Old 07-22-2008, 11:31 AM   #7381
Trader Rating: 27 (100%+)
So guys... trying to fit a picco .28 into a 8ight-T roller - do I need new mounts, or dremel mine out? The engine doesn't quite fit..
spawn_x is offline   Reply With Quote
Old 07-22-2008, 01:05 PM   #7382
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
what size are the clutch bell bearings? i blew mine up along with the clutchbell itself and waned to replace with bocas. thanx
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 07-22-2008, 01:10 PM   #7383
Integra's Avatar
5x13 for the inner and a regular 5x10 outer.
Old 07-22-2008, 01:32 PM   #7384
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Yes the orings are new but they are the black ones. in order to get the white orings for the shocks do i have to buy this
http://www.horizonhobby.com/Products...rodID=LOSA5418
I can't find just the orings.
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 07-22-2008, 01:55 PM   #7385
AZRCaddict's Avatar
They no longer make the black ones, white orings are the same part number LOSA5429
http://www.horizonhobby.com/Products...rodID=LOSA5429
AZRCaddict is offline   Reply With Quote
Old 07-22-2008, 03:19 PM   #7386
Sorry if this has been asked before, but I couldn't find it. How do I measure the droop on the 8ight? There can't be 109.5 mm of actual droop, so I assume they're measuring shock length with the shocks attached to the a-arm. Where do I measure from? Center of the shock cap mounting hole/standoff to bottom of the arm beneath the shock end seems to make the most sense, but I'm not sure. Thanks.
cjtamu is offline   Reply With Quote
Old 07-22-2008, 04:04 PM   #7387
Eric Swanson's Avatar
Center of the standoff screw to the center of the screw holding the bottom of the shock on.
Team Associated | Reedy Power | AKA | Schelle | LiveRC | LiveTime
Eric Swanson is offline   Reply With Quote
Old 07-22-2008, 05:14 PM   #7388
kolorking25's Avatar
can someone answer this for me ? i was looking at drakes setup and it said rear hub spacing all the way back does this mean the hub is back or the spacers are back
kolorking25 is offline   Reply With Quote
Old 07-22-2008, 05:53 PM   #7389
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
hub back-- spacers front
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 07-22-2008, 08:13 PM   #7390
DirtyDezPirate's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to DirtyDezPirate
Originally Posted by micrors4guy View Post
I emailed robert the day the pics of the stuff were up about the uni ends that accept the boots. Havent got anything back from him yet.
Matrix shop has been REALLY busy lately, he has not respond any of my emails or text messages yet. give it some time..
I am just ME!
DirtyDezPirate is offline   Reply With Quote
Old 07-22-2008, 11:23 PM   #7391
nice buggy Dirty Dez. I will snap some pics of mine once I am done. Gonna take me a little bit.
eltorito is offline   Reply With Quote
Old 07-23-2008, 06:49 AM   #7392
i just noticed the arms on my 8b were bent is this a common problem and how much will it affect the car's handleing.
Old 07-23-2008, 07:20 AM   #7393
Thanks Eric Swanson. Finally found it last night in the RCtech archives, LOL. kolorking, a-arms on all 1/8 scale eventually warp from the pounding they take. You start having to change your spring preload to get the ride height you want and the car won't handle properly. Just replace the a-arms.
Old 07-23-2008, 09:13 AM   #7394
ok, third time asking..
trying to put in a picco .28 into a 8ight-t Roller but the bottom of the engine seems too wide in between the mounts.
Can I dremel away or do I have to get some new mounts (like quick change losi mount?)
come on folks, real simple question
Old 07-23-2008, 09:25 AM   #7395
I didnt respond earlier because I didnt want to come off like im giving you info you already know but since youre still having this problem I will post.
On the 8ight-t you most likely have the 2 indivual mounts, one for each side. I am assuming you purchased this truck used and the mounts were already installed. You will have to loosen the mounts from the bottom of the chassis and reposition them so they accomodate your engine. You will then have to reset the mesh.
Hope this helps, sorry if it is redundant.
clarksib is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
