Old 12-18-2006, 12:02 PM   #1096
Steve Torrey's Avatar
Default New Products
Steve Torrey is offline   Reply With Quote
Old 12-18-2006, 09:55 PM   #1097
I can't seem to find Ultimate Products Racing online. Any company info or web address?
spinall4 is offline   Reply With Quote
Old 12-18-2006, 10:19 PM   #1098
I will get Brian from Ulitmate products to post some info on when and where you will be able to get some of these products. There were a number of cars with the servo spacer installed , that raced at the Best of the west this past weekend and everyone was very happy with how there cars performed.
Old 12-19-2006, 02:43 AM   #1099
tex1's Avatar
Send a message via Yahoo to tex1
That brace looks great. Did they go vertical down the back of the throttle servo as well? This will give you max strength to prevent twisting.
Good stuff.
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 12-19-2006, 02:46 AM   #1100
tex1's Avatar
Please........
Anyone have any resolution or quick fixes for the oring situation on the shocks?
May have to raid Adam's boxes if we cannot get these kits in.
TEX
www.indyrcworld.net
(972) 271-4844
Old 12-19-2006, 04:08 AM   #1101
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
I just ordered 5 bags from a-main hobbies....hurry before they are out!
Also;
Always run some kind of shock boots.
Make sure the boots are not ripped....check'm often.
Make sure when building the shocks there is zero rebound...(no pressure)
These few things helped my shocks alot.
SCUBA STEVE is offline   Reply With Quote
Old 12-19-2006, 05:27 AM   #1102
I also think a carbon fiber frame stiffner would also be perfect. One that is similar to the one above, but curves down, vertical with the servo for added stiffness, and heat protection from the motor. Plus it would look cool
Old 12-19-2006, 10:45 AM   #1103
layedbackguy's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to layedbackguy
Does anyone have a good indoor setup? I wonder what Adam was using for a indoor setup. If anyone knows, please let me know asap, per my buggy is broken down ready for a lube and rebuild job
layedbackguy is offline   Reply With Quote
Old 12-19-2006, 11:20 AM   #1104
Trader Rating: 28 (100%+)
Ive got a gallon through mine.. I set up the throttle the right way, and never had a problem. Flex doesnt kill servo motors.
FlyByWire is offline   Reply With Quote
Old 12-19-2006, 12:28 PM   #1105
Ulitmate products phone # (909)949-3000
Old 12-19-2006, 07:33 PM   #1106
Default steering servo horn inserts.
Has anyone else had problems with steering servo horn inserts stripping out? I setup the servo saver as directed in the manual, am runnin a JR 9000t, with spacers and rubber mounts with proper epa setup all the way through the travel of the suspension. I've stripped two inserts and had to drop out of two mains because of it. The steering feels smooth as silk with no binding and my horn screws had not loosened up at all to cause it. Any thoughts or suggestions would be greatly appreciated. As far as throttle, I cut my spring way down and added a return spring to help pull the slide back rather than making the throttle servo hold it there. So it has no compression on the return spring until just when you start to apply brakes.
cfeight is offline   Reply With Quote
Old 12-19-2006, 07:42 PM   #1107
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Are you stripping both throttle and steering inserts ? I`ve seen a few guy stripping the steering insert and put a metal servo horn in place and seemed to be fine .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 12-19-2006, 07:49 PM   #1108
I'm only stripping the steering, throttle has worked flawlessly. I've run about 2 and a half gallons through it, so I'm confident of the throttle setup.
Old 12-19-2006, 07:51 PM   #1109
Briguy's Avatar
I`d put a metal horn or a servo saver as a horn on the servo .
Royal R/C & Hobby
Old 12-19-2006, 07:52 PM   #1110
SupermaxxRich's Avatar
manual is wrong, there setting is way to tight for the servo saver. I have mine set to 3 threads up from the bottom wich is still fairly snug but I run the Hitec 5955 servo wich is BAD @$$
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
