Old 12-01-2006, 09:34 AM   #946
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I didn`t use the collet that came in the kit , I used the one that came with my engine . The kit one wasn`t the right size .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 12-01-2006, 10:19 AM   #947
Well I used the one that came with kit and the first flywheel collet ate into the flywheel which caused it to just rev up then catch and keep doing it.
Ghost06 is offline   Reply With Quote
Old 12-01-2006, 10:30 AM   #948
Briguy's Avatar
All collets are not the same size and thickness . Use one that fits your engine and put the flywheel on .
Royal R/C & Hobby
Old 12-01-2006, 11:53 AM   #949
Trader Rating: 39 (100%+)
Sounds like you need to make the flywheel nut tighter. I never had a problem with mine...I had it on 3 different engines so far...still working fine.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 12-01-2006, 02:32 PM   #950
i would think that the collet that came with the flywheel would be a better match than the one that came with the engine
xxxtracer is offline   Reply With Quote
Old 12-01-2006, 10:43 PM   #951
I tightened it down alot but it ate it up, I'll try the collet that came with the motor if this one messes up then I'm going to the standard setup.
Old 12-02-2006, 06:11 AM   #952
Briguy's Avatar
It might be good for the flywheel but not the engine . Collets are different and if it doesn`t fit snug on the engine without any pressure it will slip with the flywheel nut tightened all the way .
Royal R/C & Hobby
Old 12-02-2006, 06:59 AM   #953
the taper on the collet is what matters, if they are not the same it wont have enough surface area in contact and will slip. the inner diameter on all the big block collets that i have are the same but the outer taper differs from company to company.
Old 12-02-2006, 07:38 AM   #954
SpeedBump57's Avatar
+1 to xxxt ^
SpeedBump57 is offline   Reply With Quote
Old 12-02-2006, 07:39 AM   #955
Jared I left you a reply in the Glitchers thread!
Old 12-02-2006, 10:35 AM   #956
Read and replied sir.
Jared Fournier is offline   Reply With Quote
Old 12-02-2006, 11:33 PM   #957
cornerspeed's Avatar
Ran my 8ight for the first time tonight at ARC Raceway. Went pretty well. 2nd qualifier and 1st place in the 20 min. main. The car accelerates like a missile. Had to drive it about 50-60%. Hoping it will get a little easier to drive once the car breaks in. I think it has a lot of potential. I didn't get the brake bias dialed in. Have to work on that next time. Also want to lighten up the center and rear diff oils. Maybe that will calm it down for me as I am normally a electric TC racer with lots of traction.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 12-03-2006, 05:38 AM   #958
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Does any one make an extended engine mount for the eight yet?
Thanks!
SCUBA STEVE is offline   Reply With Quote
Old 12-03-2006, 06:31 AM   #959
layedbackguy's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to layedbackguy
Thanks!
www.kingheadz.com
they make a quick change mount. you can switch it around and it moves 2mm foward, so you can use a 3 shoe clutch system without shimming it to much.
layedbackguy is offline   Reply With Quote
Old 12-03-2006, 06:41 AM   #960
Briguy's Avatar
Too bad they are out of stock . You can switch the stock mounts around to move the engine forward . You can also use a Sportweks or Mugen flywheel to use a 3 shoe clutch without the K.H mount.
Royal R/C & Hobby
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
