Old 05-02-2008, 03:48 PM   #6691
Ephidelt490's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Ephidelt490
LOSI now makes a screw kit that comes with 5 screws of every size for like 20$ and comes in a nice box just like the shock service kit. Both of thoes are very good to keep on hand.
(this is micrors4guy on adams name at his shop)
[Action Hobbies] [Team Associated] [Futaba] [O'Donnell Fuels] [JConcepts] [DNA Designs]
Ephidelt490 is offline   Reply With Quote
Old 05-02-2008, 09:17 PM   #6692
air8's Avatar
Awesome!! Thanx micro
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-03-2008, 09:59 AM   #6693
I&I
Originally Posted by Cory B View Post
The Losi 8ight is best when driven bone stock (with a couple of exceptions)
The aluminum rear diff inserts are a must
get an aluminum steering servo arm
the quick change motor mount assembly is nice
and I also use the adjustable toe plates, front and rear.
I wouldnt waste your money on fancy aluminum braces and hardware that you dont need. all it does is make your car heavier and handle like crap.
I recently switched my set up from a "pro" set up to the Losi Race Roller "easy to drive" set up and LOVE it!!
car handles great, turns really well, and is surprisingly stable!
Thanks for the info. Where did you get the "easy to drive" setup?
-Losi Eight-T w/RCPD EL8 Kit (Nice kit, but broke battery tray), Neu 1515/1.5D/F, 46T Kyosho Spur, 12T Pinion, MMM ESC (Died First Run On Track & Puffed Battery) now using MM & custom case, Hitec 5955TG
-Losi Eight-B w/RCPD EL8 Ultimate Kit (STILL Waiting!), Neu 1512/2D/S, 46T Kyosho Spur, MM ESC, CC BEC, Hitec 5998TG
-Losi Eight-T w/Teckno RC Kit (Waiting!)
-MaxAmps 4s 6000 MaH Lipos (NOT recommended for a 4s/Neu setup! Use higher C rating!), Hyperion 610iNET (Works nice!)
I&I is offline   Reply With Quote
Old 05-03-2008, 10:29 AM   #6694
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
http://losi.com/Products/Support.aspx?ProdID=LOSK0800 on that page
micrors4guy is offline   Reply With Quote
Old 05-03-2008, 09:37 PM   #6695
Cory B's Avatar
actually, it's right here http://losi.com/ProdInfo/Files/thodg...RaceRoller.pdf
FYI, I race on a rough, hard pack track and have found that using all carbon clutch shoes with 2 gold and 2 aluminum springs works great. Crimefighter XTR tires are also a great choice.
Wild Bill's R/C Hobbies - Knoxville, Ia
Velocity R/C www.velocityrc.net
VWings
AFX Fab
Lancebuilt Hobbies
Cory B is offline   Reply With Quote
Old 05-04-2008, 08:33 AM   #6696
I&I
Thanks! That happens to be my local track also! It's large, smooth, loamy, very loose and dusty until just after watering with big jumps too. I would like to get a setup like that for my 8T also. Do you have the web link for these downloads? I tried going up a directory, but it didn't work. The only setup I got from the losi site was Drake's and it seems hard to drive.
I will try the all carbon setup. Maybe that will help with breaking loose.
Old 05-04-2008, 06:57 PM   #6697
Cory B's Avatar
You could try this set-up for your 8ight-T
http://losi.com/ProdInfo/Files/8IGHT-T-rossetti.pdf
It was used at Revelation also.
I don't own a truggy so I really dont have any tips or tricks for it. I hope this set-up helps
good luck!
VWings
AFX Fab
Lancebuilt Hobbies
Old 05-04-2008, 08:18 PM   #6698
what problems are you having with your 8t? if the rear end is loose try the smaller sway bar and moving the hubs back a little. that is the only 2 changes i have made to mine from the box stock setup and it is great.
Old 05-04-2008, 09:35 PM   #6699
hi guys.
i just got myself a race roller losi buggy. i notice there are different in the usage of differential oil.
anyone tested the new race roller versus the earlier kit?
lesser vicousity diff oil will make the car turn faster i guess.
chersss
novaa is offline   Reply With Quote
Old 05-05-2008, 03:02 AM   #6700
TIX
TIX's Avatar
I just got the adjustable hinge pin braces for my car and im wondering what i should be setting them to. I'm pretty new to RC and i was wondering how changing these will effect my setup
Our local track is hard packed, high grip with an open layout with some pretty big jumps.
The other tracks i run are alittle tighter cornered and looser surface
I run both an 8 and an 8T
Id really love abit of an explanation of how changeing these angles front and rear effects the car
TIX is offline   Reply With Quote
Old 05-05-2008, 03:06 AM   #6701
Matt Howard's Avatar
Originally Posted by novaa View Post
hi guys.
chersss
The race roller actually has a more forgiving setup than the kit does. This is the setup that Cory put on his 8ight and he loves it
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-05-2008, 06:14 AM   #6702
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
TIX -
You might want to take a look at the back of your manual. It is very clear on everything about chassis dynamics and how it works. It is basic and easy to read. If you can, try reading it with the car sitting in front of you.
The only thing it does not do is diffrentiate between steering and rotation. They generally call it turning. No big deal.
On buggy rear I run:
toe = .5 in pills
Anti squat = 0 pills
On the front I run 0s.
The Losi manual is very good and we can clarify anything you might have trouble with.
Hope this helps,
TEX
tex1 is offline   Reply With Quote
Old 05-05-2008, 07:53 AM   #6703
desertbird's Avatar
I replaced my servos with Hitec servos now the throttle linkage does not fit. I have a horn for steering that works, but the throttle is not as easy to swap out with Hitec.
What are my options to get the linkage on a Hitec servo? I bought a set of inserts but none of those are Hitec. Suggestions?
desertbird is offline   Reply With Quote
Old 05-05-2008, 08:03 AM   #6704
desertbird's Avatar
Old 05-05-2008, 08:39 AM   #6705
Gliptal's Avatar
The 24T insert should work with Hitec
Gliptal is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
