Old 05-19-2008, 04:22 AM   #6796
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Thanks, got it out and worked it out
Drift_Buggy is offline   Reply With Quote
Old 05-19-2008, 04:58 AM   #6797
Matt Howard's Avatar
Originally Posted by tex1 View Post
You beat me Matt.
sweeeet
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-19-2008, 07:56 AM   #6798
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by btracing View Post
Hi All,
My losi is destroying the front bearings every 20 mins or so, I have replaced them so often I lost count.
I run standard 4 shoe losi clutch and shim / adjust the clutchbell for endfloat.
Has anyone got any ideas??
Cente diff moving? or anything else common.
Many thanks .
That's a common problem. I've heard several fixes: King Headz quick change mount with the exteneded "finger" to the gas tank post to reinforce the chassis... got that, still had a problem. I understand you have to run the mesh a little sloppier than most buggies due to flex there... even with the King Headz mount.
I got frustrated and flipped the mount to move the motor, used a "regular" clutchbell that is shorter. Problem SEEMS to be solved now... but then again I'm running the mesh a little sloppy.
BTW you are lucky in a way... better $2 worth of bearings than $18 worth of clutch bell. (I went through 2 bells last weekend and 1 this weekend before deciding to change it as described... so $54 + $6 for bearings since I wasn't gonna try running the bells on the bearings where the previous one failed... $60 in 2 weeks... yikes)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-19-2008, 10:47 AM   #6799
GREGORY!'s Avatar
Hi guys!i have put the 8's shocks in my mbx5r and because they are shorter from the mugen's i need the 2 little plastics that used in the 8T arms.[the rear suspension arm stundoff]they are inqluding with the rears arms but i don't need them.does anyone have any and don't need them?
Any help please!
GREGORY! is offline   Reply With Quote
Old 05-19-2008, 11:11 AM   #6800
ok guys i am having trouble here and can't seem to get it figured out. I am fairly new to my 8ight and the last time i did any racing was back when 1/10 scale electric ruled the world. That being said the rear end of my 8ight won't stay planted in the corner. My turn in is awesome but trying to come out of the corner the rear end kicks out and almost (or does) spins me out. I am running the links in the 2-A position, and i have the adjustable rear hinge pin brace so i can change to what ever. I am running 7-5-2 diff oil and 3 degrees negative camber. i really wanna plant the rear end better from the middle out of the corner any ideas?
Camberlink is offline   Reply With Quote
Old 05-19-2008, 11:22 AM   #6801
jimbal's Avatar
Originally Posted by Camberlink View Post
ok guys i am having trouble here and can't seem to get it figured out. I am fairly new to my 8ight and the last time i did any racing was back when 1/10 scale electric ruled the world. That being said the rear end of my 8ight won't stay planted in the corner. My turn in is awesome but trying to come out of the corner the rear end kicks out and almost (or does) spins me out. I am running the links in the 2-A position, and i have the adjustable rear hinge pin brace so i can change to what ever. I am running 7-5-2 diff oil and 3 degrees negative camber. i really wanna plant the rear end better middle out of the corner any ideas?
Did you check your ride height in the rear. Depending on the track conditions it should be set around 29mm and the front at 27mm. Also check your shock length for the rear. 160.5mm is a good start. What sway bar are you running?
Team Associated SC10 4x4 | Losi 8ightB 2.0
E-Flite CX2 | E-Flite 120 SR
--Jim Balazic
jimbal is offline   Reply With Quote
Old 05-19-2008, 11:35 AM   #6802
i am running the black sway bar and i will have to check my ride height again i think i had it set at 30mm
Old 05-19-2008, 12:24 PM   #6803
DOMIT's Avatar
The small silver bar will help.
Old 05-19-2008, 12:27 PM   #6804
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
try the smaller sway bar in the rear. if that dosent help go to the b hole on the rear hub. Also run -2 up front and -1 in the rear for camber.
micrors4guy is offline   Reply With Quote
Old 05-19-2008, 01:09 PM   #6805
BRETTMASTERJ's Avatar
is it worth it to get the king headz extended engine mount instead of the non extended?
BRETTMASTERJ is offline   Reply With Quote
Old 05-19-2008, 01:10 PM   #6806
jimbal's Avatar
Go with the small, silver, sway bar and drop your ride height to 29mm to 28mm.
--Jim Balazic
Old 05-19-2008, 04:09 PM   #6807
SteveJa's Avatar
Trader Rating: 17 (100%+)
question about the slop in the hex's. has anyone put washers behind the wheel hex to take the slop out? does it work? and what shims are you using ?
thanks
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 05-19-2008, 04:14 PM   #6808
SteveJa's Avatar
having problems with the servo saver. It seems that after I get it set and run it for a bit, the servo saver get tighter? almost to the point where you think it is locked up.... but after I rebuild it, it is fine. I am using the 8t spring and have the aluminum servo saver. the best thing i can do to fix it is buy new plastic parts, but that gets old and $$$ after awhile.
thanks
HATCHER RACING !!!!
Impulse R/C
Old 05-19-2008, 04:15 PM   #6809
Integra's Avatar
thanks
Kyosho makes a 8x10 kit with .1 .2 and .3's But u have to be careful to not jarr up the bearing as that will cause it to fail even faster.
Old 05-19-2008, 04:19 PM   #6810
Integra's Avatar
thanks
are u using loctite ? it should'nt move if u are.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
