Old 11-27-2006, 08:05 AM   #901
R40Victim's Avatar
Well, my throttle servo survived another race weekend. I did have one odd glitch though. In my first heat, about a minute or two into the run, I briefly lost throttle control, and had to watch my runaway car fly in circles. As I walked toward it, it stopped, and worked normally. I went ahead and killed the motor, and took it back to the pits to inspect it. It appeard to function normally. I don't know if it got hung up for a second or what, but it sems to be fine now. I drove it several more times that night with no problems.
So it appears my insulation worked, this is the second longest a throttle servo has survived. I have several practice sessions scheduled before the next race, so I'll have plenty of time to confirm it will live...I'll keep you guys posted.
R40Victim is offline   Reply With Quote
Old 11-27-2006, 12:35 PM   #902
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
my king headz motor mount showed up today. definatley a nice looking peice. will be installing it today when i get back from work.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 11-27-2006, 01:20 PM   #903
Sofast-NT's Avatar
My Ninja seems to be a good motor so far, I ran a Collari(Werks) for a year and I'm running a Ninja BO-1A now, with a Mugen MSR 1005.
Sofast-NT is offline   Reply With Quote
Old 11-27-2006, 01:20 PM   #904
R40Victim's Avatar
Is that the version that allows you to use regular clutches?
Old 11-27-2006, 01:39 PM   #905
ahsikes's Avatar
Trader Rating: 17 (100%+)
Yes. You can rotate the mounts to allow the engine to move forward.
ahsikes is offline   Reply With Quote
Old 11-27-2006, 03:50 PM   #906
yep that would be the one. it is very sweet .
Rob Jensen
Old 11-27-2006, 04:03 PM   #907
Sofast-NT's Avatar
I'm running a regular clutch-bell but I dont have the KHdz mount, My Dad shimed it out, and it works fine. Had a new bearing go out in a 45min. main at The Farm2 during the Nitro fest.
Old 11-27-2006, 04:45 PM   #908
the king headz mount allows you to pull the motor without having to set the gear mesh every time you service the motor or clutch, also it allows you to run a normal clutch setup by flipping the mounts arround and you dont have to shim the clutch up for it to mesh with the spurr right.
Rob Jensen
Old 11-28-2006, 10:39 AM   #909
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
When you guys are running a normal clutch(3 shoe Mugen or Kyosho or whatever) are you using a normal clutch bell or the Losi clutch bell. I am running my old Jammin set up but I could not use a normal CB due to the fact than when the CB is shimmed out to the spur properly the screw that holds the CB on was hitting the fuel tank. So I had to stick with the Losi bell and more expensive bearings. I would prefer to run a normal bell with the 5x10 bearings since I can get them for like 50 cents each.
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE houstonsengineservice@live.com (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 11-28-2006, 11:06 AM   #910
Davidka's Avatar
Trader Rating: 75 (100%+)
I am using a Mugen clutch with the Losi bell. The Mugen bell wouldn't reach far enough to mesh properly with the spur. Go to www.avidrc.com for bearings. You can get any bearing in the car for $1.
Old 11-28-2006, 11:25 AM   #911
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
seems like you guys replace the clutch bearing pretty often? but how often?
this is my first 8th scale so it seems like this is a normal wear and tear item?
lagcisco is offline   Reply With Quote
Old 11-28-2006, 02:07 PM   #912
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
I hope I don't jinx myself! .... but i have'nt had to replace one yet and I've put alot of miles on my 8
SCUBA STEVE is offline   Reply With Quote
Old 11-28-2006, 03:02 PM   #913
Sofast-NT's Avatar
I replace mine after a few races, or I did. I'm running a standard bell now so I'll have to see how it does on the 8.
Old 11-28-2006, 05:14 PM   #914
saw
r40 if you are running spektrum i would check my switch and battery
anytime i start having an odd glitch the switch was usally bad or the battery had a bad connection
saw is offline   Reply With Quote
Old 11-28-2006, 05:49 PM   #915
patrick lsp's Avatar
Trader Rating: 170 (100%+)
i am running x-ray flywheel with mugen carbon shoes. along with losi bell. the stock losi set up lasted about half a gallon. i have over a gallon thru new set up and i have no noticeable wear. it may be a little softer, but i have twichy trigger finger and it works good for me. i checked it out today in my blacktop driveway, and it leaves black marks from a dead stop... a-main and carolina's both have the inner bearing cheap. from looks of wear, i can easily get another gallon or more out of this set-up for $15 including 1.0 springs
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
patrick lsp is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
