Old 05-23-2008, 08:17 PM   #6871
air8's Avatar
My ring gears between both vehicles come out to the same 43t count. I already had them on the bench. IDK why the different part numbers.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-23-2008, 08:19 PM   #6872
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
the ofset on the gear is different to get the same esh with the smaller pinion gear
micrors4guy is offline   Reply With Quote
Old 05-23-2008, 08:42 PM   #6873
air8's Avatar
ahhhhh, good call. I didn't even think about that. Der de der. LOL
--"U Ain't Fast!!"
Chris Pearce
Old 05-23-2008, 08:49 PM   #6874
Integra's Avatar
X2...Duhhh.....ALL HAIL MICRO.
Old 05-23-2008, 10:43 PM   #6875
Originally Posted by boostfiend View Post
For those that purchased the kit; were your tires already glued onto the rims?
Thanks!
Nope they are not pre-glued. I used mine for break in tires they are just step pins.
LosiMadMan is offline   Reply With Quote
Old 05-24-2008, 06:01 AM   #6876
boostfiend's Avatar
Thank you very much. Mine were pre-glued! (..and poorly) I tried writing to Losi, but they've failed to return any email. So I contacted Horizon; told them I had the KIT and they asked me which RTR I had.
Thanks for confirming this for me. I thought I might be the only one here that actually built the kit.
Back to fight with Losi/Horizon.
boostfiend is offline   Reply With Quote
Old 05-24-2008, 06:19 AM   #6877
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
Im really interested in trying the truggy gearing in the buggy.I have a few questions.
To get the truggy gearing i run the truggy front and rear Diff ring gears and pinions in the buggy,Correct?
What clutchbell should i use?
I have read some things from people that the motor doesn't have to work as hard for the same performance thus making it run cooler and longer runtimes.What does it do to the cars acceleration? What other advantages are there in running this ratio?
Thanks heaps!
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 05-24-2008, 06:23 AM   #6878
Trader Rating: 42 (92%+)
can you run all black springs on the clutch, will this be the sofest clutch
icemandolmite is offline   Reply With Quote
Old 05-24-2008, 08:16 AM   #6879
Thanks heaps!
yes, you would run the 8t ring and pinion gears in the front and rear gear boxes. Then you would have to get a 46 or 47t spurr, with the 46 run a 17 tooth clutch bell. with a 47 i would say run a 15tooth bell. If you go back a page or 2 air8 explains the advantages of doing this.
Old 05-24-2008, 08:51 PM   #6880
tex1's Avatar
Send a message via Yahoo to tex1
Red face You kidding.....
Might try going back and reading the last three pages. You will find all of the information you need to put the whole thing together. The correct setup needs to be 18 CB to 47 Spur. You can run 18 - 48 or 17 - 46 (Muggy spur gear). I found the 18 - 47 to be the best all around gearing.
Check the post for part numbers and ask if you have any more questions.
TEX
tex1 is offline   Reply With Quote
Old 05-25-2008, 04:31 AM   #6881
dead1dave's Avatar
I had a couple quick questions for you guys hoping you could shoot me a little info .
How do you guys check your ride height ? I have the associated gauge and I was wondering if you drop the car from like a foot or so or if you just push the car to a flat surface and then let go and check from there . Is 27 in the front and 28 in the rear the best ?
Also what is everyones best all around favorite tire ????? For just regular old outdoor dirt.......club racing stuff where they water before a round of qualifying and then it's dry as a bone by the end of the round . Tracks I run seem hard underneath once they are run in with a light layer of loose stuff on top .
Here are a few pictures of my car and truck .
Thank you in advance for your replies . Dave
Losi 8ight building and setup-plaque_glen_7.jpg   Losi 8ight building and setup-plaque_glen28.jpg   Losi 8ight building and setup-pict0083a.jpg
dead1dave is offline   Reply With Quote
Old 05-25-2008, 08:13 AM   #6882
tex1's Avatar
Thumbs up
I push the car down flat and then measure the lowest part of the chassis on the end in question. I like 27R - 26F for smooth blue groove type tracks. Yours sounds fine for what you are running on.
Losi XBT Red is currently my tire of choice for when you need a pin to go through the top of the dirt.
If you like Bowties then try the Losi Eclipse Red.
Hope this helps,
TEX
Old 05-25-2008, 11:56 AM   #6883
I like the Bowfighter tire setup. Bowties up front Crime Fighters in the back. It really depends on the track conditions.
Old 05-25-2008, 12:13 PM   #6884
the bowfighter set up is the other way arround. crime fighters up front bowties in the rear. The crime fighters give you the agressive steering while the bowties in the rear allow the car to rotate and not catch the bumps and ruts like a crimefighter would.
Old 05-25-2008, 02:48 PM   #6885
Integra's Avatar
x2....ive tried it and it works.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
