Old 04-11-2010, 12:32 PM   #8596
Joe Pasco's Avatar
Originally Posted by Spironi View Post
Can you describe the world of difference? What sort of changes are you seeing, under what sort of driving conditions? I like the company descriptions, but I have never seen the product in use with a good before/after basis of comparison.
Seeing as you are using the center smartdiff, I would be particularly interested to know how it affects braking and acceleration, as well as turn in and cornering in general as you roll on and off the throttle. And anything else you would care to comment on as well!
Thanks in advance,
Spiro
I do some struggle on 1 track in AZ with acceleration. That is The Nitro Pit. The same track for The Dirt 2010 Nitro Challenge. It is nothing that gets in the way of my driving. I have to use less brake and can more just ease off the throttle. This is where I have gotten t he most gain from the center smart diff. It allows me great off power sterring coming into a corner. Sometimes a tad too much. I need to adjust my springs again, as I am only running two of the four spring inside the smartdiff. I drive a 1.0, and threw in the 1.0 anyways. This really helped my driving though. That is an opinion statement, so some folks may say they don't like it. A couple folks I will talk to here and there don't like the smart diff.
Most of the tracks I run this on in AZ are hard packed.
Joe Pasco
Losi 8ight 1.0 - Novarossi - AKA - Sidewinder
Joe Pasco is offline   Reply With Quote
Old 04-11-2010, 02:22 PM   #8597
Spironi's Avatar
Thanks very much for the feedback. It is much appreciated!
Spiro
Loctite everything...
Spironi is offline   Reply With Quote
Old 04-19-2010, 03:52 AM   #8598
Default help
what hex driver size do u guys used for a6204 screws ?
that is the screws that is used to attach the servos to the kit ?
crosten is offline   Reply With Quote
Old 04-19-2010, 01:51 PM   #8599
Joe Pasco's Avatar
Should be 3/32...maybe 5/64, but pretty sure it is 3/32
Joe Pasco
Old 04-19-2010, 01:57 PM   #8600
neobart's Avatar
It's 3/32
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 04-24-2010, 02:31 PM   #8601
tc5 man's Avatar
i just bought a set of eight-t 1.0 arms, for the rear and the front and i was wondering if there, is a left and a right arm. cause it doesnt say it on the front arms or the rear arms, or are they the same.
tc5 man is online now   Reply With Quote
Old 04-24-2010, 03:22 PM   #8602
tc5 man's Avatar
anybody?
Old 04-24-2010, 03:35 PM   #8603
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
Left/Right are the same. It doesn't matter.
K_B is offline   Reply With Quote
Old 07-14-2010, 06:47 PM   #8604
Trader Rating: 27 (100%+)
hey guys, I am sure this has been asked 1000 times, but its one loong thread, and searching comes up with information other than what I need
What's a good starter box to get for my 1.0 buggy? are they compatible with 2.0?
Thanks..
sorry for the newb question, had my buggy for a year but was using a traxxas box, now finally upgrading.
spawn_x is offline   Reply With Quote
Old 07-14-2010, 08:16 PM   #8605
tc5 man's Avatar
i have a question have any of , you guys had problems with the diffs leaking on the eight -t ? i just opened up my gear boxes... and the diff oil was all over the place and, the diff had only about half of the oil left.
the o-rings and the diff gasket , arent old maybe i over filled it a little bit or something ?
Old 07-14-2010, 08:21 PM   #8606
tc5 man's Avatar
anybody know ?
Old 07-14-2010, 09:44 PM   #8607
Joe Pasco's Avatar
Originally Posted by tc5 man View Post
anybody know ?
I have had this on 8-Buggy. Front Diff in front gear box. Tried seals...nada... I just bought a new diff housing and seal. Corrected the problem.
Joe Pasco
Old 07-14-2010, 10:27 PM   #8608
tc5 man's Avatar
ok well i try again than if it, happens again il get new seals etc i only filled it up a little more than when it covers the gears. the rear and the front leaked.
Old 08-26-2010, 08:30 PM   #8609
Tate72's Avatar
Trader Rating: 52 (98%+)
OK I hope someone can help me some. I know not many people run the 1.0's anymore but I have some questions.
Right now I have my kido's buggy's shocks set up like stock settings. Both upper shocks are on the middle holes. What would it do if I changed her rear and or front shock holes on top to outer most or inner most holes? Like how would it respond?
I only ask cause we have been racing when we can but I still don't know what everything does so I figure I would ask for some teaching so I could learn...
Thanks for any help I can get..
Team Durango, http://www.team-durango.com/
TrakPower Speed Equipment, http://www.trakpowerusa.com/
DE Racing, http://www.deracing.net/
WWW.JCPRCRACEWAY.COM
Tate72 is offline   Reply With Quote
Old 08-26-2010, 09:31 PM   #8610
VWVR6_T's Avatar
Send a message via MSN to VWVR6_T
You will have a lot of answers but if you dont try it your self you are never gonna know how really works for you, why? 1.driving style 2.Track conditions 3. set up skills, etc. This is what I did http://www.losi.com/ProdInfo/Files/8...ning_Guide.pdf it helps a lot and is the best tool that you can have in your tool box, you will learn a lot with this guide, also this one http://users.telenet.be/elvo/ and (pick the very first item in the page) http://www.hudy.net/xhudy/products/p...2&kategoria=64 (you can save it to your computer or print it out). If you dont find any answer to your questions here you don't know how to read lol . Good Luck.
BTW. The fact that the Losi 8 1.0 is old not means that can't win races...
TLR 8ight 2.0 - Werks B5/2058 l Airtronics l Hitec l rev-rc.com l Werks Fuels l Sweep
TLR 8ight T 2.0 - Werks B5 Pro/2013 l Airtronics l Hitec l rev-rc.com l Werks Fuels l AKA
Ofna GTP l Hyper 8P Turbo
QUOTE by FLHX1550 "The Werks B5 is kind of a legend"
VWVR6_T is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
