Old 05-12-2009, 08:33 PM   #8401
unsp0ken's Avatar
Trader Rating: 24 (100%+)
Originally Posted by smittyusmc View Post
im not sure if this question has been asked but I could not find anything on it but what are the different effects of useing the long ackerman vs the short ackerman.
got this from the losi tuning guide...
The Long Ackerman plate will have smoother steering and is generally more forgiving.
The Short Ackerman plate produces a quicker reaction and steering response and has more steering in the middle of the turn. The short Ackerman plate would be better suited for tight technical tracks.
unsp0ken is offline   Reply With Quote
Old 05-14-2009, 07:43 PM   #8402
Guest
Send a message via Yahoo to T4-RC8 RACER77
Default Set up ??
Guys how do I build the shocks on the eight buggy with, or without rebound??and how much rebound??
T4-RC8 RACER77 is offline   Reply With Quote
Old 05-14-2009, 08:07 PM   #8403
Try to go for at least 1/2or 100%. I go anywhere from 75% to 100% depending on how much time I have. And if you get the Losi shock matching tool (great tool) be ready to see how far off your shocks are.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 05-14-2009, 09:34 PM   #8404
tc5 man's Avatar
i have my about a little over half rebond to be honest though i cant tell the diffrence maybe thats because im not a really good driver i uess lol.has anybody tried advange 1/8 buggy tires i got them for $8.99 ! and they look like they are good rubber and they have molded inserts.they where on clearence at carolinasrc.com
Old 05-14-2009, 09:50 PM   #8405
Guest
Default Diff oil
Has anyone tried 3000wt in the front,5000wt in the center, 2000wt in the rear, and did u like it, and what type of track would u use it on? I tried it on a dry,hard, dusty track, I was using crime fighters m3, tires I didn't like it at all it push every where,
Old 05-15-2009, 06:23 AM   #8406
Try 5/7/2. That works on just about any track surface.
cjtamu is offline   Reply With Quote
Old 05-15-2009, 12:17 PM   #8407
Default Setting throttle linkages on 1.0
I just saw on the Losi website there is a slightly different method of setting up the servo arm on the throttle servo. For 1.0 the arm was parallel to the servo but for 2.0 the arm is slightly angled toward the carb.
My question is for a 1.0 buggy do I use the new method for the 2.0 or stick to the old way. I haven't had any servo issues with the old way so I'm wondering if the new way is for the redesigned 2.0 radio tray.
slow is offline   Reply With Quote
Old 05-15-2009, 12:27 PM   #8408
pyromania's Avatar
Trader Rating: 18 (100%+)
Thats the way to set up the servo so that the arm doesn't run on the body. Just make sure that you have 1-2mm of play and you should be good to go.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 05-16-2009, 12:59 PM   #8409
tc5 man's Avatar
u know how losi eight manuel gives u a piece of paper that says use a washer behind the flywheel if the shaft isnt flush with the bearing , well i dint use the washer and the clutch bell is lined up with the middle part of the bearing not competly to the front of the bearing is that ok or does it need to be flush with the front of the bearing.
Old 05-16-2009, 12:59 PM   #8410
tc5 man's Avatar
and i run a novarossi .21 bf
Old 05-17-2009, 07:31 PM   #8411
unsp0ken's Avatar
EDIT: NM found the answer to my question
Old 05-20-2009, 03:59 AM   #8412
underthethumbma's Avatar
Default hi
Hello from the uk... I need some help i have put my losi 8 on my hudy setup station put my 30mm droop blocks under the chassie and set the car up with 3 degrees of negitive camber on the rear and 1 degree of negitive camber on the front when i take it off the setup station and put the wheels on it just dose not look right i then put my camber on the wheel and only have 1 degree rear and about 0.5 on the front i have no slop as i changed all tie rods and new lower arms can anyone tell me where i have or am going wrong
Losi 8 2.0 - Novarossi 21-4 - 9901 Super Strong - Sanwa - Futaba 3pk
underthethumbma is offline   Reply With Quote
Old 05-20-2009, 05:52 AM   #8413
TTR:EB4's Avatar
hi guys, my losi is going on the hudys this weekend, and i want to know whats the ideal setup...
i have:
5 - 7 - 2 in the diffs
35wt front - 25wt rear - oil in the shocks
green springs rear - silver springs front
cheers guys
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 05-20-2009, 06:16 AM   #8414
Akhor's Avatar
http://www.google.ca/url?sa=t&source...2WIxE7BmI_lxcQ
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 05-20-2009, 06:56 AM   #8415
Best guess is that you aren't measuring at proper ride height at some point, either when using the Hudy or when measuring after the wheels are on. Be sure you compress the suspension and let the car settle back to normal ride height before measuring.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
