Old 05-13-2008, 12:52 PM   #6751
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
You know, I was thinking the same thing. If you look on Amain, GMK (the makers of the CVD condoms) also makes dust caps. They're the same thing! Other than the fact that the condoms have a hole for the driveshaft of course...
K_B is offline   Reply With Quote
Old 05-13-2008, 01:25 PM   #6752
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
alot of the things that gmk sells is just re packaged items. The carb-o's are just hair ruberbands. The diff dunker is a cooking item from walmart. the wheel putty is tire plugs. i can probley keep going on but i forgot the rest of their products
micrors4guy is offline   Reply With Quote
Old 05-13-2008, 05:39 PM   #6753
DirtyDezPirate's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to DirtyDezPirate
Default Wonder
I wonder what would affect the perform on the 8ight buggy if i change the center diff main drive gear? what would happen if i go down to 47 tooth and run 15 tooth? and 46 tooth on 16 tooth.. does it even make any difference?
I am just ME!
DirtyDezPirate is offline   Reply With Quote
Old 05-13-2008, 09:45 PM   #6754
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
less out of the hole with the higher pinions, and more top end/ less top end with the smaller spur gear and quicker out of the hole.
when mine was nitro i liked the 13/48 worked on pretty much everything. now with it being electric i run a 12/46 on a 2k kv motor and its pretty good everywhere xcept the strait where i neeed a bit more power.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 05-13-2008, 10:06 PM   #6755
Trader Rating: 73 (100%+)
Originally Posted by DOMIT View Post
I found out something interesting this weekend... gonna have to give this a try:
As an inexpensive, readily available method to retain the CVD pins, one of the local guys is using "engine dust caps." Has anyone tried this? How did it work out for you?
https://www.amainhobbies.com/advance...MK0119&x=7&y=8
I had a set come in with my lsat order. We'll see how thwy work.
losifiend is offline   Reply With Quote
Old 05-13-2008, 10:38 PM   #6756
I thought about getting those, but don't think I need them. I just check my CVD's after every session/race and use red thread loc on them.
Furadi is offline   Reply With Quote
Old 05-13-2008, 10:45 PM   #6757
air8's Avatar
I kind of wish losi had done what Xray is using now. The CV joint is all captured by the pinion bearing. Just like on the outer front CV shafts on several vehicles. No set screws to worry bout falling out. But, then you'd have the extra wear an tear on the pinion gear. So ehh...whatever.
I still use the heatshrink.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-13-2008, 10:46 PM   #6758
Hey guys, here is my roller. Just painted the body.
Goint to run a Losi 427 untill I get a GO .21, 5 port motor.
Nice! Think I just got an idea for my next body
Old 05-14-2008, 06:27 AM   #6759
tex1's Avatar
Send a message via Yahoo to tex1
Now you can do a flag with stars.
TEX
tex1 is offline   Reply With Quote
Old 05-14-2008, 10:59 AM   #6760
Geo Y-Rock's Avatar
Anyone need some tires?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=170219428415
Sponsored by: Team Losi ~ Nitrotane ~ Spektrum Radios ~ GRP Engines ~ Upgrade/Rc Id ~
I got 99 problems, but a b!#ch ain't one!
Geo Y-Rock is offline   Reply With Quote
Old 05-14-2008, 11:07 AM   #6761
YGPM
clarksib is offline   Reply With Quote
Old 05-14-2008, 12:13 PM   #6762
Trader Rating: 22 (100%+)
Has anyone installed the aluminum knuckles and carriers ?
mine are developing some slop and there are many companies that make them
losi
3racing
integy
has anyone had experience using them?
i'm concerned about the tolerances / fit of them
phixd is offline   Reply With Quote
Old 05-14-2008, 01:23 PM   #6763
desertbird's Avatar
The peg on my idle stop screw broke on my 427 engine. Anyone know of a replacement?
desertbird is offline   Reply With Quote
Old 05-14-2008, 09:27 PM   #6764
losi
3racing
integy
i have the aluminum knuckles installed on my buggy and thier pretty awesome aside from the fact that the screw that holds the carriers at the pivoting point of it makes a little notch in the knuckle. and the place that holds the setscrew for the spindle king pins you cant pull out the threads thats a plus
vroom88 is offline   Reply With Quote
Old 05-14-2008, 09:31 PM   #6765
Someone had mentioned before that adding the 50t spur you the losi did not need any gear mesh adjustment and that the spur did not stick out the bottom of the chassis. However, i got 2 of them in today and the tip of the teeth (about 1mm) stick out the bottom of the chassis and i did have to move the gear mesh. I will be making a spacer to go under the center diff mounts so the center spurr is not sticking out the bottom of the chassis.
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
