Old 05-20-2008, 07:59 AM   #6826
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
ok...thanks....so you are basically saying we should run truggy gears in the diffs and put a smaller spur and larger pinion to get the same finals gear????
just trying to be clear....
thanks
Matt
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 05-20-2008, 08:23 AM   #6827
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
thanks
Matt
Sort of... it is actually a slightly higher ratio overall than stock that he is describing... just slightly. Going down to a 17 tooth bell would be closer to stock. A big advantage here that isn't mentioned is the extra "meat" in the teeth area of the clutch bell... less breakage! I shread 14 tooth Losi bells like they're made of paper. I went to a 15/48 with a non-Losi bell this past weekend and it's holding up ok now, and the car STILL has more punch than I know what to do with... I think the higher overall ratio he has described how to get would calm the car down. (I'm running stock ring and pinions in the front and rear.)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-20-2008, 08:26 AM   #6828
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Originally Posted by tex1 View Post
It has very sharp edges that work and score the plastic and even the alum nut on the servo saver. Take a rough stone grind tip for your dremel and round and soften the edges of the spring. I rounded the ends of mine to almost a ball and they will wear much better on the plastic and alum surfaces. I followed this up with Traxxas lithium grease on both ends of the spring and it will stay good and consistant for at least a month of racing before you need to clean and reassemble.
The servo saver is the weakest link on the 8ight. They need to fix it to be like the Kyosho or new Xray 808 servo saver. I have emailed them about this to no avail. It is simply not designed correctly for the vertical movement required to make it work right. This is where most of the slop comes from in the Ackermann arm. When the saver flexes it twist the joints and the arm.
Next stop is the gearing and front end.
Worlds are this year!
Come on Losi! Get it in gear!
TEX
<-------- Not Done Yet!
if they need to change the gearing and the front end soo bad then why are companies useing the same gearing and front ende setups on their new cars.
micrors4guy is offline   Reply With Quote
Old 05-20-2008, 10:36 AM   #6829
Originally Posted by air8 View Post
Well, whatever you're trying to inquire about must be new or something. Amainhobbies doesn't have those part numbers.
Oh ok. Found them elsewhere. Why would you think they are longer?
There are instances where the dogbones may come out. I know that we can shim and fix them but I was wondering if they new ones (losa3553 and Losa3554) where longer and you did need to shim.
cota348 is offline   Reply With Quote
Old 05-20-2008, 10:56 AM   #6830
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
What brand of diff oil do you use? And does Losi sell their diff oil in a larger bottle than the single use tubes?
i use all mugen and have never had a problem. they held up all last year but i noticed about a week ago i REALLY need to redo them. but thats just cuz im so busy and havent had a chance to change it yet.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 05-20-2008, 11:37 AM   #6831
air8's Avatar
Cota--did you see Matt Howard's post? #6784
Iv'e been using the Mugen also. A long time ago in this thread, some suggested the Mugen oils were around 1,000 heavier than the Losi oil. Well, I'd like to test between the two. That and I can't seem to find the viscosity I'd like in Mugen oil. I drive the 8-T also so I'd like to have 9k or 8k Mugen oil. I can't find it though.
I've thought about getting a whole set of the Ofna oil cause they have about any weight you could think of. I realize everything would be different, but that's what practicing is for. LOL.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-20-2008, 05:46 PM   #6832
Default Question about building the Losi clutch
IS there a trick to building this clutch? I am having no luck. I have ruined one composite shoe, and stripped 2 screws. I am going to buy a new flywheel and assorted parts and start over. Anyone offer any help?
Cvdiver is offline   Reply With Quote
Old 05-20-2008, 06:30 PM   #6833
Tex , what clutch and brand of pinion are you running with that setup?
H8W8IN is offline   Reply With Quote
Old 05-20-2008, 07:32 PM   #6834
air8's Avatar
Try grinding/sanding a slight bevel on the end of the clutch pins. This will help it get through the rear of the flywheel. But don't put too much angle on and don't take off too much material. Try a slight bevel, work on putting it in, if it doesn't go then put a little more bevel on. Just keep doing this till you find the sweet spot.
Also be sure you're pushing the clutch shoe down against the flywheel so the holes for the pin line up all the way through. The clutch springs will keep the clutch shoe slightly off the flywheel so there is some tension already on the clutch shoes.
--"U Ain't Fast!!"
Chris Pearce
Old 05-20-2008, 07:49 PM   #6835
Powerlink's Avatar
Send a message via AIM to Powerlink
Can some tell me what weight the shock oil is that comes in the buggy kit (orange bottle) I can't see that they put any markings on the bottle. Thanks
Karl Rolf
Powerlink is offline   Reply With Quote
Old 05-20-2008, 08:19 PM   #6836
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
35 weight. Thats why it is orange
pink_sleeve is offline   Reply With Quote
Old 05-20-2008, 08:21 PM   #6837
Powerlink's Avatar
Thank you
Karl Rolf
Old 05-20-2008, 08:25 PM   #6838
Thank you
no problem
Old 05-21-2008, 01:48 PM   #6839
Trader Rating: 22 (100%+)
are the Losi 8ight CVD drive pins replaceable with a tool??
ive heard of people doing them to mugen pins:
http://radiocontrolcoslada.blogspot....-cvd-pins.html
phixd is offline   Reply With Quote
Old 05-21-2008, 01:54 PM   #6840
Integra's Avatar
any pin can be pressed out...but the quesion lies in will it Hold in there once u press in a new pin....i tried cold pressing a pin out myself to only have the new 1 back out during the middle of a Race...could have been nasty is it worked its way out into the brakes...and yes i used the red permanent loctite and it still backed out. ...i just buy new 1's for the peace of mind.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
