Old 11-25-2008, 01:46 PM   #8026
Originally Posted by CaLaBeR View Post
The shafts are different because to my knowlege losi is using harder materials in the 2.0 bones to last longer.
Pretty sure the rear center shaft is longer and won't work with the 1.0 chassis. You might crowbar it in there but when the chassis flexes it ain't gonna be good. I think the diameter of the new f/r shafts is also a little bigger but the front should work fine, pins are supposed to be a little harder also.
cjtamu is offline   Reply With Quote
Old 11-25-2008, 09:58 PM   #8027
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Your better off to convert to the 2.0 rear case as it can be shimmed. And the aluminum inserts will not fit in 2.0 cases.
From what ive been told, the HD outdrives arnt really needed.
the arms are a direct swap if you run the 3.5mm outer hinge pins which are 5.25 for 2 from Amain.
Hope this awnsers all your questions.
Thanks, so all I need is a rear case to be able to convert it over? (and probably the shims)
I read somewhere that the difference in the shafts is becuase they are now stronger.
Drift_Buggy is offline   Reply With Quote
Old 11-26-2008, 06:57 AM   #8028
Trader Rating: 24 (100%+)
If you guys are talking about this part #
http://www.carolinasrc.com/Webstore/...dproduct=11567
I'm not sure on the thickness but I know for certain the material is harder. In turn this helps the pin from wearing into the bone(wheel side). If you notice your car would always start pushing or not turning as much when a groove developed. Once flipped to opposite sides then you had it all back again. This was meant to help with that issue. I have had these on my car since a few weeks before the worlds and they look good even now.
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 11-26-2008, 12:25 PM   #8029
Trader Rating: 66 (99%+)
Are the cnc braces a necessity, or simply a tuning option for certain tracks? I just got my 8ight 1.0 and it has the plastic braces.
pwnzor is offline   Reply With Quote
Old 11-26-2008, 12:40 PM   #8030
MikeFriery's Avatar
Trader Rating: 19 (100%+)
are you talking about the chassis braces?
if so, most people dont run them because more flex in the chassis = good.
Some people i know run front aluminum chassis braces to help prevent excess strain on the servo cases from the chassis flexing, which in theory can cause broken ears.
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 11-26-2008, 12:43 PM   #8031
yes sir, the chassis braces, sorry for not clearly stating that. Ok cool man, I think I will just run with the stock braces, thanks for your reply Mike....cheers!
Old 11-26-2008, 06:11 PM   #8032
Default 1.0 vs 2.0 radio tray & linkage
I have the 1.0 and will be slowly upgrading to 2.0 parts where possible and where it makes sense. (I can't believe they're not offering an upgrade kit - seems like they'd make a ton on that)
1st - I'm thinking about switching to the 2.0 radio tray. I pay special attention to the setup and I've never lost a throttle servo, but know that so many others have (I definitely don't want to rehash the setup vs. design flaw debate) and I figure the reason they changed it is to reduce or eliminate that problem.
Has anyone done this, and if so, did you also have to use the linkage kit for the 2.0 or will the original linkage work?
stevoreno007 is offline   Reply With Quote
Old 11-26-2008, 06:30 PM   #8033
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
You will need the 2.0 linkage .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-27-2008, 06:17 AM   #8034
what is the best quick change engine mount for the 8ight......Im looking at the KHZ, is that a good choice?
Old 11-27-2008, 06:26 AM   #8035
Integra's Avatar
depends...i run the KH to help with the flex near the CB/spur....but other's let it flex away.......i found the losi mount to Stick a little more when trying to remove it.......it all boils down to personal preference.
Old 11-27-2008, 06:31 AM   #8036
Briguy's Avatar
I also like the KH mount better and I run the KH cnc chassis braces .
Royal R/C & Hobby
Old 11-27-2008, 06:31 AM   #8037
cool cool.........I think Im going for this one.........cheers!
http://www.amainhobbies.com/product_...ducts_id/12776
Old 11-27-2008, 07:17 AM   #8038
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
cool cool.........I think Im going for this one fo' sure.........cheers!
That mount will stiffen the chassis possibly making the car feel a little loose... You may want to check out the KH standard mount or the Losi mount which is a little beefier but not extended. All are very good mounts though!
SCUBA STEVE is offline   Reply With Quote
Old 11-27-2008, 07:22 AM   #8039
Good to know.
I was also going to ask what the difference was between the 1.0 and 2.0 trays, but I decided to take a look at the Losi site. They state the position of the throttle servo is the difference. Makes sense - that's why you need the 2.0 linkage.
Is a radio tray brace/stiffener still a good idea on the 2.0 tray or is it no longer necessary?
Last edited by stevoreno007; 11-27-2008 at 07:45 AM. Reason: Changed question - read Losi site
Old 11-27-2008, 08:21 AM   #8040
CaLaBeR's Avatar
The stiffener is not longer needed as the 2.0 brace is reinforced in the flexible areas in the old tray.
CaLaBeR is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
