Old 12-09-2006, 05:50 AM   #1036
Spinall4,
That is a good question. I saw a large drawout of how it all works in this mo. mag. I think it was RCextreme or RCdriver. The bottom line is the thinner the oil the more the tires will spin. The thinker the more the tires will pull. You can also go to much so be careful not to go to extremes on the Oil. If you are running buggy. A safe bet is to go F5,C7,R2 or F5,C5,R3/2.
Guys correct me if im wrong.
kyracer is offline   Reply With Quote
Old 12-09-2006, 06:35 AM   #1037
Sofast-NT's Avatar
Originally Posted by Flode007
The Lrp is perfect
Where did you get your pack and regulator from?
Thnx
Sofast-NT is offline   Reply With Quote
Old 12-09-2006, 10:47 AM   #1038
SupermaxxRich's Avatar
The Lrp is perfect
does that pack fit under the "flat" battery lid? do you have the stock foam under the battery? how much run time you get with that battery and what servos are you running? thanks....
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 12-09-2006, 11:57 AM   #1039
Flode007's Avatar
Send a message via MSN to Flode007
Originally Posted by SCUBA STEVE
Flode007, I can't find that lrp for sale anywhere?...at least not that flat one that's pictured.
Does that 750mah vxr lipo pack last very long
This is where i found it
http://www.piraterc.com/modules.php?...rticle&sid=684
Flode007 is offline   Reply With Quote
Old 12-09-2006, 03:49 PM   #1040
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Does the switch on the regulator take the place of your regular switch?
SCUBA STEVE is offline   Reply With Quote
Old 12-09-2006, 04:29 PM   #1041
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
si! i wana know where i can order the lrp regulator also. i went to that site and it said nothing about ordering.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 12-09-2006, 06:50 PM   #1042
Yea, it looks sweet but I got impatient and ordered a muchmore 5 amp regulator, venom 800mah lipo. and a dynamite lipo charger.. that venom pack is very small I just hope it last a while!!
Does anybody else run an 800mah lipo... if so how long does it last?
Old 12-10-2006, 06:02 AM   #1043
R40Victim's Avatar
IT LIVES!!! My throttle servo survived yet another raceday. That includes several practice runs, and pushing the car hard all night. I also replaced my steering servo with a 333 oz Hitec digi, very impressive servo. The only thing that happend to the car all night, the Clutch Bell Retaining Screw came loose. I thread locked and tightened it back up...can ran GREAT!
While I was practicing, I noticed that after a 7 minute run, I still had plenty of fuel left. So we timed it to see how long I could run without refueling. 13 Freakin Minutes!!! The track is small, I rarely use full throttle(once, very briefly on the kinda short straight section), and it's a 21BF Top motor on a JP-2 pipe. I had my brother time it before, and he told me 14 minutes. If I hadn't timed it myself...I wouldn't have believed it...seemed impossible.
R40Victim is offline   Reply With Quote
Old 12-10-2006, 06:19 AM   #1044
Great guys thank you!
Walt, where do you put the regulator?
Anybody else have info
Sorry for the slow reply... been off-line.
My Novak regulator is tucked into the receiver compartement. It would actually fit better in the battery compartment, but the wiring would have been more difficult. I like to unplug my Lipo whenever I'm not running the car. With the battery in the back and the next component (the regulator) in the receiver compartment, I could put a plug between them that sits next to the throttle servo.
And Lipos are 3.7 volts/cell nominal I believe, but when fully charged they are 4.2 volts/cell.
SpeedPassion, SpeedPower, ProLine Racing
Losi 8ight, Losi SCTE, AE SC10, AE RC10T4, Kyosho IGT
Walt is offline   Reply With Quote
Old 12-11-2006, 09:22 AM   #1045
TEN,TEN,'s Avatar
i have a question,
whats the difference between the king headz 6061 alum. clutch shoes and the 7075 alum. clutch shoes, are they different in softness or somthing?
thanks in addvance.
ten....
TEN,TEN, is offline   Reply With Quote
Old 12-11-2006, 09:33 AM   #1046
Originally Posted by TEN,TEN,
i have a question,
thanks in addvance.
ten....
Yes, 6061 shoes are softer than 7075 shoes there fore they will have more "grab" but will also wear faster. Hope that answers your question
Old 12-11-2006, 04:39 PM   #1047
TEN,TEN,'s Avatar
i'll problibly go with the harder ones, thanks for the info,
ten......
Old 12-11-2006, 05:15 PM   #1048
Trader Rating: 14 (100%+)
Default throttle servo problems
was just checking to see if you guys have come up with a solution for the throttle servo problem. a friend of mine at the local track has just gone through his third servo, 2 - 8800's and a 4800. we had a new guy show up at the track with a rtr and he blew is throttle servo. i was just checking so i could pass on some info. i ran the 8 for about a month and i did not expereince any problems
jlo
jlo8864 is offline   Reply With Quote
Old 12-11-2006, 05:22 PM   #1049
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Make sure your buddy has the linkage and the slide barrel on the carb adjusted so everything is level and straight so there is no stress on the servo . Currently at our track there are 6 8ights and everyone has the carb and linkage right and no problems .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 12-11-2006, 05:32 PM   #1050
12a_rx2's Avatar
Send a message via MSN to 12a_rx2
i'm not sure if this will effect the servos but i have to fun my carby on a slight angle to avoide hitting the centre diff, this wont make the servos die will it?
Lewis Hewett
12a_rx2 is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
