Old 10-25-2010, 07:27 PM   #8656
tc5 man's Avatar
Originally Posted by losi_racer View Post
You are very impatient. As i stated and many agreed try different set ups, just because a set up says use this doesnt mean its right for you. Try different things. You can always cut the links if you want short camber links. if i were you i would try B/1 that would be my starting point and alter your settings from there
well i did mount the link into the #1 hole but it says on the 1.0 t manuel that using the #1 hole is good for high traction surfaces well most of the time my track is dry and dusty so it doesnt have the best grip .
i guess i could use the #1 hole on the tower i do have new rear tires i-beams soft.
im not impatient im just getting aggerated in why i cant use the lower holes on the tower with the 2.0 rear hubs .
i did, use the 1.0 rear hubs with the link on the (a) hole on the 1.0 hubs and the #4 hole and it was fine but i got tried of bending the rear hub hidge pins.
Old 10-25-2010, 07:30 PM   #8657
losi_racer's Avatar
Trader Rating: 25 (100%+)
just try it. stop going by what the manual says, yes it states what it will do BUT it doesnt mean you wont like it.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 10-25-2010, 07:31 PM   #8658
Suspended
Trader Rating: 202 (96%+)
with the i-beams on a 1.0 your going to push BAD in corners, what i did is ran cityblocks in rear and i-beams in front, sounds funny but worked well!
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 10-25-2010, 07:32 PM   #8659
tc5 man's Avatar
ok i did have the 1.0 rear hubs and i could use the (a) hole on the 1.0 rear hubs with the #4 hole on the tower but i got tried of bending the outer hub hidge pins.
i did try to drill the 1.0 hubs out but i couldnt get the 2.0 hub pin to go though all the way.
Old 10-25-2010, 07:32 PM   #8660
warpig's Avatar
In my experience: Going by the rules of thumb in chassis tuning sometimes will get you in the opposite situation you wanted. Or, doing the opposite of what the rule of thumb states may get your right where you wanted.
my $0.02 on that!
Ben Burtle
warpig is offline   Reply With Quote
Old 10-25-2010, 07:34 PM   #8661
tc5 man's Avatar
oh i dint know that i did have a push with using soft city blocks on the front that are well used but still good and brand new i-beams but i will try to use 3 degress of rear toe in to see what happens . as a starting point it said that it will give you more foward traction which it seem like i had lack of.
but if that doesnt work than i will use the city blocks on the rear and the i-beams on the front.
Old 10-25-2010, 07:37 PM   #8662
Suspended
if you had puch before and went to ibeams, your going to puch like a dump truck!
Old 10-25-2010, 07:40 PM   #8663
tc5 man's Avatar
no it was the last time i raced with the city blocks soft on the front and i-beams on the rear.
Old 10-25-2010, 07:41 PM   #8664
tc5 man's Avatar
losi racer- im going to try #1 upper hole on the tower with the (a) hole on the rear hub so i can get rotation.
Old 10-25-2010, 07:43 PM   #8665
Suspended
all this tuning your doing and never getting any better, you should think about maybe trying differnt diff oil.
Old 10-25-2010, 07:44 PM   #8666
tc5 man's Avatar
i already have 3000 in the rear diff and i would think that 2000 w in the rear on a truggy whould burn up too quick.
Old 10-25-2010, 07:47 PM   #8667
Suspended
what wt. you have in center
Old 10-25-2010, 07:51 PM   #8668
tc5 man's Avatar
10,000 w.
Old 10-25-2010, 07:54 PM   #8669
Suspended
10,000 w.
i went 15000, little more controlable
Old 10-25-2010, 07:58 PM   #8670
losi_racer's Avatar
10 makes it rotate a lot more tho which is what he wants. going up does settle down, i personally ran 20
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
