Old 10-18-2008, 02:07 PM   #7951
bajaracer1501's Avatar
Yo Integra, THANKS a lot man!
bajaracer1501 is offline   Reply With Quote
Old 10-18-2008, 07:46 PM   #7952
desertbird's Avatar
great timing on this one! now I know why my stearing took a shit
desertbird is offline   Reply With Quote
Old 10-18-2008, 09:51 PM   #7953
Integra's Avatar
When i FIRST got the adjustable's I KNEW something was up when i matched it to the stock plates with the Toe/Anti setting's they had originally printed.....and supposedly these measurements were done by a Machinist...so we can be assured those are the 100% real #'s.
Old 10-19-2008, 11:03 AM   #7954
underthethumbma's Avatar
hi any info on the front braces would be good what dose kick up do?
Losi 8 2.0 - Novarossi 21-4 - 9901 Super Strong - Sanwa - Futaba 3pk
underthethumbma is offline   Reply With Quote
Old 10-19-2008, 03:42 PM   #7955
Default Stripped Cooling head hex screw!
Hello. I was putting my cooling head back on the motor today after putting some after run oil in the cylinder I accidently stripped the head of one of the hex screws. Luckily it stripped when it was tightened down but now, the next time I have to take off the head I'm gonna be in a jam. The motor is the Mach 27 that came with my 8ight. Any ideas on how to get this thing out now? I have a set of bits and reverse screw heads for things like this but none are small enough to fit down the cooling head hole. It looks like there may be room to cut the screw off between the bottom of the cooling head and the top of the engine block, maybe with a flat copping saw blade. Anyone ever have this happen and if so, what did you do to get the screw out, short of buying a new engine?
Runaway Jim is offline   Reply With Quote
Old 10-19-2008, 03:53 PM   #7956
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
take the others out drill the head out the bad screw then buy a new one
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 10-19-2008, 04:32 PM   #7957
CaseyP's Avatar
Baja my bad on the inserts for got to add 1's up in the front to get 3 antisquat.
More kick up will go thru the bumps better. It should act a little stiffer and support the front more. This will also change the effective caster. More caster should make the steering imput slightly less aggressive.
If you can't get to the screw head you could always dremel the cooling head off and replace it with another one.
CaseyP is offline   Reply With Quote
Old 10-19-2008, 10:54 PM   #7958
The time has come for me to service the diffs in my 8ight. Removing the middle and rear are pretty straight forwards but what is the deal with removing the front diff? I read somewhere that you have to remove that spacer and it makes it easier?
If someone would be so kind as to post the steps for removing the front diff in the most efficient way that would be a great help.
Much thanks.
8ight pro Kit, MassiveMods stage 5 modified MRT GRP .21
Jonro is offline   Reply With Quote
Old 10-19-2008, 11:02 PM   #7959
cornerspeed's Avatar
Much thanks.
Take the entire front end off and apart. Then dis-assemble to get the diff out. This way you can inspect all of the front end components.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 10-19-2008, 11:09 PM   #7960
AZRCaddict's Avatar
The front is almost the same as the rear.
Take your front end off, 6 screws on the bottom of the chassis and 1 on the top of the chassis brace.
Then you will need to take the sway bar off like the rear.
After that you'll see there is 6 screws holding the front of the gearbox on.
Also look in your manual for the exploded parts view & instructions on how to assemble the front end.
Team EMB
AZRCaddict is offline   Reply With Quote
Old 10-19-2008, 11:09 PM   #7961
DirtyDezPirate's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to DirtyDezPirate
I rebuild my diffs every 2 to 3 races. but I should be doing it more often, if i have time, so that it doesnt cause bad luck.
I am just ME!
DirtyDezPirate is offline   Reply With Quote
Old 10-20-2008, 05:51 AM   #7962
Much thanks.
There's a spacer that sits beneath the top plate thta your steerign rack is connected to, probably what you're talking about. Look in your manual, you'll see it. Just take out the 2 screws that hold it in, makes it easier to remove the front end.
cjtamu is offline   Reply With Quote
Old 10-20-2008, 05:59 AM   #7963
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I just remove the sway bar and diff housing screws and loosed the screws under the chassis enough to get the diff housing out of the hole and pop the diff cover and diff out .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-20-2008, 04:49 PM   #7964
CaseyP's Avatar
The gearbox will swing out of the way with the swaybar still mounted. I don't like to mess with those tiny screws Lazyness I guess.
I too like to remove the whole front clip. That way you can inspect everything a little closer (like cornerspeed mentioned).
Old 10-29-2008, 02:01 PM   #7965
Trader Rating: 27 (100%+)
hey guys, anyone having problems with the fuel tank on the 8ight-t? I know they have the spring and lid on ebay for replacement, but is it a problem point?
Mine won't go to WOT. Gets to a bit less than half RPM and dies. Tried everything, then swapped in a different tank off my ofna, and it revved full throttle fine without issues
Fuel filter is good - used pipe tape, no leaks. Tested tank underwater, I may not be blowing hard enough but it was ok. I used a pressure vacuum thing (mity-vac) and got some bubbles at the lid, but that may have been too much pressure.
So far things point to tank (tubing is new..). Anyone else have issues with it? Just replace cap and spring and good to go? Opinions?
Thanks!
spawn_x is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
