Old 10-25-2010, 08:06 PM   #8671
tc5 man's Avatar
Originally Posted by inferno13 View Post
i went 15000, little more controlable
i will try the 3/3 rear toe plate for more foward traction first and use city blocks front and i-beams rear and see if i get more rotatetion.
Old 10-25-2010, 09:04 PM   #8672
tc5 man's Avatar
so what do you think of that ?
Old 10-26-2010, 04:26 AM   #8673
Try 7/10/5 in the diffs. Put the 1.0 carriers back on and spend $20 with M2C for their outer hing pins. They're hardened steel and come with a drill bit that's the correct size for drilling out the A-arm. If you ever bend one, you've really done something.
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 10-26-2010, 07:44 AM   #8674
Integra's Avatar
Old 10-26-2010, 10:29 AM   #8675
tc5 man's Avatar
Originally Posted by Integra View Post
ok ? whats funny about that
Old 10-26-2010, 10:33 AM   #8676
tc5 man's Avatar
if i get, the m2c outer pins i shouldnt have to drill anymore i wouldnt think because i already have my rear arms drilled to get the 2.0 pins to fit.
yea i, might have to get some new 1.0 rear hubs not sure i did run 7,10,5.. and i dint have enough rotate and the 3000w in the rear seems to be better on a dry track.
il see how much money i have i have to get new clutch shoes so we will see.
Old 10-27-2010, 02:37 PM   #8677
tc5 man's Avatar
have any, of guys bent the rear shock shafts on the 1.0 t should i run less droop than 110mm or is it just from a hard landing off a double maybe ?
its funny, though the one rear shock shaft bented as soon as some of the gold coating started to wear off toward the top of the shaft.
Old 10-27-2010, 03:32 PM   #8678
Integra's Avatar
Hard landing or you got hit from behind.
Ti Coating is just that, A Coating which has nothing to do with the durability of the shaft.
Old 10-27-2010, 03:34 PM   #8679
tc5 man's Avatar
yea i, know i dint think the coating had anything to do with it it was probery from hard landing i never bent a shock shaft on the eights.
Old 10-27-2010, 04:00 PM   #8680
Suspended
Trader Rating: 202 (96%+)
YOU HAD TO DO SOMTHING SERIOUS! i jump mine a local track getting 14 to 16 feet off ground and never bent a shaft yet.
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 10-27-2010, 04:06 PM   #8681
tc5 man's Avatar
it might of been from somebody hitting me from that side or it was when i hit a big double and it landed hard on one side of the rear . its just one rear shock shaft its bent good enough
Old 10-29-2010, 01:29 PM   #8682
Tate72's Avatar
Trader Rating: 52 (98%+)
Are these the ones you are talking about?
http://www.amainhobbies.com/product_...d-Hinge-Pins-2
If they are maybe I'll get a couple of sets. I'm getting tired of replacing the outer hinge pins on our buggies.
It's funny I was just getting ready to ask what would work best for a replacement pin. LOL!!
Thanks there TC
Team Durango, http://www.team-durango.com/
TrakPower Speed Equipment, http://www.trakpowerusa.com/
DE Racing, http://www.deracing.net/
WWW.JCPRCRACEWAY.COM
Tate72 is offline   Reply With Quote
Old 10-29-2010, 01:34 PM   #8683
Integra's Avatar
IMO the Stock 2.0 rear outter pins are Better then the M2C's for the fact you dont have to do any drilling and 3.5mm is more then enough....4mm is Overkill and imo having the small 3mm threaded shaft for the nuts is a weak point.
Go 2.0's and get a set of rear arms to go with them.
Old 10-29-2010, 01:35 PM   #8684
tc5 man's Avatar
Thanks there TC
thats not the ones but they look good i never bent the stock inner pins that go into the arms. heres the ones
Old 10-29-2010, 01:39 PM   #8685
tc5 man's Avatar
im using, the 2.0 rear outer pins and i had to use the 2.0 rear hubs and i can only use the (b) hole in the #4 hole on the tower inless i use the (a) hole with the upper #1 hole on the tower .
i like to use the (a) hole with the #4 on the tower i dont like the (b) on hole on the rear hub.
i have no idea how using the (a) hole on the rear hub with the upper #1 hole on the tower would work on my track.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
