Old 04-14-2008, 01:43 PM   #6571
RETRO RC's Avatar
Originally Posted by micrors4guy View Post
if you are able to get the pin out you will be able to pull the hex and drive shaft out. then just replace the drive shaft.
like micros says if you punch the pin out you could always replace the driveshaft end
http://www.amainhobbies.com/product_...oducts_id/7714
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 04-14-2008, 01:47 PM   #6572
air8's Avatar
Originally Posted by BRETTMASTERJ View Post
I have a small problem... I broke the tip of my hex driver inside the set screw that holds the pins in the wheel hex. I cant get it out I would like to save the hubs and not dermel it. I need to get it out so I can replace my hub bearings. Any ideas would be great.
Another thought here after reading RETRO's post. I have a set of small files. One of them is shaped to a point on the end. I might try something like that to create a slot in the broken tip. Then you might be able to loosen the broken bit and then try a new/stronger hex driver. If this is a RTR use a lighter to heat up the set screw. As the set screw expands it will break up some of the loctite the factory used. Then you might be able to back that thing out if it's not too messed up from the broken hex driver. GOOD LUCK, man.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-14-2008, 03:44 PM   #6573
Has anyone had a problem with their 8ight diffs leaking. My 8eight is brand new and this is the first buggy/truggy I have owned with leaky diffs. Any tips would be appreciated.
-Kane
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 04-14-2008, 03:45 PM   #6574
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
where is the diff. leaking from? arround the gear or from one of the outdrive inputs?
micrors4guy is offline   Reply With Quote
Old 04-14-2008, 04:08 PM   #6575
BRETTMASTERJ's Avatar
Trader Rating: 21 (100%+)
-Kane
change the seals in the diff
BRETTMASTERJ is offline   Reply With Quote
Old 04-14-2008, 05:18 PM   #6576
cornerspeed's Avatar
Originally Posted by stevoreno007 View Post
My local track is pretty short, not that many jumps, and is usually a bit slippery with some loose dirt, but banked corners.
What shoes and springs would work best?
If possible, I would also like them to last.
Try this set-up. All plastic Losi shoes with 4 Gold springs. It will last for 4-6 months and I think there is less heat andeven help the CB bearing last longer.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 04-14-2008, 07:30 PM   #6577
It is leaking from around the center spur.
rcdepot.us
nxgraphics.ca
Old 04-14-2008, 08:29 PM   #6578
Integra's Avatar
i found a tiny wet spot on my center diffs on both truggy and buggy after rebuilding....so i just used some racer's edge sealant..problem solved.
Old 04-14-2008, 09:47 PM   #6579
Sounds like a plan, thanks.
rcdepot.us
nxgraphics.ca
Old 04-14-2008, 10:45 PM   #6580
RETRO RC's Avatar
if you go to all carbon-(composite)- make sure you use a new clutch bell or dremmel the aluminium residue off the inside of your old one.
if you don't the composite will wear out pretty quickly
Adrian
Old 04-15-2008, 12:49 PM   #6581
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
-Kane
Nope, no problem, mine leaked out just fine. lol
Actually I lost all my rear diff fluid by being excessively gentle when I tightened the screws that hold the ring gear on my rear diff. I was worried about stripping the screw holes in the soft plastic.
5-5-0 is NOT a good setup on a Losi! (but it sure turns!)
Other than that, no, no leaks. I was less "gentle" on reassembly and haven't had a problem since.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-15-2008, 01:34 PM   #6582
big igg's Avatar
Trader Rating: 14 (100%+)
Blow a shot of air into it. I had the same problem and mine few right out. Not sure if one of those air can things are strong enough. I use my air compressor. Hope this helps
big igg is offline   Reply With Quote
Old 04-15-2008, 02:38 PM   #6583
Thanks for all the ideas guys i ended up punching the pin through and replaceing the axle end.
Old 04-15-2008, 03:22 PM   #6584
Trader Rating: 22 (100%+)
interesting.....
i'll pass though
phixd is offline   Reply With Quote
Old 04-15-2008, 05:20 PM   #6585
^ for all us carbon freaks.
Lynn Kelley is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
