Old 09-09-2008, 05:08 PM   #7816
Fabulous's Avatar
Trader Rating: 42 (100%+)
AKA IBeams best tire I have run so far.
Fabulous is offline   Reply With Quote
Old 09-09-2008, 11:03 PM   #7817
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
I stripped down my shocks on my race roller today as I am wanting to change the piston and stipped the screw head trying to get the screw off I read in the manual that it has been loctited on I was just going to use a dremel to get it off but what is usually the best way to undo them? By putting pliers over the shaft with a rag?
Drift_Buggy is offline   Reply With Quote
Old 09-09-2008, 11:43 PM   #7818
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
You can try twisting the piston counterclockwise (like you would the screw) and that my loosen the screw. I've done that with other parts before. I also use a set of dikes to grab the threads at the bottom of the shock shaft, but a towel and pliers works too...
K_B is offline   Reply With Quote
Old 09-10-2008, 12:39 AM   #7819
Trader Rating: 22 (100%+)
Has anyone tried the Dragon Racing CNC chassis for the 8ight? I'm in need of a new chassis and have seen these on ebay.
I'm sure the Losi Stock CNC and Tuned flex chassis will be better in quality. I mean, "you get what you pay for" My main question is for anyone who has tried or seen the Dragon Racing chassis:
Were there any major problems with it?
phixd is offline   Reply With Quote
Old 09-10-2008, 01:35 AM   #7820
I remember someone mentioning these some time ago and someone using the words dragon racing and taco and them being closely related
vroom88 is offline   Reply With Quote
Old 09-10-2008, 08:36 AM   #7821
Race-Wright's Avatar
If you can not afford the Flex get the stock replacement. I herd the same about the Dragon chassis bending. Plus I donít think there is any significant weight savings.
Gary Wright
Midwest Nitro Series
"Keeping racing simple"
http://midwestnitro.com/
email: gary@midwestnitro.com
Race-Wright is offline   Reply With Quote
Old 09-10-2008, 12:17 PM   #7822
dodgeboy93's Avatar
Default locktited shock shafts
try using a lighter on the shock shaft where the internal threads are then try to turn the piston off or dremel a slot in the head of the screw then remove.
usually the heat will soften the locktite so you can remove it
dodgeboy93 is offline   Reply With Quote
Old 09-11-2008, 12:17 AM   #7823
Can someone explain camber links. Changing the camber links would change the camber aswell? Is it another way of just changing camber if you don't want t adjust the turnbuckle?
My front tires are chewing out in the inside (mainly the right side)
Old 09-11-2008, 01:25 AM   #7824
Any camber hole you change to will require a link adjustment. Its just to drastic of a change. "your tires will have way to much camber - or + " The lower the inner hole, the more you increase roll center. The more parallel the link and arms are with one another the car will have less roll. Try just running the stock setup with less camber. Keep in mind too, the further you mount them inboard the more camber you will have when the suspension is traveling. Sure you dont have a right hand turn you always get on the gas in?
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
and a Retired 8ight.
MonkeyWrench is offline   Reply With Quote
Old 09-11-2008, 01:44 AM   #7825
The Roller front camber link is in #3 whereas the camber link is in #2 on the kit and most of the setups on Losi site are running it in the #2.
The Roller rear camber link is #1A, kit #4B and setups #4A
Old 09-11-2008, 04:04 AM   #7826
Trader Rating: 240 (99%+)
Camber links are an confusing adjustment.
Think of it like this:
The shorter the link the less side bite (traction sideways)
The longer the link the more side bite (traction sideways)
The more parallel the link to the lower arms the less roll the car will have.
The more angled down the inner is the more roll the car will have.
Any time you make a change in length you must reset your static camber.
A shorter link like in most of the setups will allow the car to rotate through the corner and not scrub speed, then when you exit the corner the car should square itself with the front wheels and accelerate.
The longer link like you are running car do two things:
1) it can keep the rear planted in the corner and cause it to push coming out
2) it can keep the car planted in the corner then when you get on the gas to exit it can make the car spin out or continue the corner.
I would start with the easy to drive setup and adjust from there. I think the rear is set at 4A and the front at 3
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 09-11-2008, 08:38 AM   #7827
Thumbs up
Is the losi 8ight worth holding on to or is it better to sell it to make way for the new buggy. I am concerned about parts being available and will it still be on the competetive edge with all the other new buggies coming out.
antone is offline   Reply With Quote
Old 09-11-2008, 08:47 AM   #7828
AE
Parts for the current Eight won't be that hard to find. Losi has always supported non current models with plenty of parts.
Dyno Dan is offline   Reply With Quote
Old 09-11-2008, 08:52 AM   #7829
Ok well thats good what about the new supposed 8ight 2.0 thats coming out. The new buggy is going to solve the issues that the current 8ight has and that is definitely going to be a huge advantage over the current 8ight
Old 09-11-2008, 01:44 PM   #7830
is it the standard in the 4 shoe clutch to run matching opposite shoes
for example: 2 carbon and 2 aluminum on opposite sides with springs to match
i mean, that's the stock setup.
Would it give a more gradual effect if lets say, you run 4 of the same shoes with 4 different springs: lightest to hardest? or is this a bad idea?
all input/criticism is appreciated.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
