Old 11-13-2008, 10:20 PM   #7996
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
When putting the front drive adaptor on the front diff cover/bulkhead are you mean't to leave a gap between it and the bearing/diff cover or just put the two against each other?
Drift_Buggy is offline   Reply With Quote
Old 11-13-2008, 11:37 PM   #7997
air8's Avatar
No. The drive adapter has a very small machined lip on the bearing side of the adapter. This should butt up against the bearing in the diff housing. Doing this will hold the diff pinion gear in the correct position for gear mesh.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 11-13-2008, 11:55 PM   #7998
Sweet, thanks.
Also, what is the best and easiest way to remove the hing pins on the front spindles?
Old 11-14-2008, 01:44 AM   #7999
I just read the instruction manual for the 8ight 2.0 and they say to use shims in the diff. Is this also recommended for the 8IGHT?
Old 11-14-2008, 06:54 AM   #8000
cornerspeed's Avatar
No, unless you get the 2.0 rear gearbox/bulkhead and bearing insert holders.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 11-14-2008, 07:17 AM   #8001
Akhor's Avatar
I just installed a brand new rear ring an pinion.
When I turn the drive shaft you can hear the gears grinding and they do NOT feel smooth.
Is this something that will smoothen out once I run it for a few minutes?
If not I'll go back to the drawing board, but I've tried everything and all combination (pinion spacer(s) or not) have the same result.
Akhor is offline   Reply With Quote
Old 11-14-2008, 07:46 AM   #8002
MikeFriery's Avatar
Trader Rating: 19 (100%+)
it will break in..
you do have it greased right?
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 11-14-2008, 08:11 AM   #8003
Trader Rating: 24 (100%+)
Originally Posted by way2fastrcz View Post
Actually, the chassis on the 2.0 is lightened as well...chassis has some material milled out for weight savings and added flex!
I'm am throwing this loosely but I think a local guys version 1 came in about 7 7 oz. or a bit more.
At the worlds our cars were like 1/4 ounce over minimum ifmar weight. I think that is 7pnds, 2 oz.
Some savings areas are:
Towers front and rear
Smaller turnbuckles and turnbuckle ends
Chassis(I think)
Diff cases, now you no longer have to run the hd cases. This saves a good bit.
ABURTON is offline   Reply With Quote
Old 11-14-2008, 08:20 AM   #8004
Akhor's Avatar
Originally Posted by MikeFriery View Post
it will break in..
you bet I do.. Lots of it!
Old 11-14-2008, 11:45 AM   #8005
What about for the front and center?
Old 11-14-2008, 04:00 PM   #8006
No adjustments are possible or needed there.
Donny Vinkemulder
TLR Driver
Old 11-14-2008, 04:38 PM   #8007
Integra's Avatar
you can shim the front diff with the 2.0 shims if needed.
Old 11-14-2008, 08:15 PM   #8008
bajaracer1501's Avatar
Have any of you guys experienced ordering from Qoncepts? I'm interested in the split center diff mount but 2 emails have not received responses and there is no phone number available. The website says that inventory is current and if "In Stock" shows, it'll ship within 2 business days...just checking if anybody has ordered from them recently. Thanks
http://www.qoncepts.com/RCpages/Losi8ight.htm
bajaracer1501 is offline   Reply With Quote
Old 11-15-2008, 07:33 AM   #8009
Integra's Avatar
i ran one on my truggy for a little over a year.....gave me lots of problem's with the brakes jarring up on the cam's and locking the rear brakes after tapping the brakes.....i honesty wouldn't buy another one....ive since gone back to the stock mount.
Old 11-15-2008, 09:00 AM   #8010
Right on, that's exactly the kind of info I was looking for...I'll pass on it now. THANKS
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
