Old 01-23-2009, 10:03 PM   #8146
I have a quick question, do I need to use a larger insider diameter fuel line then what 1/10 scale cars run?
Linkdead is offline   Reply With Quote
Old 01-24-2009, 08:47 AM   #8147
Suspended
You will want to use Losi fuel tubing in all of Losi's 8th scale tanks.
http://www.losi.com/Products/Feature...rodId=LOSA9315
http://www.losi.com/Products/Feature...rodId=LOSA9314
Team EMB
CodyRothe is offline   Reply With Quote
Old 01-24-2009, 09:56 AM   #8148
Seriously what is different about the Losi fuel tubing?
Old 01-24-2009, 10:17 AM   #8149
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Why ? I`ve used other brands of fuel tubing in my 8ights with no problems .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 01-24-2009, 11:30 AM   #8150
Suspended
Personally I use the Losi fuel tubing because it doesn't allow it to slide into the tank or pull out and get stuck inside the tank. Most other brands are too thin and allow this to happen. Some aren't but most are.
Team EMB
Old 01-24-2009, 08:56 PM   #8151
Briguy's Avatar
Guess I`ve been lucky then and I`ve used several different brands .
Royal R/C & Hobby
Old 01-25-2009, 07:05 AM   #8152
Integra's Avatar
i aswell.....i use Venom Tubing....part#2050 i think..the big 50' rolls...works like a charm.
Old 02-15-2009, 08:08 PM   #8153
Really stupid question. I was building my shocks and then put the front shocks on, forgetting about the washer that goes in between the shock cap, shock standoff/black spacer, and nut. So I tightened the nut down too much to the point where the nut ran out of threads! I can turn the nut left and right, but there is no threads to grab onto. Ive tried using a set of flat head screwdrivers and the wrench to pry it off while unscrewing it, but no luck. Any advice on what I need to do? And if I cant get it to unscrew, will the extra space between the shock standoff/black spacer and nut cause any negative effects on handling, like being looser in the front?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 02-15-2009, 08:16 PM   #8154
Integra's Avatar
Cut the nut off with a cut off wheel being real careful to not touch the threads of the standoff ?
Old 02-15-2009, 09:02 PM   #8155
So bascially what you are saying is there is no possible way to get the screw out? Someone told me I can get this screw at a local hardware store - true?
Old 02-15-2009, 09:19 PM   #8156
Briguy's Avatar
Cut the nut off as Integra mentioned . Since your LHS doesn`t have a nut you can get them at a hardware store . The nut is a 4-40 nylon locknut .
Royal R/C & Hobby
Old 02-16-2009, 12:07 AM   #8157
Default Standard Tools?
Hi everyone,
I just bought a Losi 1.0 kit and was hoping someone can tell me what screw needs what tool?
I want to buy hex tools but I come from a metric background and the screw names make no sense to me, like for example does a 2-56x1/4'' screw use a 0.050'' tool???
If someone can please list me all the tools that are needed for this kit along with the screws it goes into.
Thanks!
P.S. I come from 14yrs of Kyosho Infernos and after seeing the ridiculous price of the MP9, and knowing that today there are other truly great cars, I finally decided to part with Kyoshos....and after a lot of research I found the Losi to be the best option by far!! It's design is so advanced and you really can't beat the price it's being sold for ($299!!!)...hopefully my throttle servo won't be an issue
Lookin forward to be a part of your community gentlemen.
RockinRo is offline   Reply With Quote
Old 02-16-2009, 05:59 AM   #8158
Briguy's Avatar
Here is what ou will need . The nut drivers aren`t needed but make the job a lot easier .
http://losi.com/Products/Features.aspx?ProdId=LOSA99104
http://losi.com/Products/Features.aspx?ProdId=LOSA99150
I`ve been using Losi tools for many years and never even show signs of wear yet .
Royal R/C & Hobby
Old 02-16-2009, 06:40 AM   #8159
Integra's Avatar
X2 the Losi driver's are Top Notch....i Will recommend the nut driver's tho....they do make life soo much easier.
Old 02-16-2009, 07:14 AM   #8160
+1 on the Losi hex drivers. Won a set at a race 3 years ago and wouldn't trade for anything on the market. You are also going to want a 1.5 mm hex driver (just get a cheap one for what you're going to do with it) and some 3 mm set screws. There are holes on the underside of the a-arm beneath the screws that attach the shock eyelet to the arm. After you attach the shock, run a 3mm set screw into the hole until it just snugs up against the screw. This will keep the screw from backing out. There are other ways, but that's the easiest.
cjtamu is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
