Old 12-05-2006, 06:37 PM   #991
cornerspeed's Avatar
****** 1000 th post ******
So since the aluminum chassis braces are released, has anyone ran them? Any feedback as to how it affected handling, good or bad?
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 12-05-2006, 08:30 PM   #992
TonysScrews's Avatar
Originally Posted by Davidka
It's supprising to hear complaints about chassis flex on a car with a chassis that's 1mm thicker than anything out there. Are you guys sure it's a problem?
It may be thicker but the type of aluminum and where it came from could mean a huge difference.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 12-06-2006, 06:18 AM   #993
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
The chassis is made out of 7075 T-6 aluminum . That`s pretty darn strong aluminum and better than some other buggies chassis . You are going to have some flex , if you remove all the flex you will break arms and shock towers . I think if there was a solid or connecting solid top tray that would eliminate some of the issues people are having .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 12-06-2006, 07:09 AM   #994
Trader Rating: 28 (100%+)
The flexing isnt killing the servo's... Read Drake's post on the trinity site, fix your linkage.. and be done.
FlyByWire is offline   Reply With Quote
Old 12-06-2006, 07:22 AM   #995
It should be VERY easy for the servo manufacturer, doing their 'post-mortum' examination on one of these returned servos, to determine if the servo failed due to mechanical stress on the servo case itself, verses a 'burn out' that tends to occur if end points/linkages are set up incorrectly.
Overall, it seems like there are guys here saying they've suffered servo failures who seem to know what they are doing when it comes to linkages. However, I don't know these people, so it could just be that the linkage is a little harder to set up in the 8ight and that's the root cause of these problems.
SpeedPassion, SpeedPower, ProLine Racing
Losi 8ight, Losi SCTE, AE SC10, AE RC10T4, Kyosho IGT
Walt is offline   Reply With Quote
Old 12-06-2006, 08:12 AM   #996
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
The chassis definately flexes but Like I said I'm sure my servo locked up because of how hard I bottomed out, it sounded like two 2x4's getting slammed together and that was the first servo problem I've had and I have put ALOT of miles on this car....... The linkage is probably the most common cause of failure I would have to say.
Walt, I will see what they say about my servo when it get's repaired but I'm sure I probably shattered a curcuit board inside but I will keep everyone posted.....
SCUBA STEVE is offline   Reply With Quote
Old 12-06-2006, 09:29 AM   #997
Solara's Avatar
Trader Rating: 16 (100%+)
What are the different between both 8ight between the KIT version and the RTR version (beside the price and RTR issues...). I am just wondering who to pick.....the KIT version with better optioned car (I assumed) so I can mount better servos and engine/pipe...........or RTR is just good enough to race.
Thanks guys...........
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-06-2006, 09:50 AM   #998
Trader Rating: 39 (100%+)
From what I can tell from the pictures, the RTR has different shock towers, shock caps, engine mount and chassis. IMO, if you plan on racing, go with the kit. If you plan on bashing, go with the RTR.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 12-06-2006, 11:31 AM   #999
I recommend that you come out to the track this Friday night and try mine out (you can try my Revo too). What do you say Solara? Are you available? Me and E.S. will be there (unless wife says no )
Old 12-06-2006, 12:42 PM   #1000
The kit. If your gonna race you'll will be alot better off.
Old 12-06-2006, 01:29 PM   #1001
Trader Rating: 37 (100%+)
pick me up too
Nexus is offline   Reply With Quote
Old 12-06-2006, 03:43 PM   #1002
Originally Posted by Nexus
pick me up too
Any time Nexus! But I thought you were allergic to nitro or something???
Old 12-06-2006, 03:52 PM   #1003
12a_rx2's Avatar
Send a message via MSN to 12a_rx2
hye guy's
i just picked up an 8ight yesterday, should finish it somtime today
i was just wondering what i might need to do before hitin the track, like is there anything i should change on it
Lewis Hewett
12a_rx2 is offline   Reply With Quote
Old 12-06-2006, 04:27 PM   #1004
R40Victim's Avatar
Just make sure that when you build the shocks, that you lock-tite the shafts, and give them time to dry before filling them with oil. I let mine sit over night, and they haven't come apart. I also put small bits of fuel line in the CVDs to minimize play. Make sure your end points on your throttle and steering are right, and use the rubber gromets that come with your servos for the throttle. Put them under the servo mounts, not in the mounting ears, and don't tighten them any more than you have to.
Other than that, just read through this thread, there are many suggestions, and it's well worth the time to read...
R40Victim is offline   Reply With Quote
Old 12-06-2006, 04:42 PM   #1005
12a_rx2's Avatar
alright thanks for that i'll have a read through later on today
i just locki-tited the shock shafts so they should be ready when it come's time to put them on
Lewis Hewett
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
