Old 06-02-2008, 05:02 PM   #6976
bloodrush's Avatar
Default screws
has anyone ever changed the screws and nuts for metric ones?if so what for what cheers
bloodrush is offline   Reply With Quote
Old 06-02-2008, 11:08 PM   #6977
air8's Avatar
Originally Posted by Semple View Post
Will I be able to find one at Home Depot, etc?
I found a setscrew at Lowes that worked for me. It wasn't an M4 but it was close enough to work and I needed something that day. I took the pipe and hex drivers to the store with me to make sure I found one that would work.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 06-03-2008, 12:13 AM   #6978
Originally Posted by mr. losi View Post
hey i am going to replace the pins in my front drive shaft, what is the mugen or x-ray part number....
thanks
MAtt
Either
MUGC0271 Mugen 3x13mm Joint Pin
or
MUGC0270 Mugen 3x12mm Joint Pin
LosiMadMan is offline   Reply With Quote
Old 06-03-2008, 02:12 AM   #6979
Trader Rating: 52 (98%+)
Default clutch
the wheels spin at idle yes but not all the time somtimes they do and others they sit still werid. what kind of play do u all use for the clutch bell and spur gear read u want it lose so that how i am running it should i do the paper thickness as the manual says. i did put the shoes on the right direction too. what info are u looking for be gald to give it too u. need to know if this thing is supose to have side to side play and what other bells u can use with losi clutch. one more thing i am running ninja .21 bo1a motor and it rubs on gas tank any fix using fatory engine mounts i pulled the tank forward with a zip tie but would like a good fix not a rigged fix. o and does any one know what pipe works best with this motor
mixedguy is offline   Reply With Quote
Old 06-03-2008, 07:48 AM   #6980
desertbird's Avatar
My front two diff case mounting screws are stripping... Don't get excited, shes fairly ugly, has no tits, and only does it when I'm getting ready to screw her....
Is there a trick to restore the threads and get a little more life out of the diff case; I hate to just dump the biach? Then once I do get a new case is there something to reduce the likelyhood of the new biach from stripping on me?
desertbird is offline   Reply With Quote
Old 06-03-2008, 08:37 AM   #6981
jkirkwood's Avatar
Moving the arms forward does more than just help the front of the car from digging into the ground. You are changing wheelbase, weight distribution, steering ackerman, driveshaft angles, and probably a few more things. The total change of doing that may result in positive or negative results on the track. For some it may work better than for others. My point is when you make modifications like that try to understand what it's doing so if it's not behaving on the track like you expected you know why.
I'm all for making modifications. Some people say nothing on my car is stock. They may truly never know.
desertbird: You can try some CA but that is a high stress area and I wouldn't expect it to hold. You could also try drilling it out and using a larger screw. The best thing would be to get new diff cases. Just don't overtighten the screws, they only need to be snug.
jkirkwood is offline   Reply With Quote
Old 06-03-2008, 10:17 AM   #6982
cornerspeed's Avatar
I would say there is no clutch problem as regards to the wheels turning. If they are spinning pretty fast, then the idle is too high.
>5mm to 1.0mm endplay is fine. You may want to do the paper thing for the gear mesh till you get the hang of how much backlash you need for the gears.
If you put a spacer between the flywheel collet and the front engine bearing, that may be your problem with the clutch too close to the fuel tank. ERemove that and re-assemble and correct the shimming. Should be good to go if that was the case.
Off to the NAT's.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-03-2008, 10:19 AM   #6983
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
good luck to all thoes going to nats.
micrors4guy is offline   Reply With Quote
Old 06-03-2008, 10:19 AM   #6984
Clutch bell to bearing slop can be reduced by swiping some CA on the bell for where the outer bearing races contact.
Donny Vinkemulder
TLR Driver
Old 06-03-2008, 08:06 PM   #6985
Default thanks the help
tried what u gues said going to track tom and tell u all if it work just rebuil the buggy it will be its first run was having on the problem on my 8t. what stater box does everone use on there buggy have ofna crome top with blue bottom to heavy looking for smaller box with lots of touque cuz I only run high end motors with lots of pinch grp .21 heard losi box motors burn up any suggestions
Old 06-03-2008, 08:22 PM   #6986
SteveJa's Avatar
Trader Rating: 17 (100%+)
I have used 3mm screws same length in my diff cases for a long time.. you do not even need to tap / re-thread......
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 06-04-2008, 12:32 PM   #6987
losi316's Avatar
This interesting I just checked out extreme rc cars magazine website and they caught losi testing a electric powered 8. http://www.rc411.com/
losi316 is offline   Reply With Quote
Old 06-04-2008, 01:17 PM   #6988
air8's Avatar
That is interesting. But I'd be more interested to know if they were actually testing one, or wether one of their guys converted one and let others drive it. Obviously I don't have a clue, but I know those 1/8 E8's haul ass.
--"U Ain't Fast!!"
Chris Pearce
Old 06-04-2008, 02:34 PM   #6989
RETRO RC's Avatar
Originally Posted by tex1 View Post
All of my stuff is packed and being shipped to the Nats. I need to take some new pics because my others are to big to post on here. I did pack my camera as well.
Actually if you look at the new 808 front arms on their website, the front of their arms are cut back 4mm and they use shims to hold the arm where they want it. This is basically what I did to mine. It almost looks identical. I put the 3mm Xray shim in the back of the arm and it gives you instant front end clearance.
I'll take some more pics.
Take care,
TEX
thanks tex
and good luck for the Nats kick some a$$
Adrian
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 06-04-2008, 05:36 PM   #6990
desertbird's Avatar
I have had two clutch screws lock into the shaft and then strip the allen hole. The first time I cut a slot in it and used a flat head to get a little more force and out it came. This time I purchased a screw extractor. Well, I drilled it, tapped the extractor like the instructions say and guess what the god damn head came off. So no biggie I think, I start drilling the screw out and will tap new threads. Well after I get in there I can see enough meat left so I put the extractor in and that damn thing busts off in there. Well, I can not drill out the hardened steel without severe damage to the crank.
What the heck am I doing wrong to get the clutch screws stuck I know you have to tighten the living crap out of it and use a LITTLE BIT of lock tight. Is it the screws are cheap metal? they are factory Losi clutch kit screws.
Help me understand how you get the clutch screw tight enough to not work loose butremove it if you need to do clutch maintenance....
Help! I can not purchase a new engine and continue to have this problem.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
