Old 09-07-2008, 06:30 PM   #7786
Hi all
I have the 8ight RTR buggy mostly converted over to the competition buggy except for the chassis.
I'm currently running the Truhe setup and I have an issue.
On big jumps the rear of my buggy wants to unload off the jump and flip forward like I was doing a forward somersault.
I can't find a setting that has helped solve this. Any input would be appreciated.
Thanks.
chongo is offline   Reply With Quote
Old 09-07-2008, 06:57 PM   #7787
boostfiend's Avatar
Originally Posted by chongo View Post
Hi all
Thanks.
I'd try a bit heavier shock oil in the rear first, or at the very least a smaller piston. One change then test. If you're running 25wt (Losi) I'd try 30wt or 32.5wt and see if that helps. I'm sure more will have other ideas for ya. Still though, I'd try one change, then test.
boostfiend is offline   Reply With Quote
Old 09-07-2008, 07:00 PM   #7788
cornerspeed's Avatar
Hi all
Thanks.
Make sure you do not too much rear droop.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 09-08-2008, 01:48 AM   #7789
Anyone know where to get the fuel line for the 8ight? I need to replace the fuel line, due to leakage, and the one used for tank, is a bit thicker than normal.
I usually shop at Carolinas or a-main.
And, how much heavier it the alu spindel/holder combo, compared to stock plastic?
Is this a must have option? less slop?
Finken is offline   Reply With Quote
Old 09-08-2008, 07:33 AM   #7790
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I always used whatever fuel line I had or my LHS has and worked great .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 09-08-2008, 01:37 PM   #7791
dodgeboy93's Avatar
Originally Posted by boostfiend View Post
Welcome to the world of buggies. If you plan well, you'll really enjoy yourself.
For servos, I've had really good luck so far with the Ace DS1313 servos. They are quick and strong enough for both duties on buggy.
If you want to stick with Futaba, I'd go with the BLS351 and BLS451. I plan on upgrading to the Futaba setup, just to have all Futaba gear.
Ace would run you about $150 for the pair whereas the Futabas will be about twice that.
Again welcome. If you have more questions, there are several here that will be happy to help ya get going. My only other words of advice would be "Always buy new." ... but that's just me.
do you know if the associated xp ds1313 servo is the same as the ace ds1313 it looks like all the specs are the same????
dodgeboy93 is offline   Reply With Quote
Old 09-08-2008, 01:39 PM   #7792
air8's Avatar
They're same. Just different stickers.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-08-2008, 01:39 PM   #7793
Integra's Avatar
ya its the same.
Old 09-08-2008, 01:44 PM   #7794
air8's Avatar
Integra--so you're liking the M2C setup? From what I've seen there is a bit more adjustment than what Losi has available. So where have you settled at as a starting setup?
--"U Ain't Fast!!"
Chris Pearce
Old 09-08-2008, 03:01 PM   #7795
AZRCaddict's Avatar
5 Feet
http://losi.com/Products/Features.aspx?ProdId=LOSA9314
2 Feet
http://losi.com/Products/Features.aspx?ProdId=LOSA9315
The aluminum spindles and hubs will give you more steering over the plastic.
Team EMB
AZRCaddict is offline   Reply With Quote
Old 09-08-2008, 03:23 PM   #7796
boostfiend's Avatar
Exactly the same - except for price. You'll save about $20 on the pair if you go with the Ace... usually.
Old 09-08-2008, 03:47 PM   #7797
Integra's Avatar
depends on the motor and track really....but for a Honkin modded .28 Reg hards on .9's have been pretty sweet....my .21 set-up varies.
Old 09-08-2008, 04:45 PM   #7798
air8's Avatar
How much difference between the F/R CV driveshafts (LOSA3521) and the Center Front CV driveshaft (LOSA3526)??? I replaced the cross pins in all the worn out CV shafts today, and I have 5 that are same length. So I'm thinking I screwed up many months ago and put one of the 3521 wheel CV's in place of the center CV shaft.
--"U Ain't Fast!!"
Chris Pearce
Old 09-08-2008, 06:20 PM   #7799
Trader Rating: 240 (99%+)
Does any one know if the 8ight-T shocks are the same as the 8ight-B ?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 09-08-2008, 07:01 PM   #7800
Integra's Avatar
100% the same......and Air......are u talkin about the pins that have the cut out in them as apposed to the non cut out pin ?
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
