Old 11-12-2006, 05:18 PM   #706
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
so what diff oil combo will give me a stable car with a heap of steering,will 4k help calm the rear down?
sorry for all the question guys
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 11-12-2006, 05:26 PM   #707
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
a thicker oil in the rear will lock in the rear end. also try going thinner in the center. im running 5/5/4 from fromt to rear and that makes the car very stable and easy to drive for me.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 11-12-2006, 05:36 PM   #708
with 5/5/4 do you find the car has plenty of traction and is pretty stable?
Old 11-12-2006, 07:08 PM   #709
i find that the car is very stable threw everything. and the car is planded with a ride high adjustment depending on the traction conditions
Rob Jensen
Old 11-12-2006, 07:15 PM   #710
Trader Rating: 39 (100%+)
My car is stable and drives very easy with 5/7/3. Its all in your driving style and track condition/layout.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 11-12-2006, 09:39 PM   #711
Who has the best price on 8ight kits at the moment, I think I want one!!
Thanks Brendan
mtmmotorcycles is offline   Reply With Quote
Old 11-12-2006, 09:49 PM   #712
Steve Walters's Avatar
Probably B Main hobbies...
http://www.bmainhobbies.com/
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 11-12-2006, 10:13 PM   #713
JBRacing's Avatar
At our track, the box setup came out not only stable but also with some understeer under braeking....
JBRacing is offline   Reply With Quote
Old 11-12-2006, 11:30 PM   #714
Aaron Waldron's Avatar
If your car has understeer when you're on the brakes, try less front brake before you worry about setup changes.
To ask for a setup that has a ton of steering but more rear traction is pretty silly. If that was possible, every car would be super dialed!
If your car is new, give it some time to break in before you start trying to tune in more rear traction. I recommend trying small ride height and droop changes before you start chasing funny setups.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 11-13-2006, 12:31 AM   #715
lol
Old 11-13-2006, 03:42 AM   #716
Maranai's Avatar
Send a message via Yahoo to Maranai
Default Air Filter Problem
Hi
Is there any tips on 8's air filter? Every time i ran my 8, the filter keeps clogged by dust. My local track is very dusty (loose dirt might i say). I've try to make dust cover on top of my fuel tank, but it didn't help. And now, i lost my JP engine coz the dirt enter the engine.
Please help. And sorry for my english
Maranai is offline   Reply With Quote
Old 11-13-2006, 05:01 AM   #717
add more oil to your filter and make sure the ends are somehow sealed.
Homer Allman is offline   Reply With Quote
Old 11-13-2006, 05:10 AM   #718
rdeppen's Avatar
Best advice I can give is find some good dirt bike air filter oil. I use Bel-Ray oil. Clean your stock filters (I mean the brand new ones or the old dirty ones) and re-oil with said good quality dirt bike oil. I change my filters often and will change them more than once per day if it's really dusty at the track.
I found the oil that comes on the losi filters is way to thin for my taste. I cleaned them before I ever ran the car. Don't know what they use but it's not put on thick enough for me.
If you can find it, PJ1 makes a great air filter cleaning product to get all the old crap out of them. Twin Air also makes a good cleaning fluid for foam air filters.
As to what Homer said above you can do what we do with dirt bikes and add a small bead of grease to each end of your filter to seal the ends. I haven't done it yet with my 8ight but I used to do just that with my old Mugens
rdeppen is offline   Reply With Quote
Old 11-13-2006, 05:29 AM   #719
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Brendan,
I have an assembled one, brand new with a set of new arms in the package still, and a painted body(Just blue with some shadow flames and stripes). I used it for pics and it is going on Ebay today. You won't miss it if you do a search.
...Jim
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 11-13-2006, 07:52 AM   #720
R40Victim's Avatar
What A Day!!!
Saturday was Race Day, and I couldn't wait to get out there. My car was ready to go and very dialed. I ran a few practice runs, and was turning pretty good laps, when I noticed my steering was backing off, as in, it started pushing. I also noticced my clutch was slipping a bit, but the retaining screw was rounded off and I couldn't do anything about it yet anyway(figured I'd finish the day an then tear it down). Well, through out the 2 heats it got worse and worse, yet I still managed to come in 3rd, then 2nd. It was really getting hard to drive. I thought either my reciever battery was dead, or the servo saver came loose. I removed the radio tray and cranked down on the servo saver as well as topping off the battery. That did not help, it was still pushing, but I was out of time, and had qualified 4th in the A main. I ran the race, and just tried to make consistant laps, after 15 minutes of hard drivng, not too many mistakes, and a couple good battles, I managed to come in 3rd! I was very proud of myself.
Well, this morning I decided to do a tear down and figure out what's cooking...I found out why my clutch was slipping:
Look what it did to my tank:
Apparently the bearing let go, which let the clutch bell slide forward and BAM, TOASTED!
I'm about to order all the parts, from what I can tell I need the bearings, and shoes, and maybe some of those spacers(they must have fallen out). I don't post this as a complaint, but a testament to how the car will keep driving even with severe damage...hell, I came in 3rd in the A Main!
I still haven't figure out why I had a bad push, the front end seems to be fine. I'll get the clutch sorted out, then I can try and figure out the steering issue...
R40Victim is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
