Old 04-24-2008, 11:07 AM   #6661
Originally Posted by soccerlaw View Post
I have the same issue as above on my brand new 8T race roller. It seems like there are quite a few people with the same issue, but no real resolution. Somebody mentioned sanding down the bearing inserts, but not sure (a) whether to do both the rear bearing inserts, (b) how much to sand off and (c) why I should have to be sanding a new car. Some people said it's normal but it sounds and feels like the diff and pinion gears are just not meshing up right at all. Clunky sound and feel. Not just the sound of new gears on new gears.
Also, I have tried the aluminum replacement bearing inserts but they make it even worse.
Any help would be greatly appreciated.
Mine smoothed out after about a gallon.
Furadi is offline   Reply With Quote
Old 04-25-2008, 09:40 AM   #6662
I solved the problem on mine and a buddy's just by loosening the the rear brace retaining screws a little less than half a turn and I put some extra grease on the ring and pinion gears.
clarksib is offline   Reply With Quote
Old 04-25-2008, 12:50 PM   #6663
Trader Rating: 22 (100%+)
My rear diff was clicking under hard acceleration and braking. I thought the bevel gears were broken. It turns out the gears were fine. I then bought the aluminum outdrive holders and when i went to install them, it turns out that one of the outdrive bearings blew up. I had to spend another 15 dollars on the bearings.
phixd is offline   Reply With Quote
Old 04-25-2008, 01:38 PM   #6664
Derby Bros Racing's Avatar
Try one of these next time:
http://www.avidrc.com/shop/?action=i...vid=&prevstart=
At $1 a piece, $15 would do almost the whole car not just the outdrives.
Derby Bros Racing is offline   Reply With Quote
Old 04-25-2008, 01:44 PM   #6665
Wow thanks for the link. I'll be buying my bearings from there. i'd rather blow up 1 dollar bearings instead of the more expensive Losi bearings.
is there any difference in quality that you have seen?
Old 04-25-2008, 01:52 PM   #6666
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
+1 for $1 bearings if your on a budget.
I just buy 10 of each bearing used in the 8, and I have replacements for quite a while. Also, since they are cheap enough, toss a bearing instead of re-lubing it if your in a hurry.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 04-25-2008, 02:28 PM   #6667
Integra's Avatar
most places do 1$ a bearing now a days...Boca Avid Protec..ect.ect.....i toss bearings every month or so now and rebuild with Fresh Brand new 1's...at the prive its worth it to buy 100$ worth of All sizes and be able to toss em without worry of running out...i have 100$ in metric and now Standard sizes in bearings.
Old 04-25-2008, 11:33 PM   #6668
moparsrule's Avatar
Just some info for those looking for the hd diff cases, tilted rc has around 100 of them in stock now, they also have the new outdrives and foams in stock.
moparsrule is offline   Reply With Quote
Old 04-27-2008, 04:47 PM   #6669
Funny the bearing issue should come up. I just logged on to complain about mine... This was my second day out with the 8ight. So far I toasted the clutch bell bearings (last week) and the rear diff bearings today. Maybe the fronts also, they seem wobly but I have yet to pull it apart...
Whats the deal with these Losi bearings? Usually the kit bearings are better than the $1 aftermarkets
ALJR is offline   Reply With Quote
Old 04-27-2008, 05:59 PM   #6670
Trader Rating: 65 (100%+)
Hello all, I have had a Losi 8t for a while now and I'm replacing clutch shoe's with Dynamite Max Life shoes. Just wondering if somone knows what springs seem to work the best and so on..... If the max lifes are worth putting on ect.. I just dont want to go through 200+ pages because I know it might be somewhere in this thread. Thanks in advance
Team G FORCE Hobbies / Team Driver
Losi/Tekin/Spektrum/AKA/SMC/Avid Rc
Pot Belly's RIP!
Jaypeezy is offline   Reply With Quote
Old 04-27-2008, 06:45 PM   #6671
Integra's Avatar
Dyna's are 1 of the best shoes on the market these days.....for springs...it depends on the conditions...I run a ALL silver set-up and i like the stall just the way it is....ya 200+pages is a Daunting task...take it day by day...u kinda see the revolution of the truck/buggy throughout the year.
Old 04-27-2008, 06:54 PM   #6672
Thanks Integra, right now I have black and gold springs but Ill see what I can come up with
Pot Belly's RIP!
Old 04-28-2008, 12:31 AM   #6673
No not really. Avid quality is very good. In fact, even factory drivers like Adam Drake, Travis Amezcua, and Scott Kimbrow to name a few, trust and use Avid bearings for perfomance and durability.
Old 04-28-2008, 07:31 AM   #6674
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I've always run Avid bearings on other cars... just bought a "set" for the Losi (you have to look them up individually and order them of course... sizes are in the manual, just read through the assembly and the sizes are marked.) And I ordered 10 sets (20 bearings, 10 of each size) for the clutch bell.
We blow the clutch bearings out with compressed air before running... otherwise you'll have grease on your clutch shoes.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-28-2008, 01:36 PM   #6675
On past buggies, I have used ceramic bearings for the clutch and did what you sugested, blow/clean the grease out... Cleaning out stock ss bearings is asking for trouble as they do not last at all... The ceramic bearings hold up better under high-heat, un-lubed conditions...
Im running ceramic inner on the 8 now and so far so good
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
