Old 02-17-2009, 12:31 PM   #8176
desertbird's Avatar
Originally Posted by Integra View Post
Thanks! Looks like a guy could save 5.00 and dremel the screws 3 threads up from the bottom on the screw he already owns, that's all Losi basically did...
desertbird is offline   Reply With Quote
Old 02-20-2009, 05:45 PM   #8177
tc5 man's Avatar
how do u guys get all them annoying air bubbles out of the shock cause i went up and down slowely a bunch of times and let it set for 10 minutes and a night and they are still there,and when i put the bladder on and cap then bleed them i know for sure they are still there but i dont feel or hear the bubbles and i flick it to like a needle to help them get out, does it make the rebond inconstant . and one of my shocks are kind of tight one going up and down and theres no plastic pieces left on the shock parts at all,and the o rings are fully seated in there in there is now rebond when i bleed them at all. its just one shock they are brand new. do u think they are swelded up or did they give my the wroung o rings. they are brand new
Old 02-21-2009, 04:50 AM   #8178
I'm looking at the setup sheet and for the front it has that bump steer up or down option an it shows like a pivot ball...where exactly is that located? Are those the ones on the steering knuckles?
SoHotRightNow is offline   Reply With Quote
Old 02-21-2009, 06:12 AM   #8179
Integra's Avatar
no they are on the anchorman links.
Old 02-21-2009, 10:05 PM   #8180
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
i know this has been asked before and i know its all a matter of personal choice, but hat engine/pipe combo get really good gas mileage and is also good power and not too heavy on the wallet?
ive been running mine electric for the last few years and i want to get back into the nitro seen and just wasnt sure whats the "best" combo.
thanx
josh
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 02-22-2009, 01:51 AM   #8181
markt311's Avatar
Trader Rating: 32 (100%+)
I'm not sure what other people will say but my buddy runs a stock VSPEC with a 2050 pipe and gets about 11 minutes out of it. The new Losi RE11 is a 2050 clone but only costs $65. I have this setup ready to go for my new buggy but I'm waiting till spring to run it
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 02-22-2009, 06:05 AM   #8182
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
On big tracks I get 12 minutes with my Orion Wasp CRF .21 with a JP3 , small tracks about 11 with RB S3 and JP3 . Some engines are really picky for pipes to get the best performance and fuel economy .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 02-23-2009, 10:22 AM   #8183
Trader Rating: 46 (98%+)
Sorry didn't want to read over a 100 pages. Ran my 8 for the first time yesterday while the Batts on the 8E were charging. I noticed the back end really wants to slide out under acceleration really bad. What is the easy fix thicker diff oil?
Losi 8ight 2.0 sirio evoIII
Losi 8ight T 2.0 .21 vpec-t
Associated SC8
Jammin Crt.5 .12 Picco
everyjuangohome is offline   Reply With Quote
Old 02-23-2009, 06:53 PM   #8184
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
You can lighten the center diff oil, add kickup in front with the adjustable blocks, or both.
...Jim
W.E.D.
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 02-23-2009, 07:09 PM   #8185
dcracing's Avatar
Originally Posted by Briguy View Post
For the 8ight I don`t think you use the .050 wrench . It`s kinda an odd size but nice when you need it .
It is the same price if you buy the set of 4 or the three separate , so you mind as well buy the set and have the .050 incase you ever need it .
you need the .050 driver for the screw on the shock piston.
BCE Mugen Mbx6
Novarossi
Byrons
dcracing is offline   Reply With Quote
Old 02-23-2009, 11:08 PM   #8186
air8's Avatar
And the .050" for the linkage collars.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 02-24-2009, 12:57 AM   #8187
markt311's Avatar
and for the clutch pin screws
Caster Racing Parts
311 RC Graphics
Old 02-24-2009, 09:33 PM   #8188
tc5 man's Avatar
man i can not get them dam air bubbles out of the eight shocks they are brand new and everything is smooth they go up and down smooth and i tap the shocks like a needle then i let them set for a long time and make sure the shaft all the down ,and when i put the bladder on there goes the bubbles when i take the cap off to see if they are gone, i now them air bubbles make the rebond inconsent do u guys do anything special to get rid of them .i know a couple of times i was getting no rebond how much rebond good for the front or is it the same as the rear.i was wordering whats the diffrence with the 2.0 radio tray does it use the linkage as the losi 1.0 eight
Old 02-24-2009, 09:47 PM   #8189
Lars Johnson's Avatar
Send a message via AIM to Lars Johnson
Clutch pin screws are actually 1/16"
Team Associated / Reedy / AKA / Futaba / OS Engines / Byrons Fuel / www.steelescycle.com
Lars Johnson is offline   Reply With Quote
Old 02-25-2009, 05:50 AM   #8190
desertbird's Avatar
Here's what I do. With shock all cleaned out. Pull shaft down. Put a little less than 1/4 of the shock with oil. Now, push the piston almost to the top of that oil and PULL IT DOWN QUICK. You'll release the trapped air under the piston, and with only a small amount of oil in the shock it will escape quickly. Now let all that air rise to the top. After it has all escaped, carefully fill it the rest of the way. Place the shaft at the desired rebound position. Make sure there is enough oil on the top so that when you put the bladder on it ouzes out. Put cap on. AND NEVER OPEN IT AGAIN UNTIL YOU ARE READY TO REBUILD IT! If you have built it right, you should have nothing to worry about... At least I don't.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
