Old 04-19-2009, 07:07 AM   #8341
C.Capelo's Avatar
Trader Rating: 113 (100%+)
I have the same setup on my 1.0. I would subtract the thickness of the DE skid plate from the ride height you'd like to run.
C.Capelo is offline   Reply With Quote
Old 04-19-2009, 02:12 PM   #8342
Integra's Avatar
Skid plate thickness changes from run to run....i would measure off the little tab's beside the skid to get a true chassis measurement.
Old 04-19-2009, 07:07 PM   #8343
lowcountrytj's Avatar
Got a question..probably been covered but, are the 2.0 diff cases the same as the 1.0??I know someone that has them (for a good deal is why.)I think they are the same.Just trying to find out before I buy em...Thanks
LOSI 8B--8T///SC10--Im not on a budget,I have a fudget
Team Terribles
Phil Hurd Raceway S.C.O.R.E. Savannah Ga(2nd Oldest RC track in the US)
lowcountrytj is offline   Reply With Quote
Old 04-19-2009, 07:33 PM   #8344
Integra's Avatar
they are different in the fact that the 2.0's have some allowable slop for shimming the R+P back and forth to get proper backlash.
Old 04-20-2009, 07:53 AM   #8345
Thanks Integra,so nothing has changed on the diff case...will it bolt up and work on the 1.0.
Team Terribles
Old 04-20-2009, 07:54 AM   #8346
Integra's Avatar
yup.
Old 04-20-2009, 09:55 AM   #8347
Thanks Integra
Team Terribles
Old 04-20-2009, 07:53 PM   #8348
Hey could I use this clutch bell on the stock losi 4 shoe clutch set-up without modification and what would the advanteages over the losi bell be?
http://www.amainhobbies.com/product_...oducts_id/3651
rgrassey@me.com is offline   Reply With Quote
Old 04-20-2009, 08:03 PM   #8349
Should fit, bascially the only difference is the 2 5X10 bearings isntead of the 5X10 and 5X14. I would get the RR 13t clutch bell. They have the best bearing fit and spin true and come with the best metal quality so they last the longest. (thanks jamminkrazy for the info!)
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 04-20-2009, 08:14 PM   #8350
Integra's Avatar
Wont Fit...the losi bell is Extra deep to cover up the shoe's....the Ofna bell's are too Short and Will NOT work with the losi clutch.
Old 04-20-2009, 08:17 PM   #8351
Integra's Avatar
I honestly have found them to warp more then the Stock bell's and Spur's do.....buddy had his mesh walk on him and it MANGLED the spur and bell...the teeth were Blatantly worn to a point of it being junk...the flywheel/bell combo were no older then 3 races....i Used to run the bell's and they sorta did the same thing...the teeth wore at a real uneven rate and caused the gear mesh to slowly get looser and looser then to have the Teeth Snap off from the teeth Lashing back and forth between eachother....since i went back to the Stock bell/Spur i have not had any weird tooth wear issues....i also have yet to run the HD bell's.
and FWIW i Have Never had a issue with rear bearing's failing due to the slight loose fit in the bell.
Old 04-22-2009, 05:07 PM   #8352
Default sloppy hubs and wheels
I noticed my hubs/hexs seem to have some slop in them where they atattch to the axle hub. Should they be fairly snug or is some slop o.k. Seems the fronts and rears are about the same. Thanks
bdunit is offline   Reply With Quote
Old 04-22-2009, 07:59 PM   #8353
Integra's Avatar
you need a tick of play or the bearing's will eat themselves alive .1 or .2 is acceptable.....Kyosho makes a nice 8mm shim kit with .1 .2 and .3mm shims.
Old 04-23-2009, 09:33 AM   #8354
unsp0ken's Avatar
Trader Rating: 24 (100%+)
my 8ight 1.0 has a grind at the rear diff that seems to be caused by how the ring and pinion hooks up together. the planetary gears in the diff has no grind and the rest of the drivetrain has no grind. it's only when the rear ring and pinion gear hooks up that the grind comes into play. the buggy has about 2 gallons of runtime through it. is this something that will just wear in or is there a solution for it?
unsp0ken is offline   Reply With Quote
Old 04-23-2009, 09:37 AM   #8355
warpig's Avatar
Get the alloy inserts...
warpig is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
