Old 03-19-2008, 02:48 PM   #6406
From what I have been told, they are just working on refining the car. I have talked to Todd Hodge about it. It sounds like they are just trying to improve the current design.
RC Pro Products,Alpha engines,Spektrum , FASTLANE-GRAPHIX.COM,HP Hobbies and Trackside Designs
indaway is offline   Reply With Quote
Old 03-20-2008, 01:32 PM   #6407
dsl
dsl's Avatar
HELP !
I got a new 8 buggy roller. Whenever I roll it back and forth with my hands, the rear diff is making a grinding noise.
I ran the buggy for 1 race day figuring it needed to be broken in, but after running about 6 tanks, the problem was still there.
I took the rear diff out of the case and it spins freely, but when I put it back in the plastic case it grinds once the screws are tightened up. If I don't tighten the screws, it doesn't grind.
A friend of mine went through the same problem and it was resolved when he replaced the new plastic rear diff housing.
I couldn't find a solution to this problem by shimming. Any suggestions?
dsl is offline   Reply With Quote
Old 03-20-2008, 04:01 PM   #6408
tex1's Avatar
Send a message via Yahoo to tex1
Red face
I have seen some diff cases that were molded wrong and the side grooves were shrunk up and not in the proper location. Get you a new rear diff housing and you should be fine. If that one fixes the problem then be sure to send your original back to Losi. They will send you a new one as back up.
Hope you get it resolved.
TEX
tex1 is offline   Reply With Quote
Old 03-20-2008, 07:12 PM   #6409
Has anyone had problems with the pins working their way out of the CV Shafts toward the outdrives? I have had this problem on both my truggy and buggy. I know the ones in the hubs have a set screw. I have only had it for about a month. Horizon sent me a set for the t and b. good customer suport, but I want to find out if there is something I can do to resolve the issue.
Losi 8ight-B, flex chassis, O.S. .21
Losi 8ight-T Race Roller, JR 9000 T&S, O.S. MAX 28XZ
Spektrum DX3R
Losi Modified Aftershock
HPI Baja 5B
rescuemann is offline   Reply With Quote
Old 03-20-2008, 08:18 PM   #6410
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Some TL bodies for you guys to check out, !
Thanks,
Jim
W.E.D.
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 03-20-2008, 09:30 PM   #6411
spiti58's Avatar
Thumbs up
those look awesome, great job w.e.d
"U Ain't Fast!!"
"Thats how i roll, fast and out of control, nothins gonna slow me down! except mabye the occasional pipe."
spiti58 is offline   Reply With Quote
Old 03-21-2008, 05:32 AM   #6412
Those are awesome. How do I get one
Spektrum DX3R
HPI Baja 5B
Old 03-21-2008, 05:52 AM   #6413
Get a Bone saver and a set of Mugen pins and replace the pins in the CV Shafts.
http://www.amainhobbies.com/product_...oducts_id/4355
Out of stock though!!
LosiMadMan is offline   Reply With Quote
Old 03-21-2008, 06:17 AM   #6414
air8's Avatar
Also if you're referring to the F/R pinion CVDs then you can clean the threads and CV shaft of all dirt. Apply blue loctite to the threads. Then either put heatshrink on or GMK condoms. http://www.amainhobbies.com/product_...ducts_id/13168 Some people have had the CV cross pins work through using the heatshrink method. But I've not had a problem. I use the heatshrink method.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-21-2008, 06:56 AM   #6415
R40Victim's Avatar
I put heat shrink on mine a little over a year ago, no problems.
R40Victim is offline   Reply With Quote
Old 03-21-2008, 03:54 PM   #6416
abailey21's Avatar
Trader Rating: 36 (100%+)
As I'm sure I could search in here hours upon hours and find nothing so I'll ask the question that everyone can prolly answer in like 2 seconds...
I've heard, and seen now, that the stock shocks on the RTR 8 were pretty much leaking messes. Do they just need a good rebuild with new boots, o-rings-spacers and all the other seals, or was there some really easy super awesome fix that was found?
I'm asking cause I just picked up a used and I was told by the previous owner that "It's and original RTR and the shocks are crap" it has been obvious because the 4 puddles of oil in the bottom of the box.
So I need quick fix, and cost effective ideas on getting this into a reputable roller again.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-21-2008, 04:14 PM   #6417
Nik
Nik's Avatar
http://www.amainhobbies.com/product_...oducts_id/7812
these are what you need. First run kits came with black orings, newer ones have white. The white o-rings are far better seal.
Nik is offline   Reply With Quote
Old 03-21-2008, 05:02 PM   #6418
abailey21's Avatar
thank you much man
K.C.C.O.
Old 03-21-2008, 06:15 PM   #6419
abailey21's Avatar
As luck would have it, the dude I bought it from had a pack of the white
o-rings, pretty sweet I must say....simple fix, the way RC should be
K.C.C.O.
Old 03-21-2008, 06:21 PM   #6420
mathsinstrument's Avatar
Has anyone tried converting the screws to metric using the RcScrewz set? how well does it fit?
I hail from a place where metric is more dominant and easier to get...
mathsinstrument is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
