Old 05-20-2009, 07:28 AM   #8416
Akhor's Avatar
Originally Posted by underthethumbma View Post
Hello from the uk... I need some help i have put my losi 8 on my hudy setup station put my 30mm droop blocks under the chassie and set the car up with 3 degrees of negitive camber on the rear and 1 degree of negitive camber on the front when i take it off the setup station and put the wheels on it just dose not look right i then put my camber on the wheel and only have 1 degree rear and about 0.5 on the front i have no slop as i changed all tie rods and new lower arms can anyone tell me where i have or am going wrong
Make sure your setup blocks are not the front kickup, rather under the center of the chassis. Make sure the wheels are off. Push down on the chassis to make sure it's settled on the blocks. Then read the setup station settings.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 05-22-2009, 06:47 PM   #8417
tc5 man's Avatar
im having a problem with my eight when i turn the rear wheels i turns the front axle thats normal but the front doesnt wheels dont turn and when i move the front wheels i kind just freewheels both front tires and doest go to the rear is a diff gear get mislinged or something is weird to me but if i hold the spur gear both tires on the front and the rear do move.
Old 05-22-2009, 09:05 PM   #8418
Guest
Send a message via Yahoo to T4-RC8 RACER77
Default Tc5man
Mine did the same but the rear breaks was dragging, could u lost the set screw in the rear shaft, just ideas, I am kinda new to 1/8 racing.
T4-RC8 RACER77 is offline   Reply With Quote
Old 05-22-2009, 09:09 PM   #8419
Guest
Default Tc5man
Have u cheched ur diff oil lately? It could be getting low,?
Old 05-22-2009, 10:26 PM   #8420
tc5 man's Avatar
well some of the diff oil leaked its was inside of the bulkhead so maybe its cause a slip the oil is covering the diff gears i could have a bit more. yea i check the setscrew it doesnt feel like the rear brakes are dragging but iwount think that would do that through. was yours doing that when u had your engine running and run it on the ground .
Old 05-23-2009, 08:36 AM   #8421
Integra's Avatar
if the rear tire's are free wheeling there is a couple things that it could be.....either its the set screw on the pinion shaft that has backed out allowing the pinion to spin free.......the pinion itself might be blown....if the rear diff itself if free wheeling like when you spin 1 tire and they both continue to spin after you stop then you diff is 100% Dry as a bone and you need lube bad.
Old 05-26-2009, 04:39 PM   #8422
Guest
Default Hinge pin mounts
Hey guys are the losi hinge pin mounts(losa1754 & 1755) worth buying???????
Old 05-26-2009, 05:59 PM   #8423
Integra's Avatar
yupper's...worth every penny.
Old 05-27-2009, 01:19 AM   #8424
Trader Rating: 27 (100%+)
Hey guys, I am sure this was asked before but I searched and read through at least 30 pages of threads and did not find my answer
What parts (besides chassis) swap over from the 2.0 to 1.0 buggy?
I know if you get the chassis you can fit most of the stuff but I don't want to upgrade my chassis.
I'm pretty much interested in just the fuel tank and the radio tray, could I use 2.0 on the 1.0 chassis? what about motor mounts?
Sorry for the question, much appreciated. Thanks
spawn_x is offline   Reply With Quote
Old 05-27-2009, 06:55 AM   #8425
Integra's Avatar
the item's you want will bolt right up no problem's....for the radio tray you might need to get the 2.0 chassis guards or bust out the dremel and modify your 1.0's.
Old 05-28-2009, 01:51 PM   #8426
Guest
Default Hey Integra
I have a 1.0 buggy and I have the hinge pin mounts comming what else would u put on the old buggy, or what 2.0 parts would use on the old car?
Old 05-29-2009, 06:48 AM   #8427
Integra's Avatar
the list is endless...it all depends on how much you want to spend.
Old 05-29-2009, 08:30 AM   #8428
You mean the bigger rear outer hinge pins? That's a good upgrade. Also, Losi adjustable or M2C front and rear toe plates. Heat shrink condoms or similar for F&R CVD's. Ackerman plates from the 2.0 (think they will bolt right up). 2.0 radio tray if you're having trouble setting up your linkage.
cjtamu is offline   Reply With Quote
Old 05-29-2009, 09:50 AM   #8429
unsp0ken's Avatar
Trader Rating: 24 (100%+)
is the receiver box on the 2.0 radio tray any bigger than the 1.0?
unsp0ken is offline   Reply With Quote
Old 05-29-2009, 12:13 PM   #8430
Integra's Avatar
no.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
