Old 06-09-2008, 01:55 PM   #7036
air8's Avatar
Originally Posted by mr. losi View Post
and fischer bumping 3 times to get second......dialed....
I though that was great also. I can imagine the high he had going on once he got in the main, and started making his way up. I bet that felt great.
Let's talk air filters. I usually put AF oil on the ends of the outer filter to seal it against the plastic surfaces. But last weekend I forgot to do that and I had lots of dust get past both filters. Luckily it mostly collected around the carb. I tore the engine down for a good cleaning and there was almost no dirt inside, thank God. So I'd like to know what others use, or what they do to prevent this.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 06-09-2008, 02:08 PM   #7037
freefallmarine's Avatar
I use Mugen oil on my filter's and never had a problem.
What if the Hokey Pokey is, what it's all about?
freefallmarine is offline   Reply With Quote
Old 06-09-2008, 02:14 PM   #7038
Suspended
Send a message via AIM to Nay0k
Losi owns, no question about it...congrats to Truhe and all the other Losi drivers who performed well at the Nationals.
Nay0k is offline   Reply With Quote
Old 06-09-2008, 04:07 PM   #7039
I thought Tex said the Losi car was not designed right? Lets see they finished 1st 2nd and 5th and Tex (the one with the right designed losi car) finished about 130th or so. Hmmmm....Go get umm Tex. Just busting your balls Tex! haha
H8W8IN is offline   Reply With Quote
Old 06-09-2008, 06:13 PM   #7040
air8's Avatar
Well, it's not the filter oil being a problem. It's the ends of the outer filter, near the plastic caps. They let dirt through if filter oil is not applied to the ends of the outer filter. I'm going to start wrapping my air filter housing with the self-stick bandage wrap for injured joints. That stuff blocks a lot of dirt/dust while letting air through. Kind of like the Outerwears thingys.
--"U Ain't Fast!!"
Chris Pearce
Old 06-09-2008, 06:17 PM   #7041
Is the filter oil your using tackey? Mugen oil is hella tackey and keep's everything in place.
Old 06-09-2008, 06:22 PM   #7042
air8's Avatar
Yes. Very tacky.
--"U Ain't Fast!!"
Chris Pearce
Old 06-09-2008, 06:33 PM   #7043
Bubble Gum bro. Bazooka #5. Works everytime!! hahaha.....
Old 06-09-2008, 07:05 PM   #7044
I use Rbmods air filter oil and sealer NOTHING gets by my filters. The sealer is some sticky S#$%!!
LosiMadMan is offline   Reply With Quote
Old 06-10-2008, 02:57 AM   #7045
Somewhere I read to put grease at the both ends of the filter, since then never had a problem, besides using a good oil filter like Mugen.
cota348 is offline   Reply With Quote
Old 06-10-2008, 03:06 AM   #7046
Hi all,
I'm running the eight T with a Ninja .21. I had a problem with the clutch not engaging. I am thinking it's because I ran it too long without filing down the edges of the shoes? Is it better to run an aftermarket clutch or is the losi clutch fine for racing?
sleek the elite is offline   Reply With Quote
Old 06-10-2008, 03:32 AM   #7047
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
The losi clutch is the best clutch there is
SCUBA STEVE is offline   Reply With Quote
Old 06-10-2008, 07:27 AM   #7048
Integra's Avatar
i hate to disagree....but its not......the flywheel gets Gouged by the springs quickly making the shoes stick quite often...and there's no fix for it....well maby there is....but i dunno.....ive gona through 3 flywheels in the last couple months.....im moving on to the M2C version and go from there....as the springs actually LAY down on the flywheel as appose to Stabbing it....Most of u losi guys will know what im talkin about.....and also i found the pins to wear alot faster then a standard FLywheel post would...so i fould myself buying sets of those pins almost Every clutch rebuild...M2c here i come.
Old 06-10-2008, 08:09 AM   #7049
When the springs begin to stab into the flywheel just take a small file to it and file the area a little bit to make the surface smooth and "semi flat". As for the pins I do not know... I have never noticed much wear on mine. Hopefully this helps you.... or you can try the m2c... good luck either way
Old 06-10-2008, 08:18 AM   #7050
thecman26's Avatar
Trader Rating: 98 (100%+)
Hey air8,
try using some athletic wrap around the filter, me and cool have been using it for a while and it works great to keep the crap outa the filter! If you are going to augusta this weekend for the rc pro race I can show ya what I mean!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
