Losi 8ight building and setup
#8208
guys on step f-08 page 25 it doesnt show o rings underneth the battery box .and the addendum paper tells u to use the o-rings and tightin to flush with the screw, do u really have to do these is it to protect the reviever battery or something cause the padding inside the box i think would protect it right
#8209
NO O-Rings under the tray.
#8210
so u dont have to use the o-rings under the battery box if so why do they give u a extra paper saying that u have to
#8211
that is from the 1.0 amendment...and imo its rubbish....i never ran them on mine and it was fine....they are a pain to use...screw em....bolt er down and have no fear.
#8212
good they are a pain ,i did have a ofna hyper 7 i ran a couple of times that thing is a tank,i did 2wd nitro truck for the whole year, i heard some people say that the eight drives like a staduim truck that sounds weird to me cause its four wheel drive i like my car to be somewhat aggesive
#8214
Just check your endpoints and you won't burn servos up, I'm going to get a 2.0 radio tray just to be safe. but as long as you don't overdrive your servo on brake or throttle side you should be fine. I don't put any o rings under my radio tray, that was just a band aid from Losi for all the people with the rtr with no knkowledge of how to properly set up your radio.
#8215
Just to be sure I always put a smal pice of fuel tubing between the servo arm and the carb link 3mm is ok.
#8216
Just remember to use the short hex bolt underneath the battery box where the o ring is suposed to go. I didnt and messed up my battery pack.
As for the O-ring deal , it was another idea that Losi had to stop the throttle servo issues people were having , which wasn`t the problem . Along with the radio tray brace , set up the linkage and radio and you will have no problems .
#8218
Radio tray loose.....2 screw's loose.....i would not be caught dead with a floppy radio tray like that....despite what you think that is wrong....the tray does NOT need to be loose like that....IMO.
#8220
I run the tray tight and the servo screws tight. Linkage set up per the addendum, so you can pull at least 1mm of throttle at WOT. I run the brake side linkage a little loose where the screw connects into the collar. IMO that brake side is the big stress source for the servo, it really binds up there. Still going strong on its first servo.
