Old 01-10-2009, 09:35 PM   #8116
maycam10's Avatar
ok whenever i roll my car the back wheels lock up but the fronts dont. i think its a diff problem
Team Terribles!!
Losi 8ight
Go-Tech 3 port sport
Spektrum DX2.0
maycam10 is offline   Reply With Quote
Old 01-10-2009, 09:40 PM   #8117
Integra's Avatar
take it apart and figure it out.
Old 01-10-2009, 09:44 PM   #8118
maycam10's Avatar
i need help though. could the diff be the problem
Team Terribles!!
Losi 8ight
Spektrum DX2.0
Old 01-10-2009, 09:48 PM   #8119
Integra's Avatar
take the front and rear and off and check....spin them and feel them...if there's something wrong you can tell pretty easily.
Old 01-10-2009, 10:23 PM   #8120
Suspended
maycam10:
The easiest thing to do first is to back your rear brakes out, turn the knob clockwise. Then you know if your rear brakes are dragging. Also check to make sure your brake calipers are .020"-.030" apart.
There are a few things it could be if it is not your brakes dragging.
Your bearings could be bad it your hubs or diffs. Your ring and pinion could have to tight of a mesh, binding your rear.
Let me know if you don't get it figured out.
Team EMB
CodyRothe is offline   Reply With Quote
Old 01-11-2009, 11:24 AM   #8121
Default Set screws on swaybar?
What are the tiny set screws on the swaybar mounts for? If you set them tight it seems they don't transfer load from one side of the car to the other, but rather just stiffen each individual side. Are they supposed to be tight? When do you tighten them vs run them loose?
GO-RIDE.com is offline   Reply With Quote
Old 01-11-2009, 12:52 PM   #8122
dishsoap's Avatar
Do any of you losi pro's know about this?????????
My question is about the fitting from the rear drive shaft to the middle outdrive on the middle diff.
I didnt pay attention to har far inset the the drive shaft was to the middle outdrive before pulling the rear apart. After I got everything back toghether I notice that drive shaft was fitting flush in the outdrive. None of the other drive shafts fit like this one as the cross bars on the ball joint sits in the middle of the outdrive.
I tried to loosen up the middle diff from the bottom chasis to see if i could get a better fit however I had no luck.
The cross bars are sitting flush in the outdrive and it is secure its just not sitting as deep as the rest are. I spun the wheels and the rear drive shaft is engaged and everything seems to be turnning normal.
Is this normal or should I try to get a better fit before running it?
Thanks everyone.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 01-11-2009, 01:01 PM   #8123
Integra's Avatar
which one's..the one's on the diff case ? if so you want them somewhat loose so the bar can pivot but tight enough so the bar doesn't flop around....dismount the ends off the arms and make sure the bar has Zero resistance on it.
Old 01-11-2009, 01:06 PM   #8124
Integra's Avatar
Thanks everyone.
you can add a couple .2 or .3 shims to make the rear bone sit deeper...but you might have to grind off the tiny lip on the pinion to get the Set screw tight.
Old 01-11-2009, 02:47 PM   #8125
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
So how much better is the 2.0? I want to get back into the game and can't decide between the 1.0, 2.0, D8, and Hyper 9. can't beat the 1.0 and D8 for the money.
Dasupacat1 is offline   Reply With Quote
Old 01-11-2009, 05:50 PM   #8126
Cool thanks for the info. The person I bought the car from had the set screws tight and it really messed with the spring preload and the running ride height.
Old 01-12-2009, 02:25 PM   #8127
Default Weight of an 8ight?
Hey All,
Would someone please post the weight of a 8ight RTR w/o wheels and a full or near full tank. I'm also trying to find out the front to rear weight bias.
I've converted a used 8ight 1.0 to electric and don't know what RTR weight I should be trying to acheive. I'd especially like to get the front to rear balance the same as a Nitro so I can get close to the stock handling.
Thanks!
Old 01-12-2009, 07:41 PM   #8128
Danny B's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to Danny B
Default 8ight - T Clutch
Hey guys,
I'd like to hear what some others are running for clutch set-ups on the 8-t 1.0...I just got one and have about 3/4 gal on the truck. Stock clutch set-up is toast.
Any tips or suggestions for getting a little more longevity out of the clutch? Replacing the shoes every 1/2 gal will get a bit pricey! I do understand the truggy is going to be harder on the clutch especially with a GRP .28
I had good luck with 4 max life on my buggy outdoors, running a little different set-up indoors. I just don't know if 4 alums would work very well on our indoor track for truggy.
I'm open for suggestions! 4 alum? 4 comp? Stiff springs? soft springs?
TIA
Danny B.
Danny B is offline   Reply With Quote
Old 01-12-2009, 08:13 PM   #8129
Integra's Avatar
go with a M2C clutch w/Reg Hard shoes on .9 springs....you wont need any extra spring stall with that beast on board and they should last at least a couple gallons....same set-up as what i ran on my ninja.28 when i was crazy and thought i needed that much power.
Old 01-12-2009, 08:38 PM   #8130
What would be a good clutch setup for a medium size track, lots of jumps and bumps, Thunder Alley, only it is more rutted than it is in the video. Im looking for longetivity. I have heard great things from the fynamite max-life shoes. or should I get 2 alum/2 comp. I heard green and gold springs worked great!
It is for the 8ight 1.0 rtr.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
