Old 11-15-2006, 09:46 PM   #766
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
The paint on that body looks awesome DNA!
We actually have added just a touch of clearance in the throttle/brake linkage area in the right air scoop. The JConcepts body also has more room for the air filter, since the roof line is higher and the windshield is higher at the base and at a lesser pitch.
There is also an air chin spoiler built into the body at the base of the windshield.
Most of the drivers who have tested have told me they feel more stability with our body on the car. That may be attributed to the roof shape, as well as funneling air to the wing more effiecently it also acts as a channel for air to help stabilize the buggy at high speeds.
Attention to detail is what makes them look different from each other, from a distance even the buggies all look the same! The 8 stands out since it is so much narrower...Just another way the body isn't like others, .
...Jim
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 11-16-2006, 05:08 AM   #767
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
supralative- Check out www.bmainhobbies.com for the losi 8ight. best prices anywhere.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 11-16-2006, 05:24 AM   #768
Trader Rating: 26 (100%+)
I think the new Proline Body looks awsome for the 8ight,
bobf24 is offline   Reply With Quote
Old 11-16-2006, 06:23 AM   #769
The proline body looks very good. Ive got a jconcepts on the way, ill have to check that out too.
Anyone been running on a high bite, tight track with the 8ight? How much setup changes have you made? Ive got a 2/2 rear toe plate on the way to try. We run slicks with traction compound on them, thats how much traction there is. Just trying to see if anyone had to change alot to get the car to work. Thanks.
Old 11-16-2006, 06:24 AM   #770
How about you check out your local racetrack/hobby shop and buy it there so they make some money and stay in business so that you have place to race.
H8W8IN is offline   Reply With Quote
Old 11-16-2006, 07:19 AM   #771
Whats with the hate? The guy that owns the shop i race at his track, and have been buying from him for a while. Whats the big deal.
Here, check out www.atomichobbies.com , or www.amainhobbies.com , or www.dougshobbyshop.com ...
Why does everyone have to H8ight on a good price on a product? If you want to pay more money at your local shop that is up to you, or the individual. To each his own...
Old 11-16-2006, 08:04 AM   #772
R40Victim's Avatar
How about we take the conversation in the traction direction. I already have another thread going about it, but I'd like to hear what other 8ight drivers are using on Blue Groove race surfaces. I just bought a set of the old switch in soft compound. I figured they were cheap, and soft, and I have seen them used on a XXX-4 pretty successfully. Anyone else use somethig similar on their 8ight?
R40Victim is offline   Reply With Quote
Old 11-16-2006, 08:33 AM   #773
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Ive had good luck with pro-line inside jobs and switch 2.0..... I think the PL's are a little more consistant but both work well. I run the stock set-up but put 5k in the center and play with the droop a little and it handles well. I plan on trying more this weekend.....
SCUBA STEVE is offline   Reply With Quote
Old 11-16-2006, 10:04 AM   #774
weezer23's Avatar
I figured some would like or hate this but its the latest from ProLine.
Losi 8ight building and setup-prolinelosi.jpg   Losi 8ight building and setup-prolinelosi2.jpg   Losi 8ight building and setup-prolinelosi3.jpg
weezer23 is offline   Reply With Quote
Old 11-16-2006, 10:41 AM   #775
Aaron,
Any news on what Losi is doing or suggesting to fix the throttle servo issue? I had several people check my setup over and it wasn't straining the throttle on the brakes but the one thing we noticed was once the servo pulled the carb out over half way it had to work harder because the carb was at an angle. I tried reducing it as much as possible but couldn't get it perfect like it would be in other cars.
By the way the car handled great.
*Topher* is offline   Reply With Quote
Old 11-16-2006, 11:29 AM   #776
Looks sweet! Getting 2 on order as we speak.
Tony Vega is offline   Reply With Quote
Old 11-16-2006, 12:45 PM   #777
Aaron Waldron's Avatar
Topher - No blanket fix yet. You brought up a good point with getting the carb to pull out smoothly throughout the travel.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 11-16-2006, 04:31 PM   #778
SupermaxxRich's Avatar
Originally Posted by *Topher*
Aaron,
don't think it has anything to do with that honestly..... anyone thats ever owned a TTR S3 knows how much of an angle the carb has to be in order to clear the centre brace. not issue.
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
Old 11-16-2006, 06:54 PM   #779
CaseyP's Avatar
It is however the issue if the engine is older and the carb is worn out.
This may not have been an issue with the other cars but when the linkage is put in that angle any slop in the carb will tend to bind and add extra load to the servo.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 11-16-2006, 09:50 PM   #780
TEN,TEN,'s Avatar
i finally got one, after alot of thinking and ????'s. but relly the price is what sold it. i can't wait to tear it apart and go threw everything,
http://cgi.ebay.com/ws/eBayISAPI.dll...m=320049420115
TEN,TEN, is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
