Old 08-13-2008, 07:10 PM   #7606
Trader Rating: 28 (100%+)
Send a message via AIM to omaha_racing
I am having trouble getting max steering out of my eight. I am using a 3pk radio, and have the left at 100% and the right is between 65-70%. Anymore than that and it starts to bend the hell out of the servo arm and the linkage. Anyone have any ideas? Pro series race this weekend, and I want to get it right!
omaha_racing is offline   Reply With Quote
Old 08-13-2008, 10:29 PM   #7607
I'm not sure what your exact problem is but "FIRST" make sure the front and rear screws that hold the hub and spindle to the a arm arnt hitting on the inside of the spindle when you turn them back and forth. If the screws are turned all the way in and to tight they will hit the spindle and you wont get full travel "lock to lock". Then if thats not it, make sure both turnbuckles are equal lengths and your servo sub trim is set to zero. Then put the servo arm on the servo, it should be perfectly straight and just fall on, reset the epas so spindles just touch the c hub.
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
and a Retired 8ight.
MonkeyWrench is offline   Reply With Quote
Old 08-14-2008, 12:15 AM   #7608
air8's Avatar
Also try disconnecting the servo horn from the servo and moving the steering components by hand. See if you can find any binding at all.
Check your servo saver nut. Sometimes they will back off and rub against the chassis, preventing equal steering.
Try checking the servo saver itself. If you're still running plastic on top and bottom, this will cause unequal steering. Many people put the aluminum servo saver top on to prevent this. With the plastic pieces dirt can get between them and grind away at the plastics, making them "sticky."
Also check your droop screws front and rear. If they are not adjusted equally they will affect your handling. And check your A-arm/hing pin operation. Make sure there is no binding there.
Several of my friends and I will be in Lincoln this weekend. I'm looking forward to it.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-14-2008, 02:55 AM   #7609
MBR52's Avatar
Trader Rating: 8 (91%+)
Send a message via MSN to MBR52 Send a message via Yahoo to MBR52
Also have u centered the servo or u might have to adjust your endpoints
Michael Brown
Associated RC8B powered by OS Speed
Associated RC8T powered by OS Speed
Mugen MST-1 powered by Novarossi
Associated B44 powered by Novak
MBR52 is offline   Reply With Quote
Old 08-14-2008, 04:37 AM   #7610
Originally Posted by Roniel_R View Post
i ran my 8-buggy for the first time last week and the car was great but i was having problems with nose-diving issues,i will try to work on the setup but since im new to offraod maybe some one has had the same problem,any advice will be appreciated..
Make sure your brakes arnt dragging or sticking. And stay on the gas a hair longer.
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
Old 08-14-2008, 05:30 AM   #7611
As long as it doesn't rain it will be a great weekend!
Old 08-14-2008, 10:17 AM   #7612
LVBaja's Avatar
Originally Posted by antone View Post
Just a quick question guys, I am sure this has been asked a bunch of time already. What parts are necessary to convert the RTR 8ight buggy to the pro version? Aside from the obvious the shock caps, shock towers, and chassis. Any internal pieces parts that are different? I appreciate any and all answers that are given
You'll need to change the shock caps too. I only know that because a new guy at my local track busted the plastic shock cap on his 8ight RTR. The ones from my kit version are aluminum. This won't affect performance, but the plastic ones could cost you a race if they break.
LVBaja is offline   Reply With Quote
Old 08-14-2008, 08:55 PM   #7613
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
is anyone running a fuel filter? what brand/size/where? just bought an 8ight and 8t roller and doing them both gas. although i still think my e-8ight will get more use between the buggies tho.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 08-14-2008, 09:21 PM   #7614
thecman26's Avatar
Trader Rating: 98 (100%+)
This is the one I have used for the last 2 years, never has a lick of trouble with them.
http://www.carolinasrc.com/Webstore/...idproduct=3133
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-15-2008, 01:52 AM   #7615
MBR52's Avatar
Has any one found an easy way to change the fuel line and hold the fuel filter at the same time, how do others do it
Michael Brown
Old 08-15-2008, 03:41 AM   #7616
Hellsavage's Avatar
Use a hobby knife. U are changing it. This way the filter stays alive.
mzl Hellsavage
Hellsavage is offline   Reply With Quote
Old 08-15-2008, 06:30 AM   #7617
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Use needle nose pliers to grab the line inside the tank and pull out . Push new line into the tank and grab that with the pliers and pull up enough so you can put the filter back on .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-15-2008, 08:20 AM   #7618
jrr102486's Avatar
thanx for the info. where did you mount it?
Old 08-15-2008, 01:07 PM   #7619
thecman26's Avatar
I have it between the fuel line tabs on this side of the tank
Old 08-16-2008, 02:15 AM   #7620
Originally Posted by Nay0k View Post
Pink = soft
Red = soft/medium
Blue = medium/hard
Silver = hard
if it's losi comp's we're talking about it goes
silver= soft
red= hard
pink= clay m/s
blue m/h longwear
jlett21 is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
