Losi 8ight building and setup >
Old 07-25-2009, 01:28 PM
  #8521
smittyusmc's Avatar
Originally Posted by Integra
you also dont have a set screw insert to lock the pin in place if i understand you correctly.
that is true but I think it will hold if I put a dust boot over the pin.
smittyusmc is offline
Old 07-25-2009, 03:39 PM
  #8522
Integra's Avatar
I thought that too at one point......then i was 5 min away from winning a local race to only have my rear end loose all power due to the pin being ejected through the GMK condom NOT the thinner losi version...i now ensure the screw and pin are loctited in place and aren't goin anywhere....only if the pin were carptured like the Xray or similar to how the wheel bearing's capture the pins would that work with no worries.
Integra is offline
Old 07-25-2009, 03:43 PM
  #8523
smittyusmc's Avatar
that would have suck I guess I will just not even take the chance ill just want for my rear driveshaft thanks for the in put.
Old 07-27-2009, 10:44 PM
  #8524
air8's Avatar
The front and rear cross pins have a flat spot machined on them for the set screw. The four axle CV crosspins don't have the flat spot. If you use the wrong ones in the center F/R driveshaft the pin will work it's way out--eventually. Learned that the hard way a couple years ago.
air8 is offline
Old 07-28-2009, 08:23 AM
  #8525
Default SERVO QUESTION
I have been flying planes for years but am getting into RC cars now and just ordered an 8ight. What servos are people using in this buggy? Thanks everyone!!
jo8ight is offline
Old 07-28-2009, 08:28 AM
  #8526
Integra's Avatar
Hitec 7955's is your best bet.
Integra is offline
Old 07-28-2009, 09:30 AM
  #8527
Thanks!! I appreciate it.
jo8ight is offline
Old 08-02-2009, 03:46 PM
  #8528
Trader Rating: 14 (100%+)
on the truggy I have changed the front pinion and the diff case. put it back together and it feels crunchy. is this normal until i run it and they set or is the spacing wrong. I have no shims behind the pinion and two shims on the ring side of the diff. Any help would be great.
srt4s is offline
Old 08-02-2009, 04:11 PM
  #8529
Integra's Avatar
did you replace the Ring gear as well ? those are a match set....like a Piston and sleeve....you can shim the notchy feeling out...but be aware that once the gear's mate you will need to re-shim.
Integra is offline
Old 08-02-2009, 04:31 PM
  #8530
i took one shim out and the diff feels smooth. about how many tanks before i should check and reshim. thanks alot intrega.
srt4s is offline
Old 08-02-2009, 06:04 PM
  #8531
Integra's Avatar
you need a very small tick of play between the R+P....i would check the gear in 5-10 tanks and try to add the shim...see what happens.....also make sure you take out the thin shim not the thick for fine tuning.
Integra is offline
Old 08-06-2009, 10:41 PM
  #8532
Guest
Default Shims
What is the part number of the shims for the ring and pinnion gear?? Or r they in the manual??
LOSIRACER77 is offline
Old 08-07-2009, 12:04 AM
  #8533
pyromania's Avatar
Trader Rating: 18 (100%+)
I know Fioroni makes some aluminum condoms that cover the whole grub screw and pin. I can't seem to find it on their website but I'll get a pic tomorrow for you guys.
pyromania is offline
Old 08-07-2009, 07:22 AM
  #8534
Integra's Avatar
I just make sure they are in good condition and replace if they are nicked in any way....Im not a fan of Fioroni for much of anything.
Integra is offline
Old 08-07-2009, 11:07 AM
  #8535
pyromania's Avatar
I know, I still use the losi condom on my buggy. I wouldn't use anything other than losi or KingHeadz pieces on my buggy. I just thought you guys would find the part interesting.
