Old 11-22-2006, 04:26 AM   #826
Matt Howard's Avatar
Originally Posted by patrick lsp
can someone clue me in? on setup sheets most are 95mm front and 106mm rear. what points are they measuring from? with the shock off the front fully extended it measures about 75mm. and the rear is nowhere near 106 fully extended. any help would be appreciated
uhh, I just finished the build on my car so the droop screws haven't been turned down any and my front shocks measure around 106mm and my rears are around 121mm. Measure them from the top of the shock cap to the bottom of the shock end.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-22-2006, 04:35 AM   #827
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
Patrick-The correct way to measure them if from center of the screw on the top of the shock, to center of the screw on the bottom of the shock.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 11-22-2006, 06:21 AM   #828
layedbackguy's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to layedbackguy
[QUOTE=I THINK YOU GUYS ARE NOT SETTING YOUR LINKAGES UP CORRECTLY.
Once i set mine up correct, i havent had any problems, i have it set with little throw, but the carb still opens full, and brake throw is the same way, and stops the car quick with little strain on the servo..I may just be lucky tho!
layedbackguy is offline   Reply With Quote
Old 11-22-2006, 02:05 PM   #829
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Does any one know the web site for tko? I tried the link a few pages back but it did'nt work.....,Thanks in advance.
SCUBA STEVE is offline   Reply With Quote
Old 11-22-2006, 02:09 PM   #830
SupermaxxRich's Avatar
TKO Website was hacked is down for now
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is online now   Reply With Quote
Old 11-22-2006, 04:09 PM   #831
patrick lsp's Avatar
Trader Rating: 170 (100%+)
thanks for info. i had a setting wrong on mic. now it makes sense
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
patrick lsp is offline   Reply With Quote
Old 11-22-2006, 04:33 PM   #832
dirtracer1's Avatar
by the cub scouts no less.
i know alot of people seem to recommend the tko ceramic metal shielded bearings, but has anybody used avid bearings in their clutches? they have rubber shielded (rubber on one side w/metal shield on the other) clutch bearings for a buck each. anybody know how they hold up as opposed to the tko ceramic bearings?
while the avid's are $1.00 each, the tko's are $5.00 each.....big price difference. is there a $4.00 per bearing performance/life span gain with the tko's?
here's a link to the avid bearings........
http://www.avidrc.com/?action=item&id=96
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 11-22-2006, 05:15 PM   #833
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i had a set of avid clutch bearings in my xray for 2 gallons before i had to change them, and they were still good, just figured after 2 gallons i would change them. i am running them in my 8ight right now and they have about 1/2 a gallon on them and are still going strong.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 11-22-2006, 05:15 PM   #834
ringo's Avatar
Default fuel tanks
hey guys,
i was wondering if anybody has had any issues with the fuel tank that comes with the kit? this is the first tank i've come across with the floating pickup, and i'm not totally convinced. are there any conventional type aftermarket tanks available, or can anyone convince us of the benefits of the floating pickup?
cheers, jarrod.
Jarrod Currie
ringo is offline   Reply With Quote
Old 11-22-2006, 05:32 PM   #835
Thanks for the info on tko guys
Ringo, The floating pick up works great and is made to drop to the top of the tank during a roll over so you can sit upside down for a while until the marshall gets to you...... I think it works well and I have no complaints...hope this helps
Old 11-22-2006, 06:21 PM   #836
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I like the tank design . No more running out of fuel if a marshall doesn1t get to you fast enough . I actually had a servo go bad in my 8ight during practice and didn`t have time to change it . Ended up racing my Hyper 8 instead and the bug ended on two wheels during a heat and I ran out before the marshal got to me . If that was the 8ight I wouldn`t of had that problem . So ya it works good and a great idea .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-22-2006, 06:52 PM   #837
R40Victim's Avatar
In addition to my 8ight, I've had countless airplanes with the same style fuel pick up. They work very well, and when I run my 8ight completely out, there's hardly a drop left in it...the stock tank is very effective.
R40Victim is offline   Reply With Quote
Old 11-22-2006, 07:40 PM   #838
loydski29's Avatar
Default 8ight rear diff
I am having a problem with the rear diff on my 8ight I put it together and the pinion does not spin smoothly and i dont know why?It is like the gear mesh is not right but there is not really any way to adjust it.Has any one else had this problem any help would be appreciated. thanks mike
loydski29 is offline   Reply With Quote
Old 11-22-2006, 07:52 PM   #839
Briguy's Avatar
I had the same thing with the front . Just needs to be broke in like Losi states the diffs need to be broke in .
Royal R/C & Hobby
Old 11-22-2006, 08:10 PM   #840
Greg Etter's Avatar
Hey guys,
For those of you that are using the Mugen BII starter box did you guys do any dremel work to the chassis or just line it up and go? I really don't want to dremel on the chassis if I don't have to. At first glance it doesn't look like the starter wheel will get far enough up in the chassis to contact the flywheel. Any help would be appreciated.
thanks......Greg
Greg Etter is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
