Old 06-23-2009, 07:31 PM   #8476
sluggo_sx8's Avatar
Well I did a 3 day race weekend with the new clutch and all is good. There must have been something wrong with the other bell or something. I am really liking the clutch now.
sluggo_sx8 is offline   Reply With Quote
Old 06-24-2009, 06:42 AM   #8477
Integra's Avatar
good to hear buddy...the losi clutch is a stout clutch for sure.
Old 06-24-2009, 07:25 AM   #8478
Originally Posted by Chris__RC View Post
Took it apart, found my issue. The sun gear that goes onto the bevel's from the top was out of place 1mm. Just enough to put yuor finger over the outdrive and feel the sun gear is 1mm higher. I think it was an o ring issue with them not fitting into place. How often do you guys replace diff oil? I do it about every gallon or so......too much, too little?
Every 1 to 1 1/2 gallons is about what I do. Also a good time to check your sun and planetary gears for wear and replace if needed.
cjtamu is offline   Reply With Quote
Old 06-24-2009, 11:13 AM   #8479
And you would replace the gears when there is noticeable slop?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-30-2009, 06:51 AM   #8480
bloodrush's Avatar
Hi guys has anyone done the losi 2.0 servo tray into losi 1 .I need some help on a couple of things :- 1/ i have noticed that my ace servo sits in so low it hits the chassie or almost hits it but that is without the spacer blocks ,2/that the sevo horn hits the bodyshell also without spacer blocks . i am using the original losi 8ight shell so not sure if the 2.0 maybe sits abit higher . /3 if i use the dx3s rpm sensor in the same place as the 8ight 2.0 rtr it is very close to the diff .Any help or advice would be a big help cheers
losi 8 b ,o.s 21 speed, jp3 ,ace servos, dx3,byron 25%
bloodrush is offline   Reply With Quote
Old 06-30-2009, 07:30 AM   #8481
Replace the gears when the teeth start to look thin and sharp.
Old 06-30-2009, 05:58 PM   #8482
tc5 man's Avatar
how do u get the big bevel gear out of the diff case when u change the diff oil i tried to put 2 flat heads and push it up and that dint work dont know why they just dint have a hole there with a set screw to easy slide the pin out
Old 06-30-2009, 06:36 PM   #8483
Frank L's Avatar
Trader Rating: 148 (100%+)
I use needle nose pliers and I grab it on each side and it comes right out.
Old 06-30-2009, 06:49 PM   #8484
Jube's Avatar
Trader Rating: 43 (100%+)
+1
Jubal Dike
X-Factory www.xfactoryrc.com | Tekin www.teamtekin.com | Panther Tires www.panthertires.com | DE Racing www.deracing.net | Avid www.avidrc.com | Coyote Hobbies www.coyotehobbies.com | 411 Graphics
Jube is offline   Reply With Quote
Old 06-30-2009, 07:11 PM   #8485
tc5 man's Avatar
yea i tried that but i guess u have to grip harder, i did notice though i have play in my front gear in the gearbox is that fine the buggy is pretty new
and the rear doest have any play. is that fine
Old 06-30-2009, 07:15 PM   #8486
PIMP_9000's Avatar
Default is this clutch shoe done?
here is a pic of one of my losi shoes is it worn out? I do chamfer the edges when I maintain this is about 6 races old. I want to know how far you go with a losi shoe I am new to them.Thanks in advance
PIMP_9000 Darrin Hunt see my paint work in painting forum keyword pimp_9000
BCG Industries/Hunt Motorsports/Outlaw Garage
Losi 8ight & 8t/Kyosho ultima sc/RB engines/castle electrical items
Fearfarm rc/KBRL/The Dirt/
PIMP_9000 is offline   Reply With Quote
Old 06-30-2009, 08:25 PM   #8487
Integra's Avatar
measure the shoe's like this after you clean up the edges and if it's below 23.4mm the shoe's are done.
Old 07-01-2009, 05:15 AM   #8488
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I use a magnet to get the bevel gears out .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 07-01-2009, 06:36 AM   #8489
TTR:EB4's Avatar
if anyone is thinking about trying different shoes, i recommend M2C ultra light (hard compound) clutch shoes.
great shoes, i love em in the 8ight.
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 07-01-2009, 07:04 AM   #8490
Bevel gear should slide out very easily. If it doesn't you have a problem.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
