Old 03-02-2008, 05:04 PM   #6316
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Anyone got comparisions between the 8ight and an MBX5R?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 03-02-2008, 05:30 PM   #6317
Roberts's Avatar
What is the best way to get the flywheel off and on an OS V-Spec without taking off the back plate and using the OS tool to hold the rod? I know they make a flywheel tool but do they work with Losi? I just hate taking the back plate off and maybe getting dirt in the engine when I'm at the track.
Thanks for your help.
Ed Roberts
Roberts is offline   Reply With Quote
Old 03-02-2008, 05:39 PM   #6318
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
If your talking about pulling the clutch nut, I just wrap a rag around the flywheel and grip it with a channel lock pliers.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-02-2008, 05:42 PM   #6319
Nik
Nik's Avatar
to put it on... tighten the nut until it grabs, then hold the flywheel with a pair of channel locks and snug it down... use loctite of course...
If you need to hold the crank and the little cone washer behind the flywheel doesn't grab, it wont grab when your on the track either, so replace it.
to take it off... take the nut off, hold the engine flywheel side down.. and tap the back of the flywheel with a plastic handled screwdriver to break it loose.
Nik is offline   Reply With Quote
Old 03-02-2008, 06:38 PM   #6320
Roberts's Avatar
I can get the flywheel off by tapping with a rubber hammer but the problem is tighting the nut. When I start the tighten the nut the flywheel just spins so I have to take the back plate off to tighten the nut all the way. Is that the only way to get it tight, I don't believe in using a piston locking tool.
Thanks,
Ed Roberts
Old 03-02-2008, 07:00 PM   #6321
dsl
dsl's Avatar
This thread is too long to read through every post, so I apologize if this has been addressed already:
I just bought a new 8 buggy roller.
I wasn't sure what upgrades to buy, so I ordered:
DYN2542 Dynamite Machined Aluminum JR, Airtronics, KO Double Sided Servo Horn (Blue)
LOSA9114 Team Losi Clutch Springs (Gold): 8B/8T
LOSA9115 Team Losi Clutch Springs (Silver): 8B/8T
LOSA4430 Team Losi 8ight Aluminum Rear Gearbox Bearing Inserts
KHZ-KP-230 King Headz Team Losi 8ight Rear Radio Tray Stiffener
GMK0119 GMK Supply "CVD Condoms" (Team Losi 8ight/8ight-T)
LOSA4441 Team Losi 8ight Servo Saver Top, Aluminum: 8B/8T
LOSA99030 Team Losi Aluminum Servo Arm: JR
DYNP5188 Dynamite Max-Life 8ight Aluminum Clutch Shoes Set
LOSA3542 Team Losi HD Brake Disk Set, Vented: 8B/8T
LOSA4442 Team Losi Aluminum Center Front Diff Bearing Adapter
I've heard of throttle servo issues, so I ordered the King Headz plate stiffner (is this enough to fix the issue)?
What other immediate/important issues are there with the 8 and what parts do I need to fix them?
THanks everyone
dsl is offline   Reply With Quote
Old 03-02-2008, 07:10 PM   #6322
Matt Howard's Avatar
just follow the instructions on setting up the throttle servo to a "T" and you won't have any problems.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-02-2008, 08:45 PM   #6323
What's the hot setup for the 8ight buggy?
Dave.H is offline   Reply With Quote
Old 03-02-2008, 09:04 PM   #6324
Nik
Nik's Avatar
go over to losi.com
and check out Drake's and Truhe's setup sheets. Pretty good start.
Old 03-02-2008, 09:17 PM   #6325
Old 03-02-2008, 10:06 PM   #6326
I have a few friends that bought the 8ight RTR and they have a lot of slop in the front and back of the buggy. The 8ight RTR at my local hobby shop has alot of slop also. I just got done building my 8ight Compitition Kit and it has no slop at all. Whats the deal? I know the slop will come after running it, but why do the RTR's have so much slop.
LosiMadMan is offline   Reply With Quote
Old 03-02-2008, 11:28 PM   #6327
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
The RTR's use a different plastic than the kit. Its a way to have them mass produced at a cheaper cost, though the parts look the same.
Teufel Racing is offline   Reply With Quote
Old 03-03-2008, 07:41 AM   #6328
ezveedub's Avatar
Thanks,
Can you run the nut down on the crank completely without any binding? Sounds like you either bottoming out the nut on the crank or have a burr on the crank threads. If the nut tightens down fine, then put a shim behind the collet.
Old 03-03-2008, 08:08 AM   #6329
C&B RC's Avatar
+1
Just had the same problem. Run the clutch nut down the shaft without the clutch on so you can see & feel how far it will go. Mine was hanging up and I retapped the the nut with a 1/4-28. Also clean off any old locktite from the threads so the nut doesn't hang up on it.
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 03-03-2008, 12:14 PM   #6330
Registered User
Kendall Welch's Avatar
Going back to the captured rod ends mod. I used the Losi ends like vlad pointed out. No problems after 3/4 year of running on them; before I was popping off ends like crazy after big jumps or bumping a pipe. Definitely one of the major things to change on your car first to ensure it finishes the race.
Kendall
Kendall Welch is offline   Reply With Quote
Losi 8ight Clutch building Cvdiver Nitro Off-Road 3 05-21-2008 04:47 AM
Team Losi 8ight Buggy with Brushless Setup RcOneNitro R/C Items: For Sale/Trade 9 04-20-2008 06:04 PM
losi 8ight-t package f/t for brushless lipo setup ColeT R/C Items: For Sale/Trade 6 03-02-2008 11:17 AM
Losi 8ight-t setup F/s ColeT R/C Items: For Sale/Trade 15 02-11-2008 08:51 PM
OS .21 V-spec Cluth Setup on Losi 8ight? RcOneNitro Nitro Off-Road 6 09-03-2007 01:07 AM
