Old 09-19-2010, 05:43 PM   #8641
Tate72's Avatar
Trader Rating: 52 (98%+)
OK I'll try it again. I've done it a couple of times already now. I don't know what the deal is...
I have changed the bladder and the seals and it still does it. HMM..... Maybe I need to change the piston and try that. I dono..
Team Durango, http://www.team-durango.com/
TrakPower Speed Equipment, http://www.trakpowerusa.com/
DE Racing, http://www.deracing.net/
WWW.JCPRCRACEWAY.COM
Tate72 is offline   Reply With Quote
Old 10-04-2010, 08:56 PM   #8642
tc5 man's Avatar
i have a question about the rear shock postions on the arms what does what on the outside postion or the inside or the middle ? i tried the outside postion and it was terrible so i mounted it on the inside and it was better for sure but what about the middle postion ?
on a rough rutty hard dusty track ?
Old 10-04-2010, 09:31 PM   #8643
tc5 man's Avatar
anybody ?
Old 10-05-2010, 02:16 PM   #8644
tc5 man's Avatar
anybody ?
Old 10-05-2010, 02:19 PM   #8645
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
In the back of the manual the describe what moving the shock does .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-05-2010, 02:20 PM   #8646
tc5 man's Avatar
on the rear arms it does ?
Old 10-05-2010, 03:51 PM   #8647
Briguy's Avatar
Now that I look at it the manual just gives a brief description . The 1/10 manuals have much more info in them .
Royal R/C & Hobby
Old 10-05-2010, 04:53 PM   #8648
tc5 man's Avatar
no kidding i dont know why it doesnt .
i mean, if you mount the shock in the outside hole the first hole on the bottom on the arm thats the softest setting which i tried and it sucked for me to much side to side roll . and the middle hole is stiffer which is a lot better than.. the outside hole one i havnt tried was the inside hole the 3 hole which i do wonder if that works good on a hard packed dry track?
and, also the manuel doesnt explain what the spring rates do and how they work on the eight so you have to guess.
Old 10-05-2010, 09:01 PM   #8649
fukitol's Avatar
get a hudy setup statiion. they also include a very nice setup guide that will make you go crazy with setup info. or find the guide. its very info heavy
is that fast, can i drive it, how much do they cost
fukitol is offline   Reply With Quote
Old 10-25-2010, 06:30 PM   #8650
tc5 man's Avatar
i have a question im using the 2.0 rear hubs and outer hinge pins and i want to use the (a) hole on the hub what # camber link would i have to use #4 or #5 i race on a rough rutty bumpy track.
i tried the (b) hole on the hub with the #4 camber link hole and i had a hard time getting it to rotate.
the guys on the 2.0 truggy tread seem to not know.
Old 10-25-2010, 06:38 PM   #8651
losi_racer's Avatar
Trader Rating: 25 (100%+)
We answered you already, sorry you didnt like our answer
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 10-25-2010, 06:43 PM   #8652
tc5 man's Avatar
just try and find out well i tried to use the (a) hole on the 2.0 rear hubs and the #4 hole on the tower and i tried to rejust the camber because it was pushed out well if i turn the turnbuckle backwards. it just pushes the camber out more and if i keep on turning it to try to get 2- camber it wont go any farther or i will strip my ball cups out.
i mean i could try to use the (a) hole on the hub and use #5 camber link on the tower but it says on my manuel that its not as good on bumps compared to the #4 hole.
now im guessing that the #5 hole on the left on the tower will be a shorter link ? or a longer link ?
Old 10-25-2010, 06:50 PM   #8653
tc5 man's Avatar
i guess nobody else knows ?
Old 10-25-2010, 07:07 PM   #8654
Suspended
Trader Rating: 202 (96%+)
to much a-hole.......b-hole talk for me
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 10-25-2010, 07:10 PM   #8655
losi_racer's Avatar
You are very impatient. As i stated and many agreed try different set ups, just because a set up says use this doesnt mean its right for you. Try different things. You can always cut the links if you want short camber links. if i were you i would try B/1 that would be my starting point and alter your settings from there
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
