Old 07-02-2009, 01:25 PM   #8506
unsp0ken's Avatar
Trader Rating: 24 (100%+)
Originally Posted by BOOST View Post
All I ever do to get mine out is turn it upside down and let gravity do the work. It works every time...no need for prying or clamping or any of the things you guys try.
+1... That's all I have to do also.
unsp0ken is offline   Reply With Quote
Old 07-02-2009, 03:42 PM   #8507
Originally Posted by Chris__RC View Post
Like Integra said, it was just oil built up. I got my 8ight used so I don't think the oil was changed once making it difficult to pry off. But the next time I went to take the sun gear off it came off easily.
And something that has been bugging me for a while, I noticed on Losi setup sheets on the rear hub spacing part, losi says to put 2 spacers in. I have the M2C hinge pins and I use to 2 spacers that came with it, then I modifed a beveled washer (the washers for the diff in XXX models) so there wouldn't be any slop. Should I remove the extra beveled washer or not? I have heard people not getting as much traction, but I can't find the post anymore.
I've been running mine with the M2C spacers and really haven't noticed any difference in forward bite. I believe the spacers for the 2.0 should fit since Losi increased the hinge pin diameter, just can't remember to buy any.
Don't know abobut the sun gear thing. I clean/refill after no more than 1.5 gallons so the most I've ever had to do is grab it with needle nose and pull out. Knock on wood LOL.
cjtamu is offline   Reply With Quote
Old 07-20-2009, 09:00 PM   #8508
tc5 man's Avatar
what are the best bearings that have the best seal that are non ceramic cause im getting tried of takeing the seal off and putting them in wd40 to get all the dirt out my track is dusty also
Old 07-21-2009, 08:10 AM   #8509
Integra's Avatar
I dont mess with the seal's...when they are that dirty i toss them and go new...for 1$ its not worth the extra hassle to do the maintenance on cheap drive train bearings....what bearing's are bothering you the most ?
Old 07-21-2009, 12:31 PM   #8510
tc5 man's Avatar
just the rear and front hub bearings and the rear and front diff bearings ,but mostly the hubs
Old 07-21-2009, 12:31 PM   #8511
tc5 man's Avatar
there the stock losi seal bearings
Old 07-21-2009, 01:06 PM   #8512
Jube's Avatar
Trader Rating: 43 (100%+)
Avid Revolutions FTW!
Jubal Dike
X-Factory www.xfactoryrc.com | Tekin www.teamtekin.com | Panther Tires www.panthertires.com | DE Racing www.deracing.net | Avid www.avidrc.com | Coyote Hobbies www.coyotehobbies.com | 411 Graphics
Jube is offline   Reply With Quote
Old 07-22-2009, 06:44 AM   #8513
sport10's Avatar
Use Boca Green Seals. They are the longest lasting hands down.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 07-22-2009, 07:14 AM   #8514
Integra's Avatar
$ for $ when comparing they are not worth it imo.
Old 07-22-2009, 07:34 AM   #8515
sport10's Avatar
Unless you figure in the time you will not be spending on maintence replacing cheap bearings. Which is worth alot IMO. The poster did ask what the best lasting bearing were not the least expensive.
Associated B44
Associated B6
Old 07-22-2009, 01:43 PM   #8516
Integra's Avatar
Maintenance needs to be done either way.
Old 07-24-2009, 08:32 AM   #8517
+1. And I do figure my time is valuable. By the time I figure in solvent costs and lube costs plus my time cleaning bearings, I'm way over the $1 it would have cost me to replace with new. I still run the Losi clutch bearings, have had great luck with those. Avid everywhere else.
Old 07-24-2009, 11:04 AM   #8518
tc5 man's Avatar
yea i have the losi stock clutch bearings im shocked that i havnt had to replace the big bearing yet and im on my secound gallon,now i did have have to replace the smallere bearing in the frount,my clutch bell seems fine still.
im gone to look at them green seal bearings from boca they should seal better
Old 07-25-2009, 11:52 AM   #8519
smittyusmc's Avatar
I have the old 8ight buggy and I just got the 2.0 chassis I do not have the rear driveshift yet but it is on its way.
So I use a extra drive shaft from an aarm, I used the small pin because the big pin would not work every thing went together nicely and it is the prefect size I was just wondering if any body has tryed it and if the small pin will stand up to the abuse. thanks.
Hot Bodies Hara D8 - ODss .21
Team Associated B4.1 reedy 8.5, R10 Pro
Team Associated T4.1 OHP 17.5, Tekin RS
Team Associated B44.1 reedy 6.5, R10 Pro
smittyusmc is offline   Reply With Quote
Old 07-25-2009, 12:17 PM   #8520
Integra's Avatar
you also dont have a set screw insert to lock the pin in place if i understand you correctly.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
