Old 04-09-2008, 06:06 AM   #6541
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Originally Posted by LosiMadMan View Post
Stupid question, but how do you break the box in?
He is talking about breaking in the motors that are in the box . After Losi had many issues with the motors burning up they mentioned afterwards the motors need to be broke in . Run the starter box a few times with nothing on it .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 04-09-2008, 07:25 AM   #6542
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Originally Posted by stevoreno007 View Post
Anyone have experience with carbon fiber shock towers? I want to upgrade these because I have the RTR and see the carbon fiber ones on ebay for $30 for the pair (about the same as a pair of the kit towers).
Are these as tough as the kit towers? Or should I just go with the kit version?
Thanks!
the problem with carbon towers is that if any of the role center adjustments or shock standoffs come loose at all they will destroy the tower. I have seen it happen on my buddies Rc8 a couple times.
micrors4guy is offline   Reply With Quote
Old 04-09-2008, 07:37 AM   #6543
Integra's Avatar
Not ramming it right outta the box...Running the motor's On and off with Zero Load for 10-15 minutes...then applying comm drops and bearing drops to the can's periodically.....Also rewiring the whole box and soldering All the connections makes a WORLD of difference.
Old 04-09-2008, 07:54 AM   #6544
Can I run 2, 7.4v 2s li-pos in the 8ight starter box? The reason being that my charger only charges 1-3, and I can save some money. That rules out the 4s li-po from losi or anyone else.
LosiMadMan is offline   Reply With Quote
Old 04-09-2008, 09:17 AM   #6545
Integra's Avatar
Yupp....no problems there.
Old 04-09-2008, 11:42 AM   #6546
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by tex1 View Post
Stevo - Carbon shock towers would be for stiffness and weight savings. They can take a little punishment but are not as strong as actual CNC kit towers. Those things can take a beating.
TEX
Yup, what Tex said. Trust me, I've tested this theory. They're tough. They don't call me "Captain Crash" for nothing! (I'm up for promotion though... soon to be Major Crash!)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-09-2008, 07:49 PM   #6547
chad220's Avatar
Trader Rating: 15 (100%+)
Hey guys im haveing a little trouble mounting up my new GO Tech 5pt on my 8ight. it seems like i cant get any play on the clutchbell. Do i need to dump the GO collet and get a losi collet to get the correct spaceing?
chad220 is offline   Reply With Quote
Old 04-09-2008, 08:27 PM   #6548
ALWAYS use the losi collet for the losi flywheel
Old 04-10-2008, 12:34 AM   #6549
dodgeboy93's Avatar
Default 8 starter box ?
when u use a gel cell batt it says that u can hook up the extra leads to the power ports, these ports are for a glow plug igniter right? when i hooked up my igniter it just blowes the plugs instantly too many volts! what do u guys use???
dodgeboy93 is offline   Reply With Quote
Old 04-10-2008, 12:49 AM   #6550
Trader Rating: 22 (100%+)
glow igniter: 1.2 volts
gel cell : 12 volts
Some starter boxes have a power panel that regulates the voltage into output ports where you can hook up a glow starter with wires
good ol' xtm =X
http://www.hobbypeople.net/gallery/146070.asp
phixd is offline   Reply With Quote
Old 04-12-2008, 08:01 PM   #6551
big igg's Avatar
Trader Rating: 14 (100%+)
Hi,
Sorry if this has been covered before, but has anyone trying using a Werk's 4 shoe clutch in there Losi buggy? I installed mine tonight and it looks like it might work. I have not run it yet with it installed. I need to rebuild the shocks and diffs. Thanks
big igg is offline   Reply With Quote
Old 04-13-2008, 06:56 AM   #6552
Suspended
Trader Rating: 440 (99%+)
My buddy is using the stock losi engine mounts with a werks clutch. The crankshaft screw comes close to the tank but it does clear.
MattP is offline   Reply With Quote
Old 04-13-2008, 05:30 PM   #6553
SteveJa's Avatar
Trader Rating: 17 (100%+)
I have a drive shaft pin question.
The pressed in pin on the drive shaft (part that goes in the drive cups) front, rear and center..... what part # mugen or xray or whatever can you use to replace them ???
SteveJa is offline   Reply With Quote
Old 04-13-2008, 06:48 PM   #6554
They are either the 3x13mm ro 3x12mm not sure. If someone can clear this up that would be cool but here are the part
#MUGC0271 3x13
#MUGC0270 3x12
Bone Saver tool
http://www.amainhobbies.com/product_...oducts_id/4355
I wonder why the dog bones are the same ones from the LST2 and the pins on my LST2 have no problems and its bigger and weighs alot more.
Old 04-13-2008, 11:13 PM   #6555
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Madman,
That is on the truggy correct? On both my 8ight and 8ight T, the only real wear I have found is on the front center more so than on the rest. The only reason I saw for it was because of the angle that drive line hits the center diff. Not too big of an issue to me, but if left unchecked could be a very bad thing.
Teufel Racing is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
