Old 08-25-2008, 02:07 AM   #7711
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Originally Posted by boostfiend View Post
Springs first. If it's too bouncy, increase dampening.
You must run a REAL bumpy track!
Yeah, it is pretty bumpy. Is there any point changing the rears at the same time? It only really feels like the front end
Drift_Buggy is offline   Reply With Quote
Old 08-25-2008, 03:38 AM   #7712
romeo_charlie33's Avatar
Default Nitro or Lipo
Originally Posted by Fred Perkins View Post
Thanks!
Here is my delema.
$445 to go brushless
$566 to go nitro
Where did you get those figures and what parts have you figured into your calculations? Seems a bit of a difference in the pricing not the way I thought it would be though.
romeo_charlie33 is offline   Reply With Quote
Old 08-25-2008, 05:17 AM   #7713
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
Originally Posted by Drift_Buggy View Post
I have a race roller and still running the race roller setup. I have ran the kit 4 times and now the front end seems really, really loose/soft dampering and bottoms out alot. What is best to do 1st? - Shock Oil, Pistons, Springs?
I just built a kit, and was looking at set-ups, the race roller should have the same springs set-up, but the diffs, are 3k,3k,3k i beleives, where th race car is 5,7,2.. oils should be the same in the shock.. 35wt.. make sure they are built rite, and check your ride height as well..
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 08-25-2008, 05:47 AM   #7714
MBR52's Avatar
Trader Rating: 8 (91%+)
Send a message via MSN to MBR52 Send a message via Yahoo to MBR52
Yer, the RR setup is pretty well right 4 all. It is a basic setup, that is good 4 an average track. I have hardly changed a thing.
Michael Brown
Associated RC8B powered by OS Speed
Associated RC8T powered by OS Speed
Mugen MST-1 powered by Novarossi
Associated B44 powered by Novak
MBR52 is offline   Reply With Quote
Old 08-25-2008, 07:52 AM   #7715
boostfiend's Avatar
If the rear 'feels' ok, I'd leave it alone. As a general rule; only make one adjustment at a time. Then you're not left in the cold.
As Jabroni stated, check your ride height as well. That's a biggy. I end up running with the front shafts just below level, then shafts level in the rear. That gives a slight rake to the car.
You may also try bringing the front shocks in a little on the tower, or going to the outside on the arm.
Again, one thing at a time. You'll come across that 'sweet spot' for your driving style and track.
boostfiend is offline   Reply With Quote
Old 08-25-2008, 02:48 PM   #7716
Trader Rating: 14 (100%+)
Default Qoncept split mount
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=010
Is this worth buying?
spcpicard is offline   Reply With Quote
Old 08-25-2008, 05:35 PM   #7717
What tool does everyone use to measure their ride height or is it just going by sight with the dogbones? To set your ride height do you push the buggy down and wait for it to rebound back up and measure it then or just put it on the ground. I have skid plates on both front and rear. Should I keep them into consideration when doing the ground clearance or just not worry about them? (there 3mm thick)
Old 08-25-2008, 11:35 PM   #7718
MaTt 93's Avatar
Send a message via MSN to MaTt 93
i use digital calipers
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 08-26-2008, 04:25 AM   #7719
air8's Avatar
Since I use the quick change engine mounts, the stock mounts are free'd up. I put an engine mount screw in the original mount and adjust the screw till it just touches the bottom of the chassis. Then measure from the bottom of the mount to the top of the screw head. that's my ride height measurement.
Drop the buggy from about 10" high and then measure front and rear. I try to use a flat surface, like a counter top, or solid table.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-26-2008, 07:20 AM   #7720
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
I did something similar you this, however with a rtr mount i found at the track i red locktited the screw in. one at 27mm for the fron and rear at 29. Since this is where i normall start with ride height for every track i use that for quick measurements. Then i have an AE ride height guage for when i need to make adjustments
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 08-26-2008, 11:22 AM   #7721
boostfiend's Avatar
I pump the shocks to see where they 'settle'. About 5 times, forcing both compression then rebound. Then I'll go by eye for ride height. Once I get close, I use calipers to even the sides.
I don't use skid plates, so I couldn't answer you there.
Old 08-26-2008, 11:50 AM   #7722
what is everybody running for the front anti dive on thier cars i have the adjustable hingle pin braces and just was wondering what the " norm " is
Camberlink is offline   Reply With Quote
Old 08-26-2008, 01:31 PM   #7723
boostfiend's Avatar
I assume you mean rear anti-dive. I'm also running the adjustables and using 3t/3a. I really like the setup, seems a lot more nimble than 3t/2a.
If you're speaking of caster/kickup - I'm still running stock with the alum. adjustables.
Old 08-26-2008, 04:36 PM   #7724
i installed some aluminum bearing inserts for the rear gear box today and the mesh is very tight and i mean tight!!....everything is lined up well and there is no slop on the pinion and coupler. i ended up having to put a couple thin spacers on the two top screws between the gearbox halves to have the mesh smooth out...
jstwin is offline   Reply With Quote
Old 08-26-2008, 04:41 PM   #7725
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
you may want to replace your rear gear box as it probably wore from the plastic bearing retainers.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
