Old 04-03-2009, 04:22 PM   #8281
BOOST's Avatar
Originally Posted by dishsoap View Post
This is gettting confusing. I think I should just use grease in the back diff no silicone oil. This should tame it down big time.
Have you ever considered that you are just too keen on the throttle and over driving it.....is this your first 1/8th buggy?? Also what tires are you using?? Throttle control and correct tires are two very important things 8ight owners need!!
BOOST is offline   Reply With Quote
Old 04-03-2009, 04:34 PM   #8282
Integra's Avatar
so the adjustables are good then?
Should I also replace the rear sway bars? Bigger or thinner?
run 3/3 in the rear...it Will tame it down..when you get them the rear sheet will be Wrong....this is the updated correct version....leave the stock bar's on and try and toe/anti adjustment's.
Rear Toe-In adjustment
Position...Insert #...total toe-IN...REAL total
Inside........1.............1............1.65
Inside........0.5..........1.5.........2.15
Middle........0.............2............2.70
Outside......0.5..........2.5..........3.25
Outside......1.............3.............3.80
Rear Anti adjustment
Position...Insert #...total Anti...REAL total
UP..........1...............3............3.15
UP.........0.5.............2.5..........2.60
Middle......0.............2.............2.05
Down.......0.5.........1.5...........1.05
Down.......1.............1.............0.95
Good point BOOST
Old 04-03-2009, 05:14 PM   #8283
dishsoap's Avatar
Boost
AKA Tires City Block Medium. Yes its my first 1/8 scale buggy so you are probably right about over driving. I did have someone drive it that was experienced and it was loose in his hands too. Guess I just need more practice.
I jus see other peoples buggy planting into the ground off of jumps and going around corners with great control.
Integra
Thanks for the setup notes I really appreciate it.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 04-03-2009, 05:18 PM   #8284
I put this on its own thread. Maybe I will get some more traction here.
I kinda need some adivse on what to change next on my Losi 8 B for performance. My problem is the back end. I cannot seem to get it tight and feels really loose in the back.
I am having a problem on the turns and getting it squared up to hit the straight. It seems that when going into turns the back end spins out and when coming of of turns its loose as well. I just feel like I have no grip and the buggy dose not want to plant itself to the ground as it keeps bouncing all around the place.
I cant hit the straight full power due to this.
Here is my current set up what should I try next to tame it down for more grip?
1) Shocks were just serviced with recommend weight
2) Sliver springs in the front and green in the back
3) AKA City Blocks Medium
4) Diffs front 5 middle 5 rear 2
Here's a good place to start with setup for the 1.0. Most of this setup is very similar to what a lot of the pros listed as their setups and is now very similar to the stock 2.0 setup.
8ight Race Roller - Stable and Easy to Drive
GO-RIDE.com is offline   Reply With Quote
Old 04-03-2009, 08:27 PM   #8285
J4c03's Avatar
Send a message via MSN to J4c03
so i just ordered my 8ight t 2.0 race rolelr and im having troubles deciding what motor i want to put in it i was leaning toward teh grp .28 tuned truggy motor but with all the options available i wanted some experianced input on what motor to get.
J4c03 is offline   Reply With Quote
Old 04-03-2009, 08:30 PM   #8286
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
GRP`s are good engines . I like Orion engines myself .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 04-04-2009, 06:35 AM   #8287
Integra's Avatar
.28 is NOt needed.....a .21 will have more then enough power to puch a truggy......28's are Overkill and only beat up on the drive train.
Old 04-04-2009, 08:24 AM   #8288
SupermaxxRich's Avatar
Boost
Integra
try getting rid of the AKA's and running a different name brand tire. I've found on some tracks the AKA's are too stiff for a 8ight causing poor traction and a bouncy/edgy car
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 04-04-2009, 08:58 AM   #8289
warpig's Avatar
That's a first...
warpig is offline   Reply With Quote
Old 04-04-2009, 11:17 PM   #8290
dishsoap's Avatar
What tires do you recommend? Name brand and modle?
Old 04-04-2009, 11:36 PM   #8291
anything with a soft foam. JC tires work really well or PL BT's or CF's.
Old 04-04-2009, 11:38 PM   #8292
Originally Posted by warpig View Post
That's a first...
not really. ask anyone running a Losi at the the Nitro Challenge. AKA's were not the tire to run on a 8ight. Like I said, I like AKA's, but there not the be all end all tire on all surfaces.
Old 04-05-2009, 01:04 AM   #8293
dishsoap's Avatar
What compound?
Old 04-05-2009, 07:28 AM   #8294
Guest
Send a message via Yahoo to T4-RC8 RACER77
Default Hey team drives
Hey guys what is a good setup for the new buggy. Is there any hop ups that I need to buy for ?
T4-RC8 RACER77 is offline   Reply With Quote
Old 04-05-2009, 03:52 PM   #8295
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Hey guys i am considering getting back into 8th scale.The original 8 buggys are goin for a steel in most areas. my question is will 8ight 2.0 parts such as arms hubs and drivetrain parts fit on the old losi buggy 8ight
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
