll switch over to a lipo rx pack. I've got plenty of hump packs that still work really well. No reason to invest into lipo. ha, I just spent $500 on a new 8ight, and I'm too cheap to buy a Lipo rx pack!
Old 09-27-2006, 01:29 PM   #118
sepirts's Avatar
Has anyone stripped out the button head screws that hold the shock pistons on? I've seen two kits with this problem, and one of them had a crack in the shock shaft where the screw threads into.
Old 09-27-2006, 02:02 PM   #119
Trader Rating: 14 (100%+)
I think he meant starter box wheels.
I too have a ofna box that will not work, the wheel is to big. I'm kinda glad because I can't stand that box, weighs so much with that 12v motor and gel cell inside.
o.s. power is offline   Reply With Quote
Old 09-27-2006, 02:36 PM   #120
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
how is everyone trimming the wheels down on yalls starter boxes? a fresh razor or someething?
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
