Old 12-03-2006, 06:57 AM   #961
JBRacing's Avatar
When ever you guys will decide that you finished spending money on clutch shoes and spend time on working on it, move to Fioroni Turbo sliding clutch!!
By getting it, you will end the torment of working on you clutch all the time.
I ran it last year on my Mugen for an entire season (about 8 gallons) and the only time I opened it was in order to add another spring to it as a setup action.
Anyway, if you do decide to take it you will need the Kyosho flywheel and not the Mugen's because it is to short
JBRacing is offline   Reply With Quote
Old 12-03-2006, 07:52 AM   #962
R40Victim's Avatar
So you can flip the stock motor mounts to use a regular clutch? Might have to try that next time I can't seem to get Losi clutch parts...
I have another aftermarket motor mount comming. It's a 4 piece, much like the King Headz version. Once I get some use out of it, and see how I like it, I'll report back what I find.
R40Victim is offline   Reply With Quote
Old 12-03-2006, 08:12 AM   #963
layedbackguy's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to layedbackguy
Originally Posted by Briguy
Too bad they are out of stock . You can switch the stock mounts around to move the engine forward . You can also use a Sportweks or Mugen flywheel to use a 3 shoe clutch without the K.H mount.
www.bmainhobbies.com has them(4 in stock). Homer is 1 of the best sources for losi parts to me.
layedbackguy is offline   Reply With Quote
Old 12-03-2006, 08:19 AM   #964
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Thanks for the info guys but I am acctually looking for an extended motor mount to reduce chassis flex in the center..... last night my chassis flexed so bad that the center diff mount hit the carb and twisted it in the block!...and that was not in a crash just landing after a big jump. The front and rear braces will not stop the flex in the middle so I think the only answer is an ext. motor mount......any one else have any Ideas?
JBRacing, The fioroni does work great I've been running one in my 8 since day one.
SCUBA STEVE is offline   Reply With Quote
Old 12-03-2006, 12:09 PM   #965
Trader Rating: 39 (100%+)
Were you running the aluminum braces? King Headz makes an engine mount that looks to be beefier than stock.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 12-03-2006, 01:15 PM   #966
cornerspeed's Avatar
If anything, I think the motor should be moved back a couple mm's. Seems light on the back and left side to me. I am going to add wieght behind the motor.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 12-03-2006, 04:10 PM   #967
i think a stronger radio tray that wraps around both sides of the throttle servo would take care of some of that mid-chassis flex. you could always bolt a piece of 1/4" square steel or aluminum stock to the chassis between the 2 chassis braces somewhere that there is room for it.
adam lancia is offline   Reply With Quote
Old 12-04-2006, 01:37 AM   #968
dirtracer1's Avatar
will it work with the losi clutch bell, or do you have to use a kyosho (or compatable) clutch bell?
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 12-04-2006, 03:13 AM   #969
JBRacing's Avatar
Honestly, I didnít tryÖ
My friend, who imports Fioroni to Israel, told me that when he tried to use the Kyosho bell and he had problems with it so he recommended I use their bell and so I did.
Now, when I switched for the MBX5 to the 8ight I bout a whole new, flywheel, clatch and bell.
Old 12-04-2006, 04:34 AM   #970
Dirtracer1, It will not work with the losi bell....it is to deep. I use ofna bells, they work very well.
Old 12-05-2006, 06:46 AM   #971
I think I'm gonna try the KH motor mount some of you were talking about it should make the chassis flex decrease at least a little
Old 12-05-2006, 07:14 AM   #972
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i ran my kh motor mount yesterday. it does not affect the chassis flex at all. now when he comes out with an extended mount then thats another story.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 12-05-2006, 08:17 AM   #973
Yea, I figured that ......as soon as I get the mount in the car a extended version will be released
Old 12-05-2006, 10:43 AM   #974
Trader Rating: 66 (100%+)
Has anyone tried to put a jammin z brace in the car. Would that help with the flex in the middle of the chassis. I was wondering if anyone else made aluminum braces for the 8. I would like to run one in the rear to help witht he flex.
Bob Moore is offline   Reply With Quote
Old 12-05-2006, 10:55 AM   #975
ahsikes's Avatar
Trader Rating: 17 (100%+)
King Headz braces should be out this week for the rear.
Take a look at them before you decide on one. They left the nuts in the brace in case you happen to break a screw off. You wont lose the whole part, or have to drill it out.
ahsikes is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
