Old 07-16-2008, 06:15 PM   #7321
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Opinions vary on the lipo thing personally I run one and love it. That controller box you are talking about is a lipo regulator. The down side to lipo is it takes a lipo ready charger which you may not have.
Here are some links to check the stuff out
http://www.losi.com/Products/Feature...rodId=LOSB9820 battery
http://www.losi.com/Products/Feature...rodId=LOSB9608 regulator
http://www.losi.com/Products/Feature...rodId=LOSB9603 charger
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 07-16-2008, 07:57 PM   #7322
Default servo
Originally Posted by Arushmen View Post
Hi. everybody. I have been running the 8 since 2 months ago.
My problem is that I have broken 4 steering servos in this time.
I have heard about this problem in the throttle servo. I Didn't have problem with the throttle servo but I am crazy with the steering servo.
Do you know what is happening with it?
Check your servo saver make sure its set right,then always check your end point adjustment,epa right,left on controller!good luck!when i set my epa i turn all the way right or left,then click back a couple clicks never had a problem!
Jimmy Pierce is offline   Reply With Quote
Old 07-16-2008, 10:40 PM   #7323
Trader Rating: 52 (98%+)
Default steering
drake setup felt ok but stillnot enough steering in intering corner seems to wanna take corners wide and not tight unless i am rolling into them did not have problem with rc8 it would steer tight in to corner on and off throttle. but i am a losi fan all the way tyhey are the best know i am just over looking somthing set all my epa just right double checked my set-up on hudy stand now that all right going to try new servo may be old one is just getting old if that happens going to faster servo maybe its just npot turning wheels in time
mixedguy is offline   Reply With Quote
Old 07-16-2008, 10:44 PM   #7324
also going to switch back to stock plastic braces front and back enstead of kings head alum chassis braces will that make a big diff can u even tell?
Old 07-17-2008, 02:24 AM   #7325
Hi all,
greets from Germany.....
I have a question too! What ist bump steer? Up or down? I donīt understand that. And iīm searching for a good carpet set up! Someone can help me? Or someone have a good one?
Thankīs
Michael
iwillresist2008 is offline   Reply With Quote
Old 07-17-2008, 07:14 AM   #7326
Originally Posted by iwillresist2008 View Post
Hi all,
Thankīs
Michael
Does anyone have a setup 101 on the Losi 8b? I mean a document where you can find out about:
Bumper steer
Shock oil viscosity
Shock position
Shock springs
Droop
Ride height
Diff oil viscosity
Etc.
It would very helpful to a lot of people
cota348 is offline   Reply With Quote
Old 07-17-2008, 07:21 AM   #7327
Integra's Avatar
The back of the manual
Old 07-17-2008, 07:47 AM   #7328
Old 07-17-2008, 07:55 AM   #7329
LOL. I started to write an explanation of some of that stuff then realized it would take awhile. None of that stuff is specific to the 8ight, it holds for all cars. But, Integra is right, there are good explanations of some of that stuff in the manual. There's some stuff I printed out when I first started doing this, I think I may still have it bookmarked. I'll see if I can find the link.
BTW, bump steer is what it sounds like, it's the tendency of your car to steer itself due to toe in/out changes when the suspension reacts to bumps. On most cars it's changed by adding spacers beneath the ball stud, on the 8ight you can change it by moving the steering ball up or down. Bump steer is usually not desirable, esp. on rough tracks and you try to get as close to 0 bump steer as possible. A little is sometimes used on smooth tracks to help calm the car in the corner.
cjtamu is offline   Reply With Quote
Old 07-17-2008, 09:52 AM   #7330
Trader Rating: 27 (100%+)
Hello.
I just picked up an 8ight truggy and my Picco .28 motor has a hard time fitting into the stock mounts. I'm sure I could fit it in with *minor* dremeling, but wondering if this is a sign that I need different mounts?
Thank you!
spawn_x is offline   Reply With Quote
Old 07-17-2008, 11:23 AM   #7331
Here it is. There's a lot of info here on car handling, etc. Have fun reading.
http://users.pandora.be/elvo/
Old 07-17-2008, 11:51 AM   #7332
bloodrush's Avatar
hay all need a bit of help with my os speed . problem i have is the engine runs fine but when she get to temp it gose a bit mental as soon as you come off throttle it somtime revs its nuts off sometime it just idles fine for say 2 secs then it starts to rev any help plz
losi 8 b ,o.s 21 speed, jp3 ,ace servos, dx3,byron 25%
bloodrush is offline   Reply With Quote
Old 07-17-2008, 11:53 AM   #7333
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
sounds like a lean bottom and fat top.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 07-17-2008, 11:57 AM   #7334
bloodrush's Avatar
cheers but i am worryed if i lean it out more on bottom it will over heat .tryed pinch test on it and revs like hell you still think i need to lean it? cheers by the way
Old 07-17-2008, 12:02 PM   #7335
go back factory on the needles. set the idle gap to .7mm. then start it up get it up to temp and start leaning on the top end till it clears out and sounds good but still has a decent trail of smoke. Then start leaning on your bottom end. You can do the pinch test but if you are running a speed normall flush with the houseing and the slot parallel to the chassis is a good spot for th bottom on. +/- 1 hour or so
Rob Jensen
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
