Old 09-25-2009, 10:46 PM   #8566
The blue shields should be facing each other. The bigger bearing, the one closest to the motor should have the blue shield facing the front of the car. The smaller bearing, the one closest to the tank should have the blue shield facing the rear of the car.
slow is offline   Reply With Quote
Old 09-25-2009, 11:01 PM   #8567
tc5 man's Avatar
oh its not the bigger bearing inside the clutchbell its the small one that goes in the front ,i have the black side facing the fuel tank and the blue side facing inside of the bell. does it make a diffrence
Old 09-25-2009, 11:04 PM   #8568
tc5 man's Avatar
i just have the small special bearing in the front of the clutchbell.i just have a reguar cemetric bearing inside of the bell not the special one
Old 09-25-2009, 11:08 PM   #8569
That's right then. I'm not sure on this but I think black shield is heavier duty than the blue shield.
Old 09-25-2009, 11:24 PM   #8570
tc5 man's Avatar
one side has a blue sheid and the other side has a black seal,both sides dont have a blue shied on it just one side
Old 09-25-2009, 11:25 PM   #8571
tc5 man's Avatar
they are still smooth after about 6 runs or so even running in the mud
Old 09-28-2009, 08:48 PM   #8572
Tate72's Avatar
Trader Rating: 52 (98%+)
Does anybody know which would be a better plug for the stock 427 motor? OS 8 or one of the O'Donnell plugs?
Tate72 is offline   Reply With Quote
Old 10-03-2009, 08:55 AM   #8573
Tate72's Avatar
I need some advice, I have got a used 8ight to where the back of the chassis is worn down thin. It's not worn down all the way but I had to cut grooves in the back 2 screws to get them out. I would say it's less than half left. So my question is, until I get a new chassis for it will these work for now?
http://www.amainhobbies.com/product_...si-8-8T-20-20T
Also I will ask here to. I can't seem to find a back plate on A-Main that I can use for the losi 427 motor to convert to a bump box. Does anybody know if the make one or where I can locate one at?
Old 12-27-2009, 12:17 PM   #8574
JEB21's Avatar
Default shock problems
I'm blowing shocks out almost every time I hit the track. Essentially the shaft and the piston separate inside the shock body and the shaft comes out the bottom.
Are my screws holding the piston to the shaft not holding (I used loctite)?
or
is my sag not set correctly and the shock has too much potential for over extension?
Any tips or others have this problem? Thanks!
8ight - GoTech .21 5 port
Kyosho RB5 - Novak 10.5
Vendetta ST - Ammo 3900
JEB21 is offline   Reply With Quote
Old 12-27-2009, 12:21 PM   #8575
Integra's Avatar
or
are you cleaning the shaft's with alcohol or some type of chemical ? the threads need to be Brand new clean for the loctite to hold....and if this is a re-occurring problem i would let the shocks sit overnight(24hrs) for the loctite to cure.
setting the droop is important but wont lead to the piston problem you are having.
Old 12-28-2009, 11:22 AM   #8576
JEB21's Avatar
It has been a recurring problem. When I originally built the shocks I did let them sit overnight before I finished them up.
Old 12-28-2009, 01:52 PM   #8577
Integra's Avatar
hrmm...what kind of loctite....did you clean them outta the package prior to assembly ?
Old 12-28-2009, 02:13 PM   #8578
JEB21's Avatar
blue loctite.
cleaned/sprayed them down with a bit of electric engine cleaner.
I'm going to rebuild tonite and soak in alcohol before assembling.
Old 12-28-2009, 03:20 PM   #8579
tc5 man's Avatar
blue loctite.
i had the same problem, with my shock piston coming loose ,clean the treads. off real good and put a dab of red locktite, on the screw and let it sit for overnight trust me, it wont get loose . u can still loosen the screw though if you need to change pistons.
Old 12-28-2009, 03:21 PM   #8580
I know this is in here some where but can you use regular electric motors in my losi bump box?How do you change that pinion for the belt?thanks Lee
Team AGAMA and VP Pro
nascarracer is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
